Question about GE Dryers
The top surface of my 12 year old dryer is getting
The top surface of my 12 year old electric dryer is getting very hot. I vacuumed accumulated lint from the inside of the unit. I also disconnected the unit from the outside exhaust vent and ran for about 20 minutes and the surface did not get hot. Could the problem be that the exterior vent pipe needs to be replaced or is it likely that the overheating is a sign of some problem within the dryer.
  • GE Master
  • 2,533 Answers
If it cooled down when you removed the exhaust line that tells me your line could be plugged or crimped. The end where it goes outside may be plugged. Vacuuming may not do the trick. I really don't like to use a cheap plastic line as they have a habit of buckling and then they plug up. If the dryer is running hot you could have a fire so I would change the hose if that's the problem.
Posted on Dec 22, 2016
I vacuumed the exhaust line which opened the line to vent the dryer
Posted on Sep 05, 2009
Re miele t4222c tumble dryer When it's turned on it runs for about 5 seconds then trips the electric.... Any advice please
Martin,
Caution: never enter an appliance internals with power applied!!!
You can die if you ignore this!!! You are dealing with 220 Volts!!!
My first check would be to open the unit & check for accumulated lint. The motor may be starved for cooling air (happened to me with my son's dryer). If so, get the vacuum & clean it thoroughly. Then find out why lint accumulated inside so it will not happen again.
My next check would be the dryer exhaust pipe. You can chase out accumulated lint with a simple brush tool from the corner hardware store and an electric drill. (You should do this yearly anyway).
If everything looks well inside, you need to decide if it is the heater element or the motor that is tripping the breaker. With power unplugged, disconnect the heating coil & tape the hot lead(s) with electrical tape.
Reconnect power & turn the unit on. If it trips the breaker, the motor is your problem. If it runs, the heating coil is your problem.
If it is the motor, order a replacement online.
If it is the heating coil, inspect it to insure it has not decided to short out on warming up (and tripping the breaker.) You could easily enough replace the coil online if needed, but simple mechanical actions may suffice.
When it runs, reassemble & replace the unit.
Good Luck,
Pete
Sep 20, 2015 | Miele Dryers
Tip
How to Fix Dryer Lint Problems
<span>Instructions</span> Things You'll Need: <ul> <li> <span>Vacuum cleaner</span> </li> <li> <span>Screwdriver</span> </li> <li> <span>Electric leaf blower</span> </li></ul> <ol> <li> Remove the lint trap from the dryer and peel off the accumulated fuzz.<br /> </li> <li> Vacuum the top of the dryer, the floor nearby and underneath for lint at least once a week. When you remove the lint trap, tiny particles fly into the air and settle nearby. Behind and underneath the dryer are favorite hiding places for dryer lint.<br /> </li> <li> Disconnect the vent tube from the rear of the dryer and inspect it every month. Dryer lint accumulates more easily in flexible plastic tubes than rigid aluminum ones, because curves halt the lint's path.<br /> </li> <li> Clean the vent tube leading to the wall annually. As for the tube leading to the exterior, a trick that sometimes works is aiming an electric leaf blower down the tube. The leaf blower can expel the lint through the exhaust on the exterior. Before using the leaf blower, check that all duct work is fastened securely.<br /> </li> <li> Unscrew and remove the back panel on the dryer, if you're mechanically inclined. Particles that escaped the lint trap can accumulate inside the dryer cabinet, so vacuum this area.<br /> </li></ol>
on Jan 04, 2011 | Dryers
The dryer is causing the breaker to trip
check the entire venting system . possibly full of lint .
Dec 21, 2017 | Whirlpool LER4634J Electric Dryer
Burning smell when on.
You could have an issue with lint that has accumulated surrounding the heat element, motor, etc., or there may be some faulty wiring. Contact an appliance service company.
Apr 14, 2010 | Whirlpool GEW9200L Electric Dryer
Dryer doesn't get hot
unplug dryer,take bottom panel off and take out the lint filter,remove the blower wheel duct and clean out the lint,while you have the cover off read out the thermal fuse located on top of the blower wheel housing,remove one of the wires when you read it out, if the air isn't moving outside it will pop the fuse.vac out the inside of dryer and if you have a shop vac switch it on blow and blow off all the lint off of the motor,you should do this once a year so you don't have a fire.if the fuse is good,read out the ignitor,sensor and gas coils.when you get it running go outside and make sure the air is blowing out strong,if it isn't you could have a blocked vent line,if it's a long run use a leaf blower to blow out the vent line.
Nov 28, 2009 | Kenmore Dryers
Whirlpool dryer not drying
your dryer is likely clogged up with lint .. that would be after the lint filter .. the pipe that carries the hot air out is usually completely clogged after that long .. it and the dryer itself (down inside) has to be cleaned about once a year to keep it tip top .. hopefully you can find someone that can take it apart and clean everythiing .. that should get you back to like new performance .. or you could call a few handymen to see what they would charge to clean the lint from your dryer and stack .. or if you are handy there is a special big brush with a string attached .. you pull that thru the stack to clean it .. use a vacuum cleaner to get inside the dryer vent (you can see in the vent when you take the hose off .. excessive lint buildup not only greatly reduces your dryers efficiency but is a fire hazzard as well ..
Aug 12, 2009 | Whirlpool LER5636P Electric Dryer
Very hot to touch on top
Sounds like you have a clogged vent hose or clogged duct work leading to the outside of the home. Make sure you have no obstructions in the exhaust system including a functioning flap on the outside wall cap.
Jan 03, 2009 | Frigidaire GLER341A Electric Dryer
Squeeky Noise
Raise top by prying lose clips on front, remove 2 screws holding front in place (inside cabinet) and disconnect wirings, removed front (panel with door) panel, removed 4 screws holding inside front panel in and lifted it out, released tensioner from belt, lifted out drum out of unit, vacuumed accumulated lint from machine, motor, wiring, checked and greased drum rollers and tension pulley, cleaned drum edge from accumulated roller debris using automotive brake rotor cleaner, reintsalled drum, applied automotive belt dressing to belt and reassembled. Working for now. If reoccurs I will replace drum rollers and tension pulley.
Nov 22, 2008 | Maytag MDE4806 Electric Dryer
Back panel removal
it is..remove bottom panel ..after unplugging from wall..remove lint screen next remove 3 screws holding the lint screen/blower housing in place ..clean out housing clean blower wheel with long brush or a long arm clean lint from base and on element housing on right side especially on top of the housing..that is the most important location if lint gets too thick on element housing ..fire hazard....ckd vent behind dryer and to outside if you find a large amount of lint .that is good indication of a restricted vent
Aug 22, 2008 | Kenmore Elite HE4 Electric Dryer
Whirlpool Gas Dryer - Model LGB6200KQ1 Serial # mm2105815 Heat comes and goes. Can heat fine for a few loads then stops. Then starts again. Any ideas
Sounds like it is running Hot, Clean you venting out and make sure the weather hood outside is not blocked.
Vacuum out the lint filter area.
Your dryer also may have worn seals, how old is it? 10 to 12 years running a load a day average? it may be time for a new dryer or rebuild yours.
Jul 10, 2008 | Whirlpool Dryers
Dryers Logo
108 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
