Please check the broil function if it is still working, if it is then the back element has gone out. CLICK HERE
If the broiler is not working either then write back and we can go from there.
If you have verified the oven gets up to set temp, and the broiler works - your clock needs to be replaced. (AKA ECU)
The clock is the electronic controller that tells the oven what to do based on the position of the knobs, and sensors.
That is HERE
Thanks for using FixYa
Electric oven will not heat: Things to check- The screw in fuses, they are usually the 30 amp fuses for the oven. Next is the clock assembly, often these clocks will have the words "push for manual" or "turn for manual", this will put the clock back into the normal operating mode rather than the automatic mode. Next, you may have to remove the power and check for any burnt wires. If all checks ok, you will have to test the selector switch and oven control.
About oven light not working check out this
The interior oven light in most ovens is a standard 40 watt appliance bulb. Often, to change the bulb, you first need to remove a shield or glass dome. If the bulb isn't burned out, the problem may be with the switch on the oven door frame. If the switch works poorly, intermittently, or not at all, you need to replace it.
The oven door won't close
If your oven door has gotten bent or warped (maybe you rested something heavy on it…), you need to remove the door, disassemble it, and straighten it. You can lift most oven doors off of their hinges by opening the door several inches to its first "stop," and lifting the entire door straight up.
If the hinges have become worn, damaged, or bent, you probably need to replace them. We recommend replacing both hinges at the same time, to prevent uneven wear of the undamaged hinge.
An indicator light doesn't work correctly
When an indicator light has stopped working, you may be able to replace just the bulb--but you usually have to replace the entire light assembly. Alternatively, there could be a problem with your burner sensor (stuck open or closed) or your indicator light circuit.
click this link for more help
http://www.applianceaid.com/elecrange.html
thanks please do rate the solution.thank you for using fixya.keep updated.
My clock has none of this wording. Clock has 3 knobs. Center on labeled "set" turns clockwise to set timer and counterclockwise to set time. Right knob labeled stop time turns to set stop time and push to cancel. Left knob labeled "enter" turns to set start time and push to, I think, enter. How do I check the clock? Also, what do the 3 microswitches that are actuated by the lock lever do and what are their normal states (open/closed)?
Eveything works except for clean function.
