Question about Amana Refrigerators
How do you get to the 1/8" supply line from bottom of freezer door to the water dispenser Amana SXD22S2W?
  • aliceburkett Sep 04, 2009
    You must be kidding! This does NOT address the problem & is hardly readable (read it yourself) - especially for someone who has worked on many applainces. By the time the unreadable answer came, I had half solved the problem myself.
  • 3,741 Answers
You will have to check the connections first.also you if the connections are there previously and you have to convert them to 1/8" then you can just connect the wire.but if there is no connection and you have to modify the unit then electrical connections has to be checked.but actually there is a electrical connections already in most of the units between bottom of the freezer and water line. you can click this link directly for the wiring diagrams/schematics http://www.applianceaid.com/image/samplecandiagram2.jpg --------- thanks.keep updated.
Posted on Sep 04, 2009
Water dispenser does not work, any time it is used water just drains out of bottom of freezer area onto floor. Ice cubes works
Hello Melissa;
My name is Peter. I am a retired field service refrigeration technician.
I am sorry to say you have a serious problem.
The water supply line to your ice maker runs up the back of your refrigerator from the ice maker solenoid. It is a separate water supply line.
Your water dispenser water line runs from the water dispenser solenoid under your unit and up from the bottom of you freeze door.
You have a plastic tubing leak within your freezer door. Calling a service company to replace the freezer door tubing - a good service technician would not replace the tubing - the damage has already been done.
The insulating material in your freezer door is soaked. The water in the door will cause the door liner to expand and crack. There is no way to completely dry out the insulating material.
The only fix is to replace the freezer door. So, $300.00+ for the door and $150.00+ for the service tech. No, a hair dryer will not do it.
May I suggest:
1.) Remove the bottom toe plate (Kicker plate) in the front of your refrigerator.
2.) Turn the leveling screws counter clockwise so you can pull the refrigerator out to get behind it.
3.) Unplug the unit.
4.) Remove the screws from the bottom cover.
5.) There are two connectors to the solenoid valve to the water dispenser. It is the larger diameter tubing running under your refrigerator.
This will disable your water dispenser. If you see cracks on the inside of your freezer door, seal them with a high temperature silicone adhesive.
If you elect to purchase a new unit, check out Sears Outlet (Scratch & Dent) Stores.
May 08, 2015 | Refrigerators
WATER WILL NOT DISPENCE FROM WATER DISPENSER
Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws. Covering the opening with a blanket will prevent the loss of cold in the freezer. .
disconnect the line to the water dispenser at the water inlet valve on the back where the water supply comes in and try the dispenser. if you hear the valve work but water doesn't come out, the valve is bad. If you don't hear the valve, the dispenser switch is bad
Sep 27, 2010 | Amana ASD2324HES Stainless Steel Side by...
Water dispenser stopped working, freezer temp down
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws
disconnect the line to the water dispenser at the water inlet valve on the back where the water supply comes in and try the dispenser. if you hear the valve work but water doesn't come out, the valve is bad. If you don't hear the valve, the dispenser switch is bad.
Dec 17, 2009 | Amana Side by Side 20.6 cu. ft. Cabinet...
Water dispenser won't work --ice dispenser is fine but no water comes of the water dispenser.
fridge set too cold ? frozen tank or water lines in fridge. set ref warmer for a couple of days
Aug 26, 2009 | Amana AFB2534DE Bottom Freezer French Door...
Water dispenser not working
I have a Hitachi R-M800GM.
When i operate the water dispenser, water flows out from the dispenser [not strong flow]. There is also water flowing out at the bottom of the freezer door [hinge area]
I think the line running inside the freezer door may have come loose? If so, how to reattach it? Do u have any layout drawings of how the hose is being connected.
Please help.
Thanks,
Rick
May 31, 2009 | Amana ARS2464B Side by Side Refrigerator
Internal water dispenser stopped working
I lowered the temp on the freezer to 4 overnight, by morning water dispenser is working fine. I think that when we changed the temp to 7 (in order to make more ice ) it froze the water pipe going to the dispenser. I am going to keep both fridge and freezer at 5 ,and hope this will not happen again.
Dec 31, 2008 | Amana AFD2535FES Stainless Steel Bottom...
Amana Refridgerator Freezer, French Doors
Most side-by-sides have a length of hose at the bottom of the freezer that send the water to the ice maker and water dispenser. take the back off so you can see this hose, there may be a kink in it, or a clog.
May 30, 2008 | Amana ACD2232HR Side by Side Refrigerator
Refrigerators Logo
114 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
