Question about LG KP500 Cookie black on T-Mobile U-Fix £25 Text , with 30 mins & 500 txts a month Cell Phone
Network problem so i was playing around with my cookie and i accidentally opened the small black thing at the back and put a needle in the hole and now i cant get network......what do i do to fix it witrhout spending a lot of money......:-(
Whilst putting cd into my hi fi accidentally pushed close button drawer closed before cd properlyinserted. Now I cant open to get cd out
Look close, many times there is a tiny hole the size of a needle by where u put the CD in.
Pop a needle in there and it will release the CD as it opens the door.
Oct 19, 2015 | Televison & Video
How to change a sim card in an iphon 3gs
to remove the sim card this requires a very small tool or fine needle or fine piece of rigid wire and insert it into the ejection hole located near the sim card.
Hope this helps
Aug 21, 2012 | Apple iPhone 3GS Black (16 GB)
Hey, i have just installed this and my son played around with the settings, and now the connection to the internet is only available to this computer. I have tried to get into the settings using...
It sounds like he either shut off the wireless or put a WEP security key on the router that is blocking your connections. The address to connect to the router is probably 198.162.0.254 which is the normal default.
May 15, 2011 | D-Link DIR-600 Router
My needle won't move even with hand wheel. Feed dogs move. Bobbin turns. Bobbin winder is off. Did same thing last night then worked when I turned it on this morning. Quit with 6 inches left of 12 yard...
You have a gumed up basting device, You can try to fix yourself but should be taken to a bernina teck for a fix. Take the end cap/head cap/ side panel/ needle bar panel off. It is one screw on the left side.
Remove neddle
Find the needle bar
On the needle bar there is a black small pice, it is round and has a little tab that stitcks off it.
Pull the needle down and push/pull/wiglle soft on the small black tab.
There is a small pin inside that should clip into a hole in the needle bar.
This should get your machine sewing again but the basting device realy should be cleaned and adjusted, should be around $45-100.
Hope this helps.
Mar 27, 2011 | Bernina Artista 170
Cd drive won't open
There is a pin hole in front of the tray door, put a fine screwdriver or needle in the hole push it in until you hear a click and it should pop open, pull the draw all the way, open until it stops, look under the tray you should see a small black belt "loading belt" if it's okay the loading motor is bad, The CD ROM driver needs to be replaced.
Jan 03, 2011 | Acer Aspire 5535-5050 Notebook
I don't know how to refill
Hi Good day!!!
1. Spread newspaper or paper towels on a table to create a workspace protected from spills and accidental leaks. Set the cartridge on this workspace.
2. Remove the label on top of the cartridge. Use a razor to peel up one corner, if necessary, then peel back the rest.
3. Fill the syringe from your refill kit with between five to 10 milliliters of ink. Match the ink to the color listed on the cartridge.
4. Insert the syringe needle into one of the holes on top of the cartridge. If there are no holes in the cartridge, you must create one. Use a thumb drill (also included in your refill kit) to punch a small hole through the plastic.
5. Insert the needle into the cartridge. Inject the refill ink into the cartridge until it is full. Ink will bubble up around the hole when the cartridge is full. Fill the cartridge slowly to avoid mistakes and spills.
6. Place the cartridge back into the printer. Wait at least a few hours before printing. Some refill kits recommend waiting 24 hours before using the printer. Print a test page when the cartridge is ready.
Oct 26, 2010 | Computers & Internet
How do i get the needle to go back around to the top side of the peg on the fuel guage of my 1997 chevy malibu
Don't disassemble the dash! It will take hours and will rattle from now on. Use a very small gauage of wire, inserted in the odometer reset botton hole, to move the needle back around. It takes a minute or 2. This guage problem usually happpens when the battery is disconnected.
Jan 27, 2010 | 1997 Chevrolet Malibu
Similar problem
That would be the thread guide. You need a small allen wrench to put this whole thing back on. There is a hole in the right side,looks like a hole, it's blackish, but is for allen wrench. The curved metal piece slides up into a tiny hole from the bottom near where needle enters then slide whole thing back on machine and tighten with allen wrench.
Jun 29, 2009 | Brother XL-5340 Mechanical Sewing Machine
Accidental format
press a small paperclip into the reset button hole on the back of the mp3 unit the turn it on again
Mar 12, 2008 | Samsung YP-U3 MP3 Player
Motorola Network Pin Blocked
Hi
I have a RAZR V3 that my son was playing around ,I don't know what he did but when he gave the phone back to me it was off and when I turn it on to make a call the phone says -Enter Unlock Code- I have no idea what's the unlock code ,when I entered 4 zeros like-0000- and hit OK , the phone says INCORRECT CODE-TRY AGAIN. I tried a bunch of numbers with no luck. I can only enter 4 numbers at a time . NOW I THINK I'M LOCK OUT and cannot use my RAZR V3 anymore. PLS. I NEED HELP TO UNLOCK THIS PHONE .
Nov 20, 2007 | Motorola Mobility RAZR V3
LG KP500 Cookie black on T-Mobile U-Fix £25 Text , with 30 mins & 500 txts a month Cell Phone Logo
32 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
