Question about Sony PlayStation 2 (PS2) Console
Disk tray won't stay in
When i put a disk in, the playstation keeps ejecting it. And the blue light is blinking blue.
  • 4 Answers
Hi i have the same problem with my ps3. what i do is when your ps3 is off put the game in the slot then turn on ur ps3 it will load the disk and will stay in. when you want to play a diff game eject the game then turn off the ps3 then again put the game you want to play in the slot and turn on the ps3 it will load the game i hope this helps
Posted on May 18, 2009
Your PS2 is definitely broken. Either send it in to Sony to be repaired or buy a new PS3. Bummer. Sorry to hear about this.
Posted on Dec 20, 2007
Can not get the mac pro osx 10 5 8 to start with the utility disk or with regular start up my on pilot lite keeps blinking
Put the Mac install disk back in. Try pressing command-option-escape to force quit. If nothing happens, then press command-control-power to force a restart. If that doesn't work, press and hold the power button for five seconds or so until the computer shuts down. Power up the computer again, and hold the option key so you can select the instal disc for startup. Run Disk Utility again. Sometimes you get a tangled file reference that requires several tries to undo - this could be calling the sleep routine instead of what it's supposed to do.
May 28, 2013 | Computers & Internet
Mac 0sx 10.5.8
The disk might not have a working OS on it.
It you have successfully run the disk utility the disk probably in full working order. I think that the OS on the disk is either missing, corrupt or not compatible with the computer you are running it on.
May 28, 2013 | Apple Leopard 10.5 Osx Mac Operating...
Movie is stuck inside and it doesn't stay on long enough to eject
there is an emergency eject but might harm disk tray ok hold eject while its on flip power switch in the back to off while still holding the eject turn it back on
Dec 02, 2010 | Sony Playstation 3 (PS3) Console
My daughter put a disk in the ps3 and it aks like there is no disk inserted and won't eject. How can I get the disk out of the playstation?
hold eject turn sytem off with switch in the back while still holding the eject button flip switch back on and it will come out THIS IS FOR EMERGENCIES ONLY MIGHT DAMAGE DISK TRAY
Nov 30, 2010 | Sony Playstation 3 (PS3) Console
I have playstation 3 model # CECHH01, a game is inside, when i power on the light goes green, then quickly goes blue then yellow and goes back to red and powers off leaving the red light blinking. What do...
well sounds like your PS3 needs to be reflowed or reballed. I would highly recomend you have a professional do the repair. as fas as having a game stuck inside the machine you can get it out in under 10 seconds by doing this.<br /> <br /> 1) turn off power switch in back of ps3<br /> 2) place finger on eject button and hold there while ps3 is off ( no red light) <br /> 3) while holding finger on the eject button turn power switch on the back of ps3 on , hold finger on eject button untill the disk ejects.<br /> 4) turn power switch off and have unit repaired or replaced. <br /> <br /> if unit is covered by warranty and you send it to sony you must get your disk out of the system as you will NOT get it back if you send it to sony. Most reputable repair shops will return your disk with the system or give it to you before they take the system in for repairs. I ALWAYS give the game disks back before a customer leaves my shop as it leaves me with less to keep track of.
Jan 04, 2010 | Sony Playstation 3 (PS3) Console
When I turn on the power to the PS2, the disk tray immediately opens. I put in a disk and close it, after 2 seconds it opens again as if I hit the eject button. The tray won't stay shut.
i would check if your eject button is stuck if it is try to pull it out a little with small plyers or its the eject sensor or finally it might also have something in the way of the tray if you dropped it on accident or something it will keep opening if something is in the way. hope this helps.
Dec 23, 2009 | Sony PlayStation 2 (PS2) Console
I cant insert a disk in my ps3 and there is not a disk in there
turn the main switch off on the back of the unit then place you finger in the eject switch now turn the main power switch on the back of the unit with out removing your finger the unit will power on now just keep your finger there for a few seconds until the blue light start blinking now take your finger off if there is a disk it will come out if the bluray drive needs to be reset it will reset by doing this
Apr 24, 2009 | Sony Playstation 3 (PS3) Console
Ps2 cd tray does not open and the eject button light flashes
This is the tray getting stuck on the PS2 shell/casing. I can fix mine as it does the same thing but I tap it one quick time after I hit the eject button and it will usually open. Don't try to pry the tray open or this will make the problem worse.
Jan 08, 2009 | Sony PlayStation 2 (PS2) Console
Ps2 disk tray wont open, power light is on, eject light is off
if the ribbon cable that goes to the lens came out its gota go back it. has a plastic tab on the top that lifts up and down to lock it in place....
If its the eject/reset button the ribbon might not be in all the way
Dec 30, 2007 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 (PS2) Console Logo
210 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
