Question about Brother P-Touch 1000 - Labelmaker - thermal transfer - Roll - 180 dpi x 180 dpi - up to 10 ... Printer
House do I fit the cartridge into my Brother pt1000?
How to fix brother lc 985 when ink absorber full? thanks
have you fitted a new cartridge
cant find a user manual for that online
is the plastic removable tag on the cartridge
been taken off before fitting
is the cartridge sitting in the correct position and moving and loading after shutting the casing lid
if no better
would look at more problems with the printer
May 18, 2016 | Brother Office Equipment & Supplies
"no tape" error
I found 2 helpful manuals from brother that you may want to checkout. they explain exactly how to install the cartridge:
http://www.ptouchdirect.com/ptouch/manual/PT1000.pdf
http://www.ptouchdirect.com/ptouch/manual/PT85.pdf
Feb 18, 2013 | Brother P-Touch PT-2400 Label Tape OEM...
I cannot find the slot to replace ink cartridges! Brother LC61CL
Which Brother all-in-one printer or copier do you have? The LC61CL cartridges fit MFC-255CW, MFC-290C, MFC-295CN, MFC-490CW, MFC-495CW, MFC-5490CN, MFC-5890CN, MFC-5895CW, MFC-6490CW, MFC-790CW, MFC-795CW, MFC-990CW, MFC-J410w, MFC-J615W and the DCP-165C . The cartridges could fit other printers as well.
I know that the MFC_795CW has a cover on the right hand side that you need to open when the unit is on. Then the cartridge carrier will move to the ink changing area. (For a new printer, there is a green protector in place that you need to pull out. Keep this in case you move the printer later.) This location applies for the DCP-165C copier as well.
If the unit is on but the cartridge carrier does not move to the opening of the ink cartridge cover, then something may be blocking the carrier from moving. This could be a scrap of paper or other foreign object blocking the route.
Brother has the support for most of their printers available here: http://www.brother-usa.com/Support/ . There is a specific link for just the manuals on the page as well.
More complete trouble-shooting guides are available if you search for your model from the Brother search box at the top right hand corner of the page. Go to the product details page and then see the Brother Solution Center links on the right hand side of the page.
I hope this helps.
May 05, 2011 | Brother Office Equipment & Supplies
I AM UNSURE OF HOW TO CHANGE THE FONT OR PRINT SIZE?
Here's the diagram/manual for the PT-1000.
It does a pretty good job showing how to make these changes:
I hope this helps.
Best of luck!!
Mar 04, 2011 | Brother PT-1000 Thermal Label Printer
Wanted user manual for ptouch1000 brother
The manual can be found by clicking on the below mentioned link:
Please accept the solution if the information provided has been useful.
Jul 15, 2010 | Brother Office Equipment & Supplies
My Brother LC61 Series printer does not print - printer is less than 1-yr. I purchased new ink cartridge a couple days ago, however, all of a sudden, the printer will not print.
1st question that should be asked, is was it a genuine Brother approved cartridge with the right value of filtered ink?
If not then the jets will be possibly clogged.
if you return it for repair to brother under warranty, make sure its fitted with genuine cartridges otherwise warranty is void
please rate my help++++thanks for using fixya
Apr 16, 2010 | Brother MFC-290C Printer
Ive lost my instructions to operate my P-T 1000 HELP
The following link is the instruction manual that comes with the device, http://www.scribd.com/doc/3568489/brother-PT1000
Hope this helps,
Joe
Feb 25, 2010 | Brother PT-1000 Thermal Label Printer
Cartridge? problem
If you are using or have used third party generic ink cartridges or refilled ink cartridges, the Cartridge Sensor printed circuit board may have been damaged. We have found that some third party generic ink cartridges leak onto the ink cartridge sensor circuit board causing an electrical short of the ink cartridge sensors. The damage from the leaked ink results in the machine displaying NO CARTRIDGE because the machine will no longer recognize the installed ink cartridge(s). Genuine Brother ink cartridges do not cause this issue because of the unique design developed to fit specifically in the Brother products. As long as a Brother cartridge has not been refilled, the Brother cartridge will not leak.
Jul 07, 2008 | Brother MultiFunction Center MFC-440CN...
To reset brother p-touch 1000 e-mail lmtheron@icon.co.za
Hi - You can download the manual by clicking the link underlined in blue below:
PT1000
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Jun 13, 2008 | Brother PT-1000 Thermal Label Printer
Help changin cartridge for the lc 51 series
The Brother lc-51 series cartridges fit a variety of different Brother printers.
On this Brother.com support page
you should select the printer model that you have, and download the user manual for your printer. Once you've downloaded the manual, look in the 'Routine Maintenance' section for how to change the printer cartridges.
Mar 20, 2008 | Computers & Internet
Brother P-Touch 1000 - Labelmaker - thermal transfer - Roll  - 180 dpi x 180 dpi - up to 10 ... Printer Logo
24 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
