Question about Ricoh Aficio 1035 Copier
Sc990 on Aficio 1035 - Ricoh Aficio 1035 Copier
  • 143 Answers
Software performance error The software attempted to perform an unexpected operation.
Software defective Internal parameter incorrect
Insufficient working memory When this SC occurs, the file name, address, and data will be stored in NVRAM. This information can be
checked by using SP7-403. Note the above data and the situation in which this SC occurs. Then report the data and conditions to your technical control center.
Ok, that's the "OFFICIAL" meaning, in reality, EVERY TIME I'v had this, it took a PM or at least a Developer change and a good idea to replace the Drum and Drum Cleaning Blade too, Be sure and run the setups too.
Enter the service mode.
Clear modes, 1,0,7 and hold down the Clear/Stop key. Press COPY SP on the display and enter the following info.
SP2001 = 1480V
SP2201 = 600V
SP2801 (after new developer is installed)
SP2805 (after new drum and developer is installed)
SP3001-2 (after cleaning the ID sensor and/or replacing the drum)
SP7804
SP7807
Good luck.
Posted on Sep 05, 2009
I have one Afficio 1035 Machine. Now the problem is sc990. How can i solve the problem?
Posted on Dec 17, 2009
  • 162 Answers
This can be reset pressing . (point) and # simultaneously by more than 10 seconds, this reset and recharges the software. The copy print a report of error.
If changing cylinder blade, developer and fitting does not disappear… tries changing the hard disk. Good luck…
Posted on Sep 10, 2009
4 Suggested Answers
  • 34 Answers
SOURCE: ricoh aficio 1035
It needs a firmware update or re -write.
Posted on Feb 18, 2008
Bubbabear64
  • 2794 Answers
SOURCE: how do i set aficio 1035 to factory default
SC352 Indicates ID Sensor/Pattern edge detect Error 3. If its a color machine, then it's a Magenta TD ensor failure.
Usually If you need to change the developer roller you should change the developer as well. Once that is done, then you go into service mode and calibrate the developer and initialize the TD sensor.
Did you change the developer?
Posted on Aug 02, 2008
  • 3 Answers
SOURCE: sc990
sc 202 mpc 1500 and af 1075 sc 995
Posted on Jul 10, 2010
My ricoh aficio shows sc990 how can i fix this problem?
first you check pm life of drum kit if finished than replace it
second clean laser unit (ld) you will discover that this code will never shows again.
Aug 12, 2012 | Ricoh Aficio 1035 Copier
Sc990
sc990 is the software problem. replace the HDD of the machine and it should be fine. don't format the hard drive as it might result in laser error code.
Oct 22, 2010 | Ricoh Aficio 1035 Copier
Sc990
Best solution is probably to update firmware.
Oct 12, 2010 | Ricoh Aficio 1035 Copier
I have A problem of SC990 in the ricoh aficio 2035/45 and also I get light copies and over tonning problem.
The light copies and overtoning is probably caused by the developer going bad. Do you have a service contract on your copier? It's likely time for a whole PM (preventive maintenance) procedure.
The sc990 is probably caused by the copier's condition as well. Once you have the PM done (or at least replace the developer, rebuild the photoconductor unit, and clean or rebuild the transfer unit) the sc990 codes should go away along with the poor copy quality.
Jun 19, 2010 | Ricoh Aficio 1035 Copier
SC990
It is often related to the drum, it is a bit of a 'rogue' code, relating to software i believe, but Drum/PCR is usually the cause, and a good place to start.
Jun 16, 2010 | Ricoh Aficio 1035 Copier
I have ricoh 1035 & eror sc990. without hdd ,i can print and copy one side and by hdd i have error. i do . & # toghter for 10 second for soft reset and nothing happend. in code menu: 5801 - 2109 -...
If you use Katun OPC drum in your machine and is work more 80000 copies you need to replace the OPC drum and the drum cleaning blade.After replace the drum perform the process comtrol and the SC990 disipaire.Whenever use other genuine parts and not original Ricoh parts appair SC codes to refer HDD parts.100% this method is working.
Nov 21, 2009 | Ricoh Aficio 1035 Copier
Do hard disk formatting can help the problem SC990?
No
Thew problem is software performance error
The software makes an unexpected operation.
•Defective software
•Defective controller
•Software error
Do this:
1.Turn the main switch off and on.
2.Reinstall the controller and/or engine main firmware.
Nov 07, 2009 | Ricoh Aficio 1035 Copier
Ricoh 1045 sc990
Generally changing the cylinder (blade and developer) Initialize td and id sensor usually it is solved. If it is not thus it proves the following thing: press point and numeral (enter) simultaneously for more than 10 seconds until this clear the service call. If the problem persists can be the hard disk, change.
Jul 31, 2009 | Ricoh Aficio 1035 Copier
Af2045 always shows sc 990
if you are getting the sc990 code, you will need to have someone come out and do preventative maintenance (PM) on the machine. the 990 code has to do with the drum quality, and the only way to fix it is to, at least, have the drum unit rebulit.
Apr 02, 2009 | Ricoh Aficio 1035 Copier
Ricoh Aficio 1035 Copier Logo
508 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
