RISO GR 2950
Show
A07-418 paper jam sign
We have a gr 3750 and when the paper tray comes up the feed wheels do not start up to feed the paper in.Any suggestions
  1. check the upward sensor for adjustments and the sensor on the stripper pad unit for adjustments
Mar 13, 2011 | Riso Office Equipment & Supplies
Riso gr 3770 error T14
how can i solve the Error T14 for Riso Gr 3770
Thanks
May 12, 2009 | Riso RZ220 Duplicator
Riso GR3770 will not pull the paper through once it passes the initial feed assembly. The paper ''picks up'' just fine, but after the lead edge enters the machine, it kicks off impression and gives a...
what happens sometimes is the rear side of the registration (shiny silver color) roller becomes worn down so bad that the spring cannot grab properly. the registration roller, in this case, would have to be replaced.
the way to check is by getting to the back of the machine, and if this is the cause, the spring should be a little wobbly on the shaft. with a new roller, the spring fits snug, and grabs properly for it to feed.
Mar 31, 2009 | Riso Office Equipment & Supplies
Paper feeding problems Riso TR1510
refix your ink cartrdige also check there is not any paepr jam issue.
also some times printer neeed servicing creates this type of issue.
Mar 28, 2009 | Riso Office Equipment & Supplies
Riso 3700 - Error Code G064
1 Power  swich off/on
2 Open and close front cover twise
Mar 22, 2009 | Office Equipment & Supplies
Risograph GR 1700 E02
check the Paper Feed Tray.. is there something in the way? does it go up and down? if it is all the way up or down maybe it got pushed off the rail?
Mar 11, 2009 | Riso Office Equipment & Supplies
first try paper feed clutch.. make sure nothing is blocking paper path...
Feb 03, 2009 | Riso RZ220 Duplicator
Margin shift
If it is a GR or FR it is out of timing.
Jan 29, 2008 | Riso RZ220 Duplicator
91 people viewed this question
jasbo
jasbo
