Question about Garden
Ryobi ry30160, will not stay running..... changed plug,gas,cleaned carb? will start but will not stay running. Am at wits end..........
  • 3 Answers
SOURCE: Briggs & Stratton Engine Won't Stay Running
Make sure none of the hoses are cracked or loose fitting
Posted on Aug 03, 2008
SOURCE: Ryobi gas string trimmer won't run
I have a RYobi SS30 and it will not run at all. I have pulled the cord about a hundred times, yes after about 10 I should have gotten the picture, but if anyone knows what to do to correct this I would appreciate this. I am not very mechanically inclined so any help would be appreciated
Posted on Sep 28, 2008
  • 41 Answers
SOURCE: engine stalls when giving gas
Make sure you have the carb. fuel line on the correct side of carb. Not on primer bulb side.
Posted on May 15, 2009
  • 115 Answers
SOURCE: Ryobi 720r trimmer starts ok but stalls when the
The carburator needs to be adjusted a little, thin our your mixture screw when the trimmer is warmed up and idling. Well how do you get it to idle? I usually have to play with the choke lever with the throttle wide open going from choke to partial choke as needed to keep it running. Adjusting can be tricky, you need a small screwdriver. Screw all the way in then back out 3 to 3.5 turns. this should get you close. Adjust idle as needed.
Posted on Jul 06, 2009
SOURCE: RYOBI weed eater.hard to start. starts then stops
I have a ryobi doule line bought in 1997..Had same problem put new gas cap on and problem solved..could not get air in....
Posted on Aug 02, 2009
I have a Ryobi RY28120 gas powered weedeater that will start sometimes and not at others. Not sure if the carb needs cleaning or if it need a new muffler. Maybe adjusting carb screws? Not sure! Also,...
Use only fresh gasoline (alcohol free if you can find it). Purchase a top quality synthetic 2 stroke oil such as Lucas, Golden Spectra and mix it exactly as the manufacture dictates. Install a new accurately gapped plug and make sure the plug wire cap (boot) is pulled back to inspect the wire to connector crimp. Start it up as you normally would to allow the new gas and oil to permiate the system and if you cannot get it to stay running without the choke being on shut it down and squirt some oil into the carburetor and pull the trimmer over, if this makes it start everytime it does not want to start and it allows you to click off of run you have either low compression (rings are worn). or your carb is yet another victim of the geniouses that thought alcohol in gas was a super idea. Either way you can replace the piston and rings or the carb. both are almost not worth the time and cost anymore, a new carb for mine is $70.00, with a new piston and ring set being around $40.00 and a brand new trimmer the same as this one on sale at $130.00 it was an easy decision to buy new.
Jul 18, 2014 | Ryobi Garden
Echo ppf-210 power pruner will not stay running? I have changed the plug, rebuilt the whole carb, new gas, etc. Still will not stay running? It will idle a small bit and as I pull the throttle I get no...
check the fuel filter to see if its dirty or not under fuel . also you will have to re-tune the carb . or check for compression in the engine it should be at 120 or above you may also want to change the plug
Sep 26, 2013 | Echo POWER PRUNER
My ryobi cs30 gas trimmer (3 years old) has been difficult to start this year, has been getting worse all year and now wont start. What's up?
Most likely it is the spark plug, but could be a dirty fuel system. I'd start with the spark plug then go from there. you can also use a good quality fuel injector cleaner in your gas to help keep all your small engine carbs clean. If the problem persists there is a fuel filter inside the gas tank that plugs onto the end of the fuel pick up line that could be clogged. Worst case a carb kit can be gotten for them for about $20 bucks. Hope this helps. Please vote yes, thank you.
Nov 01, 2010 | Ryobi Gas Hedge Trimmer
My ryobi weedeater has had a carb rebuild kit installed last year,but it will start and run if i constantly press the fuel bulb.this is the only way it will stay running.when i stop pressing the bulb,it...
As long as the fuel lines are not cracked or broken, then you will need to disassemble the carburetor and spray with carb. cleaner. Use a Den Tek brush, (http://www.amazon.com/dp/B000V5MQ7Y/ref=asc_df_B000V5MQ7Y820727?smid=AKZ54EXMVZHXW&tag=dealt5228-20&linkCode=asn), to clean the small portals in the carb. Make sure the small screen in the carb. is free of debris. Reassemble and start. Let me know if you need further assistance.
Jim
Jun 10, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Ryobi CS30 will start but when I pull on the Throttle trigger it bogs down, good spark plug and filter is good. I have the same problem. Cleaned everything and even put NEW mixed gas in and still does not...
Check the fuel lines first for cracks. If they are cracked or brittle, replace them. Also, your carburetor may need cleaned. Use a Den Tek Brush, (used for cleaning between teeth), to clean the small portals. Make sure the small screen in carb. is free of debris. The smallest of particles can cause your problem. Reassemble and try starting. If it still acts up after all this then you will have to purchase a carb. kit and replace all appropriate parts. If you need tips on these remedies, feel free to ask.
Jim
May 29, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Trimmer won't stay running without starter fluid
drain any old gas/fuel mixture out of unit.
purchase new gas and mix with oil as recommended for your engine.
clean the air filter on the unit.
pull the spark plug and clean with carb spray and reinstall...
you also may need to remove the carb and clean any jets with carb spray... old gas can turn into a shellac'ish type goo and foul up the works...
I recommend draining all fuel after usage...
Problem with gas trimmer staying started
Carburetor is out of adjustment. there are two carb adjustment screws on the side of the Carb. they require a special tool that is only $5 from your local mower repair dealer. those screws are the idle and Hi speed mixture adjustments. the carbs on Ryobi are set too lean. turn counterclockise to richen the mixture. just turn one eigth of a turn at a time. start w the hi speed.
Apr 03, 2008 | Ryobi 15" Electric Factory Reconditioned...
Garden Logo
139 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
