Question about Acer AL1916W 19" LCD Monitor
BLACK MONITOR...INPUT NOT SUPPORTED
IN THE MIDDLE OF DOING SOMETHING MONITOR GOES BLACK WITH THE EXCEPTION OF THE MESSAGE ABOVE 'INPUT NOT SUPPORTED' ...I HAVE TO THEN SHUT OFF THE POWER TO REBOOT AND START BACK UP!
  • 256 Answers
This is the resolution problem. Pls reduce the resolution . Right click any where on the desktop and click on properties there. a popup appears just choose Setting there . there you will find the option of Screen Resolution .Just Slide the pointer toward less litlle till your problem resolve.
Posted on Sep 04, 2009
    Scholar:
  • 88 Answers
Your Monitor cable is lose connected or it is not properly fix ,
Also check it with stabilizer, plug the monitor wire and power on your screen ,
If it helps you kindly comments on it
When i shutdown my computer after that when lcd goes black then at that time a message shown on the black screen that "no input signal" and also glows little bit light with this message continuously.
Your monitor may have an option to set it as "manual" or "auto". If set in manual, you will have to turn off the monitor power switch each time. If it has the "auto" setting , it should shut off or "go to sleep" when it detects no input signal.
Oct 18, 2014 | Samsung SyncMaster 713BM 17" LCD Monitor
When i shutdown my computer after that when lcd goes black then at that time a message shown on the black screen that "no input signal" and also glows little bit light with this message continuously. in...
It usually depends on the monitor type and/or whether the monitor power cable is connected directly to the wall-socket or to the PC casing first. Both might explain the different behaviour. If they're all connected the same way, it's just the type of monitor that doesn't go into 'standby' mode automatically when there is no signal. You could post the exact make and model monitor and/or contact their customer support, but it's more likely not a configurable option ...
Oct 17, 2014 | Samsung SyncMaster 713BM 17" LCD Monitor
Why is my dell inspiron 531s stuck on black screen with input not supported message?
Start pc in safe mode and try to change resolution.
Then update the graphics driver.
May 06, 2014 | Dell Inspiron 531s Desktop Computer
My monitor has an "input
Out of range typically means that the resolution in windows is set higher then the monitor can support. You will need to get into windows to remedy this.
You can do this one of two ways. You can try to hook up to a more advanced monitor and do it.
OR
If you have video at first, you can press F8 as the computer is starting to boot up. this will open the advanced booting options menu. Select Run in VGA mode OR you can try Safe mode. Once you are in there you can change the resolution by Right clicking on the desktop and selecting Properties or Personalize. Then under display settings you can adjust the screen resolution using the slider bar. Set it to something like 1024x768 and then save exit and reboot normally. Once in there you can look up the max screen resolution your monitor supports and set it accordingly.
Hope this helps. Please vote if so.
Feb 01, 2011 | Computers & Internet
Black screen with message about no input signal
might be something wrong with your monitor's data cable
May 21, 2009 | Sony SDM-HS95P/B 19" LCD Monitor
I have a hp desktop model a1268c computer. after an update my computer srcreen says ''input not supported'' and the screen is blank. When the computer boots the F1 button ''setup'' works but the F10 button...
> You needs to configure your scree resolutions and other parameters.
> May be frequency rate doesn't supported by your old Monitor.
> Just attach your desktop with different monitor and change parameter to lowest frequency range. (60 HZ or lowest with 640*480 resolution)
May 15, 2009 | Computers & Internet
"Input Not Supported" message on monitor at boot
Sounds to me like the input has gone out of the boundaries the monitor supports. IE the refresh rate is too high frequency (normally 60 to 72 Hertz for LCD's) or the screen resolution has been set too high.
Go into safe mode and set it back to 1024 X 768 at a frequency of 60 Hz, once back into windows proper you can try higher resolutions and change your refresh, if the screen goes black or displays a message "Out of Bounds" or similar it should revert after 15 seconds if left alone.
Have fun
Apr 27, 2009 | Envision EN-9250 19" Flat Panel LCD...
Monitor Message = "No Signal"
see i use Compaq too
they don't generally except other modes
did u try that monitor with other pc where it worked
u should install proper monitor software ... u will found it from the cd given wit Ur monitor
Apr 24, 2008 | Mag Innovision lt456s 14" Flat Panel LCD...
Monitor Blacks out 'input not supported'
i think the probelem is monitor resolution out of range . try the system resolution changes and connect the monitor then the issue is solved 80% or other problem is monitor hardware damages cheack the whole hardware components
Nov 04, 2006 | Acer AL1717 17" LCD Monitor
Acer AL1916W 19" LCD Monitor Logo
104 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
