Question about Canon Office Equipment & Supplies
My imageclass coper wrinkles every copy and smudges the ink
  • 4,806 Answers
It sounds like that the unit just needs a thorough cleaning around the roller and print head area's.
This is a common problem with just about all printers, fax machines etc.
When ink gets on the rollers and starts to dry it's stays tacky causing all the paper that goes through it to wrinkle up as you have described.
Another thing to look out for is foreign objects around the feed and exit tray.
Rubbing alcohol is an excellent form of cleaner or if you haven't got rubbing alcohol a damp, warm, clean non lint cloth should suffice, take care when you are cleaning the unit not to knock anything out of place.
Good luck.
Posted on Sep 04, 2009
We have a canon imageCLASS 2220 coper/fax that is set to default to fax when the power is turned on or the machine is idle for a few minutes. How can we get this default changed to copy instead of FAX?
I need to change the IP address on my canon imageclass 2220. I have moved locations and I know they are preset on the machine HELP I know I am overlooking something
Jan 18, 2010 | Canon (6981A002AA) for imagerunner 2200,...
Smudges on copies
You may want to try the series of steps required for "cleaning" the inside of the printer. Usually there are a combination of reset buttons that are used to clean a printer and it could take about 10 minutes. The Canon website usually has which combination of buttons will do that.
Sep 15, 2009 | Canon imageCLASS D320 Digital Copier
Smudges on paper and then when it does copy, ink is light.
hi,check copy cartridge or clean corotron wire.try to increase toner.send me result.
thank you.
May 25, 2009 | Sharp AR-5320 Black and White Copier
Canonimageclass D320 makes smudged copies. What do I do?
This model is noted for a jam in the fuser area around the roller, Not easy to get to but sounds a like that may be proble, Can you hear a sound like paper wrinking as it runs. Also is the drum in the cartridge clean or has tone on it. Have you changed the cartridge. I do get a kick out of Staples Experts.. They did sell you some cleaning sheets... Hey Good Luck....
Apr 23, 2009 | Canon imageCLASS D320 Digital Copier
Ink remains wet and if touched smudges.
Sounds like the fuser is bad...try installing a new fuser.
Apr 20, 2009 | Office Equipment & Supplies
Wrinkled and smudged prints comes out wrinkled on one side and smudged on the same side.
The fuser needs to be replaced. Most likely its either worn or damaged.
Mar 27, 2009 | HP LaserJet 1320n Printer
Canon ImageClass D660
With a clean cloth and maybe a little rubbing alcohol should do
Jul 25, 2008 | Canon imageCLASS D660 All-In-One Laser...
Dirty smudges when printing
try to go to the enternal part of your printer and check if theres an inks.. or try to check on the set-up if you have a clean printheads... try running it again...
Jun 12, 2008 | Canon imageCLASS D680 Laser Printer
Cannon Imageclass printing problem
You need to check your glass first to make sure it has no scratches. Then you can run a copy and open door to stop paper in the center of the machine, b4 it goes through fuser. If line is on copy, you have a bad drum. If not your upper fuser roller is bad.
Oct 19, 2007 | Office Equipment & Supplies
16 people viewed this question
old marine
old marine
