Question about Hitachi 80GB IDE Hitechi DeskStar 7K160 7200RPM 8MB HDS721680PLAT80 0Y30001 80 GB Parallel Hard Drive
When I attach my hard disk I cannot power on my PC
  • info48836 Sep 05, 2009
    I have tested jumper settings and i have tested that harddisk to 3 computers. Every where it gives same problem. I think this hard disk is short. I need a way to solve this problem because data in it is important.
    Genius:
  • Hitachi Master
  • 1,252 Answers
Check the jumper settings of the hard disk and power , bus connector
Posted on Sep 04, 2009
Disk boot failure, insert disk
Test the leads that attach to your (hard drive from the motherboard) make sure they have dust free secure connections or replace all the leads that attach to your hard drive including electrical extensions + IDE SATA and the ones that attach from your (motherboard to hard drive) if its a 40 pin flat ribbon IDE this will be the first to fail
make sure all leads that are attached to your drives dvd\cd and floppy drive have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs continue its cycle power and data to travel through every working device and have an end point so any faulty leads will end up with a computer error
hope this helps you
Apr 27, 2012 | Epson >>> IM800 DARK GRAY 733 MHZ CPU...
Have a client's laptop that powered on, a black screen comes on and the message says "cannot read the hard disk, press Ctrl Alt Delete to restart". So I took out the hard disk and tried to access...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test the leads that attach to your ((hard drive from the motherboard)) or replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your ((motherboard to hard drive))
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections needs its connections continue its cycle and to have an end so any faulty leads will end up with a computer error
hope this helps
Apr 29, 2011 | Hitachi TravelStar 5K250 250 GB SATA Hard...
Unit failed to boot and observe the followng; - No start-up display - No CMOS boot-up display - Hard disk clicking sound and OS won't start
Turn the computer off.
Disconnect the AC power supply.
Remove the battery.
Remove the disk-drive.
Reconnect the AC power supply.
Turn the computer on.
Put any "data" disk into the CD-drive.
Does it display the CMOS boot-up display?
Can you hear the PC try to spin that "data" CD, i.e., trying to "boot" from it?
If it works "better" without the disk-drive attached, the disk-drive is the problem.
Jan 11, 2011 | Toshiba Satellite A105 Notebook
My computer stopped working some time ago, and I was pretty much certain my hard disk had died (SATA), so I bought a new Hard drive (SATA) and booted my computer....the bios didn't detect the hard drive,...
ONE BAD LEAD?
try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive one bad lead will cause a computer to shut down
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Sep 18, 2010 | Packard Bell Computers & Internet
Computer will not come on
Check that no cable attached is a little loose, and make sure you press the power button hard enough, otherwise I would look at a failed power supply because as long as there is power you will get sounds or at least a green light even if the pc isnt working.
Aug 18, 2010 | Acer Aspire One AOA150-1570 Notebook PC
Disk boot failure, insert system disk and press enter -ax1200
Hardrive is gone. dear. replace it. check if there is any floppy or cd in the tray. if not replace the hdd.
Oct 01, 2009 | AcerPower 1000 - Athlon 64 3800+ 2.4 GHz...
Hard disk problem
Better to check if your Hard Disk have a power. By knowing that it is working you have to go BIOS and see it there that it is recognize as Primary or Secondary Setup. Boot Failure have the options why it won't run from the hard drive. #1 Maybe its not detected in your PC or no power, check again inside your CPU if it is properly connect. #2 No windows or any system available. #3 If all of this are not then your Hard Drive are defective.
That's is my analysis on your problem. Hope this might help you to know what is that problem for.
Aug 05, 2009 | Samsung (SP0822N) 80 GB Hard Drive
Computer will not start
Remove the hard disk and cd-rom and than start your pc.
If its working then attach the hard disk and than cd-rom respectively.
Check all the cable again.
Mar 12, 2009 | HP Computers & Internet
Hitachi ide 80G hard disk on pentium 4 pvmm2 motherboard.
no, it can handle an 80Gb. But before you do that reset first the firmware cause it helps your computer to prepare whatever plug and play devices the you may attach to it. or Upgrade your previous firmware to a higher version.
Dec 14, 2008 | Dell Vostro 1500 Notebook
Pc cant boot
Is the BIOS settings ok? Try changing the Molex power Connector or Change the power Supplies. Hope this helps
Sep 17, 2007 | Computers & Internet
Hitachi 80GB IDE Hitechi DeskStar 7K160 7200RPM 8MB HDS721680PLAT80 0Y30001 80 GB Parallel Hard Drive Logo
95 people viewed this question
Top Hitachi Computers & Internet Experts
Alun Cox
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
