Question about Jensen VM9411 Car Video Player
On switching on, my VM9411 has a volume of 38 locked on, i turn it down to 10 and switch off and on restart, it goes back to 38. i have tried the on vol setting procedure but it does not work.
    Problem Solver:
  • 8 Answers
Try turning it down to 10 pushing in the volume button until it beeps and then turn it off and back on and it should work
Posted on Nov 20, 2009
How to restart my tablet without turning it on because I forgot my password?
Look in your tablet instruction book for a procedure called 'hard reset' or a location for a small hole on the edge or back of the tablet where you can push in something non-conductive, like a toothpick to press a hidden reset switch. Without having a make and model for your tablet, it is hard to determine what exactly to do because each make and model is different. You talk about pressing the power and low volume buttons- are you holding them both in simultaneously for 10 seconds? This might be the reset procedure for your tablet, but that is not clear. One last thing to try is to hold in the power button for 10 seconds and see if you get a power off screen. If you get this, try powering off the tablet and then restarting. Also make sure the keyboard isn't on caps lock when you type your password.
Jan 03, 2015 | Tagital Taital TM 7" Android 4.0 4B MID...
How can I get the screen to rotate over to the correct position?
You might have your Orientation Lock on. If you are using iOS 7 or 8, swipe up from the bottom and disable Orientation Lock (http://cdn.osxdaily.com/wp-content/uploads/2013/10/stop-screen-rotation-orientation-lock-ios-7.jpg)
Alternately, the switch on the side of your iPad might be set to Lock Rotation, so go to Settings > General and see if Use Side Switch To: is set to Lock Rotation. This would mean that whenever the switch above the volume controls is down, the orientation is locked.
Sep 30, 2014 | Apple iPad Tablets & eReaders
My China Mobile Vell-com Model V222 Has been Lock When I switch On first screen was open lock code input this mobile full screen touch only 3 key are there 1 call and 2 menu 3 switch off/onWhat Can I
try power home and volume down, all at the same time. when turn's on leave fingers on power and volume then count to 10 ( seconds) and take your fingers off power and volume, should have a menu come up and use the volume button to move down to factory reset and press home button. now this will wipe all you have on the phone but as you dont know what the password is this is your only choice. hope this helps.
Mar 24, 2014 | Cell Phones
Toshiba (Model : 36A43) - volume goes down automatically
I am having same problem on 32 inch same problem. After playing with board with no results,I tried front buttons and found that if I held the power button in ever so slighItly as not to turn it off, it fixed problem which is the micro on/off switch, I removed the switch and used the remote and everything is back to normal, I am about to insall a used micro switch after I finish typing this but I am sure this will clear up volume problen and menu going crazy problem if not I will just leave micro switch out and use the remote, and I will get back to this board only if that micro switch still causes the problem, so if I don't post in next hour the problem is fixed and I'm more than glad to help.
Jun 18, 2008 | Toshiba 32AF43 32" TV
Volume
the volume control needs to be cleaned. this control is a step switch basicly. and the switch contacts are not making proper contact. cleaning this requires dis-assembly and desoldering so if you are inclined to do this work happy fixing if not it shouldn't cost much to fix.
Jan 19, 2008 | Aiwa NSX-A115 Shelf System
Volume control problem
Ok my head unit is stuck on 10 with my valume and it wont change how can I fix that
Nov 25, 2007 | Dual XDVD8181 Car Video Player
Volume knob
Normal Aiwa compact shelf units use what is called a jog switch for the volume. Usually you can tell the difference if when you you turn the volume up or down. It goes a short distance and seems to spring back. In this case there are two momentary contact switches. One for up one for down. With a plastic lever on the back of the knob that bumps the approriate switch whether turning down or up. If the lever is broken it will bump up against one but not the other. If it is broken plastic you know how good gluing plastic goes it never seems to hold.
Aug 02, 2006 | Aiwa NSX-A777 Shelf System
Car Audio & Video Logo
105 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
