Question about Sony Dvcam DSR-PD150 DV Digital Camcorder
How to reduce iris when shooting outdoors
When shooting outside on a sunny day how do you reduce the iris so the picture doesnt look burnt?
    Champion:
  • 221 Answers
You might also want to use the ND (neutral density) filter as outlined on p.47 of the owners manual. this filter is especially intended for use in bright sunlit conditions. it is a standard feature on broadcast quality cameras also.
Posted on Jan 14, 2010
On the left hand side of the camera is a wheel and button located right before the LCD screen and after the focus selctor. If you roll the wheel to the + you will open the iris - close the iris.. there is also a button that says 'iris' above it, what that does is auto pinpoints the light setting for you..
you could also play with the shutter speed and gain located in the back of the camera next to the battery if you have extremely dark situations or even extremely light.
Posted on Dec 11, 2009
I have a a samsung SD-173U camcorder. What settings can I use outside on a sunny day. Every time I try to use it outside, the picture doesn't come out.
Use the "Automatic" setting so it will adjust automatically indoors AND outdoors.
Thanks for using fixya!
May 28, 2011 | Samsung Cameras
Outdoor pics completely washed out Cannon S5 IS Power shot
Try going into the review menu, choose setup and then choose 'reset all' This should re-set all shooting settings to automatic and solve the problem. If that doesn't do the trick, your sensor is probably damaged - not good news - sorry
Jul 25, 2010 | Canon Cameras
Bright white exposure
This may be a ccd problem.
See this link.
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&keycode=2112&fcategoryid=221&modelid=8776
Aug 06, 2008 | Canon PowerShot A80 Digital Camera
CANON Rebel RTI Outdoor pictures are dark
learning to use light metering correctly can have its challenge.
the manual will guide you on how to set up to read light from the subject. spot metering a dark area will cause general overexposure, or a washed out look. spot metering a bright area will cause a dark image. if you are on spot meter and shoot two people standing together against a bright lit background, your meter will see between them if they are centered, and read all that bright background, setting the camera to a less sensitive combination of aperture / shutter speed, resulting in a dark image. use field averaging meter setting and be sure you are metering the subject and not the background. try shooting a wall that is fairly clear of other colors and uniform it light hitting it, you should have a correctly exposed image. since it works in other modes (at least 1, anyway) then it is unlikely you have an exposure compensation issue. that is the only other non defect issue that would cause your problem.
once you confirm that you have these settings correct and still get a dark image, its time to have it serviced.
good luck
mark
Sep 01, 2007 | Canon EOS 400D / Rebel XTi Digital Camera...
Pictures are too bright when shooting outdoors in sunlight
Have you tried changing your settings manually to outdoor? Or adjusted the aperture? You can usually find the aperture settings under the menu button. If not, try adjusting to outdoor conditions and disabling flash. And also, lower your white balance a good bit.
May 01, 2007 | Canon PowerShot SD600 Digital Camera
No pictures at all, at it's best just blury colours
got my developed film back and all I got were pictures seperated into 4 boxes with one colour a box. can you explain more can you look at the negatives and see whats on them. try a sunny sixteen rul on a sunny day with sun high in sky set camera aperture to F16 if you are using ISO100 film set the camera shutter to 1/100th ISO 200 = 1/200th etc take a picture of a stationary subject - like a brick wall whats the make and model of the camaera
Apr 13, 2007 | Lomo Action Sampler Kit Camera 35mm Point...
Picture are dark indors after i dropped camera
yes this can be repaired
the problem is with the image sensor,not with the lens as you can still take pictures outdoors
repair cost of this camera is $135.00 flat rate from kodak's authorized repair center
May 25, 2006 | Kodak EasyShare Z740 Digital Camera
Brightness
kindly provide me with contact details of your repair centre in New Delhi, India. I have fujifilm f420 finePix digital camera and facing problems inusing it.
Regards
Alok
alok.tanwar@gmail.com
09818000602
Sep 12, 2005 | Fuji FinePix F420 Digital Camera
Sony Dvcam DSR-PD150 DV Digital Camcorder Logo
115 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
