How do you plug in and by what cords - Office Equipment & Supplies
  • 1 more comment
  • carmawhite Sep 04, 2009
    Murphy:
    What does a USB cord look like?
    carmawhite@comcast.net
    What does USB Cord look like?
    carma
  • carmawhite Sep 05, 2009
    I have a HP 6100 All in One. I have a Toshiba Laptop and I have cable internet. I have misplaced the cords and have forgotten how to plug it all in, and what cords I need.
    Can you help. I am computer dense and will need step by step instructions. Thanks,
    Carma
  • 2,404 Answers
I would need to know what printer you have but normally you hook the printer up to the computer thru a USB cord and then a power cord to get power to the printer. I would try that and if your still having trouble, get back to me the make and model of your printer and I can help you further.
Posted on Sep 05, 2009
  • 13,433 Answers
What is the question? What is the brand and model of your printer and what are you trying to use it with? your desktop computero or a laptop?
Posted on Sep 04, 2009
    President:
  • 2,004 Answers
You plug a printer to your system/ laptop through the usb port.
The usb connector cable will sought for printer via laptop connectivity.
Good luck.
Rate this.
Can i use my old 4 prong cord on my new dryer ?
Check you cord if it should resist the amperage of your dryer. and have security plugs. Else, no problem
Apr 24, 2015 | Kenmore Dryers
Power cord
braun 7030458 syncro shaver charging cord for electric razor braun 7526 adapter power cord replacement parts.
Jun 01, 2013 | Braun Syncro 7526 Electric Shaver
Power cord was pulled out and looking to replace the cord
Two types of power cords--ones that are soldered into a board inside the set and ones that plug onto a socket inside.
Almost any standard POLARIZED cord will work for the soldered in ones---Polarized cords at the plug have two lugs--one larger than the other---
The large pin goes to the neutral side of the electrical outlet--if replacing a soldered in cord you MUST get them the same.
The larger lug on the cord will have a white stripe on that side or a rough surface.
Neutral to neutral and hot to hot---the hot side in the set goes to the fuse.
This has been around for decades--it prevents the cord from being plugged in backwards (Polarity) and if installed backwards the set will work but you will have 120 volts potential voltage on all external metal fittings like the CABLE fitting---sparks will happen when you try to put the coax to the set and it will feed this back to all sets via the cable in your home.
Get it right the first time----a cord that plugs onto pins will have this also but the plug on the cord if original (Toshiba in this case) will not permit this reverse polarity because of the shape of the plug itself at the end of the cord.
Dec 08, 2012 | Toshiba TheaterWide 52HM84 52" Rear...
I am trying to use a Plantronics CS70N headset with my Mitel 5215 IP Phone. I have the headset plugged into the headset jack on the back on the phone, but there is no head set button. Is there some...
First remove the headset cord from the headset jack. That is only used for corded headsets. Plug the short cord into the jack where the curly cord had been plugged into. The curly cord is now going to be plugged into the base of the charger where the picture is of a handset -- the curly cord goes there. There is a A/C adapter that is plugged in to base that is now plugged into the wall.
Good luck from Headsets Direct!
Jun 29, 2011 | Mitel 5215 IP Phone
Hello i am having probelms with my Belkin g basic router it has wireless and it works but when i connect it to my computer it does not it says it can't find or something but if i plug in my other box that...
It's sounds like you're getting your cords mixed up. The modem (the box from your company that provides internet) needs it's power cord plugged in, a phone cord or a cable cord plugged in, and an ethernet (LAN) cord plugged into it. The power cord will plug into the wall obviously, the phone cord or cable cord will be coming out of the wall obviously, but the Ethernet (LAN) cord will plug into your computer or a router. A router in your case. So the Ethernet cord from your modem (box that came from you company that provides internet) will plug into the router in the specific slot that says Internet or Modem connection. Now you need another Ethernet cord to go from your router to your computer. Try to plug the cord that goes from the router to the computer into the 4 different ports on the router until one of them works, you'll have to give it about a min to check each one. If that doesn't fix it then you need to make sure your LAN card is being read correctly and installed correctly, best way to do this is to go to Start > Control Panel > Device Manager and look at Network Adapters. If there is a Red X next to a conenction, right+click the conenction and tell it to enable, or update drivers.
Dec 13, 2010 | Belkin (F5D7231-4) Wireless Router
The plug at the end of the headphone is wearing out
I don't know if this might help, but see my tip on replacing dodgy cable and plugs on headphones.
May 24, 2010 | Grado RS2 Professional Headphones
I need a new power cord. I took out the back and
The power cord (E901 which plugs into P901) Hitachi part # for this model is EV00851 but it would not be commonly stocked since most repair shops would repair the cord. The repair would be done by either splicing a new cord on to the old one or unsoldering the old cords plug receptical (P901) and installing a new generic cord in its place - either way observe the polarity -white wire to thick blade of cord. Post back if you need more info (I may have a used cord)
Nov 23, 2009 | Televison & Video
Damaged plug on end of float switch
if it is just a small length of cord you can just attach any cord to it from any old appliance, if you feel that it needs to be waterproofed go to home depot and by one for wet areas
Sep 18, 2009 | Water ACE SUBMERSIBLE SUMP PUMP 1/3 HP
It will not turn on, i tried the reset button still no power. How do i fix it?
Check the plug end of the power cord--if the cord is pulled instead of the plug, it can cause breakage of the wires inside the cord. Try pulling the plug from the cord--if the insulation seems to stretch-out, shorten the cord a little(an inch or so) and install a new replacement plug. If cord seems ok, then an internal inspection of the motor area is the next option.
Jul 11, 2009 | Jack Lalanne Power Juicer (Stainless...
19 people viewed this question
k24674
jasbo
jasbo
