Question about Canon L120 Fax Laser Printer
Activity Report Printing
Please can you give me instruction on how I can obtain an Activity Report on the i-SENSYS FAX-L120 I cannot find our office manual. Thank you
What will be the reason for canon sensys fax-L 150 coping dark page but faxing and printing is ok.
First things first. Try and print report from the fax. Any kind of report. If it is printing OK, then the next step is to check if:
Your clients receive your faxes OK? If they are dark as well, then your scanner head is at fault.
When you make Copy on your fax and it prints dark it could be simply set with dark settings _or_because of the white calibration strip or roller being soiled or dirty, which acts as the ultimate white reference point for scanner _or_ the Scanner CCD sensor is in paper jam release position (too far away from reading the originals) just pull it back to normal feed position.
Or simply faulty scanner.
Sep 30, 2016 | Canon i-SENSYS FAX-L150 Laser...
How to stop automatic "activity report" printing
in the menu section search for activity report and turn it off
Apr 18, 2016 | Canon PIXMA MX452 Wireless Office All In...
I have lost instruction manual. How do I 'copy' on a canon FAX-L120
1-Load the document face up in the ADF/Tray
2-Enter the copy mode by pressing Copy Button
3-Enter Quality
4-Press Start
For any further information/ clarification please refer to Chapter 6, Page 80 & 81 for the Canon i-SENSYS FAX-L120 Manual.
Save the Manual for Future reference
Hope it helps! Good Luck!
CreativeTECH
Mar 11, 2011 | Canon i-SENSYS FAX-L120 Plain Paper Laser...
My fax machine cannon i sensys fax-l 120 is showing memory full. i cant recieve any fax. how i can clear memory
Hi
in order your fax to print you need to replace the cartridge
when the cartridge is low it stops printing incomming faxes
and keep it in mem untill you replace it with a new one
unfortunly this cartridge can not be refilled and use it
Hp is better on this
Jan 31, 2011 | Canon i-SENSYS FAX-L120 Plain Paper Laser...
Printing an activity report
You should be able to get an activity report through the menu key. Push the menu key and scroll to reports Push ok/set key and scroll to actitvity report. Push set/ok key, one or the other, and an activity report should print out.
Jan 24, 2011 | Canon FAX-L1000 Plain Paper Laser
How to do an activity report
Set activity report ON, under report sett. under user mode (MENU), then the report is automatically printed after 20 TXs or RXs.
I think that there must be some kind of button with triangle with "eye", there must be counter, status, and if I recall activity report printout.
Hope that helped
Mar 15, 2010 | Canon L120 Fax Laser Printer
Memory Full Canon i-sensys Fax L120
try this
press "menu" and then "#" button, go to service mode. Select the "clear data function". and select "memory clear"
Sep 03, 2009 | Canon i-SENSYS FAX-L120 Plain Paper Laser...
Canon L120 Fax Laser Printer Logo
103 people viewed this question
old marine
old marine
