Question about Garmin StreetPilot C330 GPS Receiver
Blaupunkt travelpilot lucca 3.5 frozen on first screen
I changed a registry key in HKLM\init when i wanted to run iGO8 instead of original lucca soft. Rebooted navigation and this happened. When I turn it on it freezes on the first blue screen.
I also tryed to copy recover data from original CD to SD card but with no effect.
The only thing which works is USB connection (I can see and manipulate with 3 flash disks on PC when I attach the navigation: 1st - the SD card, 2nd - 1GB internal disk with original maps and 3rd - cca 40MB internal disk with some screensavers etc. [no OS folder anywhere] ) Can somebody help me to fix it?
p.s.
apologise my English please...
marcelbakker
  • 174 Answers
SOURCE: cannot find my map data anymore
Have you checked the wrench menu, map info, the preinstalled map should have a check mark, if not tap on the check box, it should now show a detailed map screen when you go back to the main menu and select show map.
Posted on Jun 12, 2008
  • 98 Answers
SOURCE: want to download free maps to my garmin c550 gps
hear is the manual what maps do you want
Posted on Jan 25, 2009
SOURCE: My Garmin StreetPilot c340 is frozen.
No.......the C340 STREET PILOT has a hidden reset button. Put your fingernail in the slot just under the GARMIN name on the front face plate. Gently pull the face plate outward. Don't take it all the way off. The reset button is on the right side of the front screen just under this plate. Use a pointed object and hold the button IN for 3 seconds and unit will turn off. When you power it back up it will REBOOT.
Posted on Jun 10, 2009
  • 1111 Answers
SOURCE: Garmin Nuvi 250W stuck on "Loading Maps..." screen
Try the reset, and if that fails, download the web updater from the garmin site and try that route.
Master reset will erase all way points or favorites and will restore your unit to the default factory settings.
  1. Start with the unit OFF and unplugged from power
  2. Touch and hold the lower right corner of the screen with an index finger or the eraser end of a pencil
  3. Continue touching and holding the lower right hand corner of the screen then power the unit ON
  4. Release the power button when the device powers ON
    • You will see a new message: Do you really want to erase all user data?
  5. Remove your finger from the touchscreen when this message displays
  6. Touch Yes
Bill 39c203c.gif Learn from your failures or you will fail to learn.  Theory: you understand why it should work but it doesn't
Practice: it works but you have no idea how
   ALL That is necessary for the Triumph Of evil is That good men do nothing.
Posted on Aug 30, 2009
  • 1043 Answers
SOURCE: My garmin 1300 says no
Your map file may be corrupt. You can go to the Garmin website where you registered your unit, and download the same map. If you want to update to a newer map you can do that as well. To ensure that you have the correct map you will have to register your unit if you haven't already done so. Go to the following link:
https://my.garmin.com/mygarmin/customers/myGarminHome.faces
You will have to first make sure that your GPS is attached to your computer with the black USB cable that came with your unit. Plug the smaller end into the back of the unit and the larger end into one of your USB ports. The GPS will automatically power on. You will see a graphic on the bottom of your screen that looks like a GPS connected to a computer. A line will appear halfway up the screen which will start as a white line and then change to a green one. Once that is done you can register at the above site. The website will attempt to connect to your GPS so that it can read your model and serial numbers. It will then show you which maps are available for you.
Posted on Mar 13, 2011
Actualizar mapas gps blaupunkt
COMO ACTUALIZAR MI GPS BLAUPUNKT TRAVELPILOT LUCCA MP3. PRDEONE LAS MOLESTIAS, SALUDOS.
Oct 15, 2012 | Blaupunkt TravelPilot Lucca MP3
I need usb kabel for travelpilot lucca mp3
The Travelpilot Lucca does not have the capability to be connected by USB cable. The connector socket on the bottom of the device is intended for a cradle built into a car that provides connectivity to compatible Blaupunkt car radios. It is a proprietary connector unsuited for PCs.
MP3 files are transported to the Lucca via SD cards only.
Jan 04, 2011 | Blaupunkt TravelPilot Lucca MP3
My blaupunkt lucca 5.3 Sat Nav says PUK error System block How do I get over this problem please.
A request for a PUK code ("Personal Unlocking Key") will appear on your phone if your SIM card PIN code is entered 3 consecutive times incorrectly.
Your SIM card will then become "PUKed" or Blocked. This is a security measure to protect your service.
You need to call the Customer Service department of your cell phone provider and they will give you the PUK code which will unblock your SIM card.
Jul 21, 2010 | Blaupunkt TravelPilot Lucca 3.5 Edition...
Blaupunkt lucca.exe error
find update firmware from this site and update the firmware on the device or re install the software. http://blaupunkt.de/en/servicesupport/audio-pl/car-audio/downloads/updates/
Dec 30, 2017 | Blaupunkt TravelPilot Lucca MP3
Transfer map from sd to lucca 3.5b
blaupunkt travelpilot lucca 3.5b free map
Sep 29, 2008 | Blaupunkt TravelPilot DX-N GPS Receiver
I've a Blaupunkt Travelpilot Lucca MP3 sat nav. The touch screen is not working. It powers up. But it cannot go further. 'OK' button is not working.
i wsa in Saturn in Wiesbaden, and i tried to operate blaupunkt Lucca 3.5. the touch screen was working, but it was not accurate at all, and wasnt sensetive enough, especially with finger. with a stylus it was much better. i tried recalibrating the touchscreen (twice) but it didnt help
in other models of Blaupunkt i didnt find this problem
Mar 13, 2008 | RIM BlackBerry Pearl 8100
Garmin StreetPilot C330 GPS Receiver Logo
298 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
