Question about Bosch Cooktops
Oven clock / timer
The oven clock / timer will not set and the oven will not work as a result.
  • 23 Answers
This could be a very pricey repair. Depending the make and model of your part. Try to contact the parts department for your oven and see how much they say a new clock/timer will be. The higher end models could require a 300 - 400 labor just to install the part. Most companies will not do it if you have the part so be sure to ask first.
Posted on Sep 04, 2009
Why would there be no heat from frigidair oven elements?
Make sure the oven timer is set properly, if its turned off, the oven will not go on. Also check if the oven has separate fuse, it may have blown.
Aug 24, 2014 | Frigidaire Stove/Oven/Range Black Glass...
Burners work on top of stove, but oven and clock not working
Make sure the clock is not set to "auto" function or on "timer" mode. The oven will not start until the correct time has come up. If the clock is not working , this is likely to be the problem. See if there is a manual operation control or switch. You may have to get a new clock or arrange for the clock to be bypassed so the oven can work without it. Most electronic clocks can stop an oven from working if they fail.
Jun 19, 2014 | Kenmore 30 in. 42701 / 42702 / 42709...
I have an LG electronic range it is on recall for the burners going on spontaneously, they have yet to fix this for me. Now the oven set buttons for both the regular and convection over will show and
Thats what is sounds like to me- or the keypad..... Anytime you have multiple malfunctions of of the control panel, it usually is one or the other. Hope this helps. Good luck, Dennis Wayne
May 08, 2014 | LG Electronics Range. 30 in. SeCleaning...
I just installled a Verona VEFSGE 365 dual fuel range/oven.
Got to your manufacturers instructions and check if you have a auto cook timer for the ovens, if so normally the timer needs to be set on "Manual" to enable it to function.
Apr 29, 2013 | Verona VEFSGE365DAW 36" Double Oven Dual...
Fisher & Paykel Thyme main oven not working
You could try reseting the clock to the manual position.
If in Automatic the oven won't turn on until set time.
Mar 18, 2013 | GE JB870 30" Free-Standing Electric Double...
I have a Frigidaire Gallery Professional Series Stove and Oven unit. The oven temperature indicator light has been fading for years and is now barely visible. Everything else on the control panel (timer,...
Hello arab125 - I understand that the timer and clock works fine, however from what you have described it sounds like the range could possibly have a wiring failure, faulty sensor, or an issue with the EOC. I would suggest contacting a professional to move forward accurately.
Oct 08, 2012 | Frigidaire FGEF3031KB Gallery 30"...
Stove is fine but the oven does not heat.
Possible faulty element. What about the clock/timer? Is it on the right setting? It should be in manual mode. If the timer is okay it will generally be an element or a faulty connection at the element.
Feb 09, 2011 | GE Cooktops
The power went out and then the elements and oven would not work but there was power to the clock?
This solution only really applies to oven elements only. I haven't experienced it with hotplate elements as they are not normally controlled by the timer. When you have an electronic timer and there is a blackout the timer normally reverts to auto. function when the power comes back on. You have to set it back to manual before the oven will work. Turn the oven element to ON and the set it to manual. The oven element indicator light will light and the oven will work.
Feb 06, 2011 | Stoves 23 in. Premier TC600I Electric...
Clock & Timer Malfunction
you can go to the back of the clock and clip the buzzer wire[one is allyou need] tape it up.other wise you need a new clock
Dec 31, 2008 | Cooktops
Cook top
Sounds like you have cartridge fuses in your house. When only one is blown it can cause interesting results. The clock is probably feeding back through the burner. This lets enough electricity through to run the clock and othe small things but not enough for heat. Have all the cartridge in your house tested. I'll bet either one of the mains or range ones are bad.
May 28, 2008 | Frigidaire Cooktops
Cooktops Logo
213 people viewed this question
Top Bosch Cooktops Experts
Paul Carew
Jay Finke
Jay Finke
Narinder Chhina
Narinder Chhina
Are you a Bosch Cooktop Expert? Answer questions, earn points and help others
