Question about Brother DCP 115C All-In-One InkJet Printer
I cannot print a photo or doccument - Brother DCP 115C All-In-One InkJet Printer
How to get rid of this doccument jam scanner on display and there is no paper in it at all or dust nothing at all
Check Control Panel and CANCEL any print operation. If no result, disconnect printer, connect it again. Noting?
Remove first color then BW ink heads, try. Noting?
Disconnect USB and power. Connect again.
Same stuff?
Uninstal Printer and try to reinstall it again.
Nothing?
Well if after ll this your printer is still hanged up, you should take it to service
Apr 26, 2015 | Office Equipment & Supplies
Mfc 9880. printing clear 100%. problem with copying only. feint and blur copies, cant see 98% of doccument. i tried cleaning the scanner unit. i think i probably messed up sumthing..
Probably did! I found out the hard way on a HP All in One that all the remedies out there wouldn't make it print until I bought a new print head. This one would go through the motions of printing but I got blank paper in and blank paper out. You probably didn't mess it up it can do that itself. I would just get on the web and spring for a new head and be done with it. dhgill
Aug 24, 2011 | Office Equipment & Supplies
I have a DeskJet 722C printer that just doesn't have good print quality for color images anymore. All print-outs have a vertical line pattern through them. Is there anything that can be done? Or is it time...
hi,
first let me know that is it only happence with the color doccument?or it happening with all the documents...if its happening with the all doccuments then you need to open the rear door and clean the rollers...then takeout the cartridges..take a clean cloth and clen the copper dots...put them in..if still facing problem...you need to replace the printer..
Mar 23, 2010 | HP DeskJet 722c InkJet Printer
Printer is printing vertically, and not horizontal..please help..
Hello sir; When you make a copy, make sure the doccument direction should be same with the paper from the tray.
Dec 28, 2009 | Canon IMAGERUNNER 2230 Copier
Hello, I have a canon printer. new ink ink run on , how long to be take this process, I want be to print a doccument.
Hello sir; That 's very difficult to tell, all depend on each color using volunm, but for general speaking about 3000 to 4000.
Oct 12, 2009 | Cannon Canon i960 Photo Printer
Samsung SCX5312 copies look very pixilated/grainy. Prints look fine. I cleaned the Optics. This got rid of the background but did not correct the CQ. Has new drum & fuser. Problem is definitely in...
Hello sir;Did you reset copier after you replace a new drum? if not please do it, if still have problem, you need adjust shading;
Close doccument feeder, select adjust shading . press "set up" An image will be scanned and a ccd shading profile will be print put, if the printed image is different than the image the ccd is bad.
Aug 14, 2009 | Samsung Office Equipment & Supplies
Black line down the center of the page when printing
1,check the scannor unit,which is doccument feed in open the cover look the piece glass is clean.
2, replace drum cartridge.
Dec 16, 2008 | Brother MFC-7220 All-In-One Laser Printer
Stopping printer in process
in most cases you will have a printer icon in taskbar, doubleclick it and stop the process. if not, go to START > SETTINGS > PRINTERS and choose "purge print doccuments".
Feb 22, 2006 | Citizen Impact PR Matrix Printer
Brother DCP 115C All-In-One InkJet Printer Logo
23 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
