Question about Bissell 7901-1 ProHeat Scotchgard Upright Wet/Dry Vacuum
Bissell Pro Heat 7901 will spay through hose but not the floor and red flow indicator will not spin. So we took the housing off and after unclogging a hose running to the hearter, my husband unhooked the hose that goes to the flow indicator, blew in it and it started spinning. Put the deep cleaner back together, tried to use it and nothing. What else can we try? Can't afford to put it in the shop right now. Thanks in advance.
  • melinda97 Sep 04, 2009
    ok here is an update....
    I took the housing off and finally so water when I pressed the trigger. But now water only comes out of the left side of the machine , so how do I clean the right side? ( for cleaning the floor)
    Problem Solver:
  • 16 Answers
I borrowed my friends bissell to clean my carpet. It's the 7901. He brought it over and told me that it only sprayed out of the attachment hose. He said he couldn't figure out what was wrong. I'm no vacuum technician but, I am a mechnic. I decided to open her up and check it out. After about two hours it was back together and working. The reason I replied to your e-mail was because we have the same problem. I couldn't find an answer to this problem on this site so I will tell you what I found and hopefully it will help you. In removing the cover where the red heating light is, there is the heating unit for the water. In my case it is silver and it will get very hot so be careful. Notice that there is two water hoses connected to it. I removed this heater and found one of the connectors where the water hose goes was clogged. I took the back off the heater and used my air compressor to blow out the connector, and sure enough something flew out. Hope this helps. brian.small@bobstgroup.com
Posted on Sep 13, 2009
Testimonial: "thanks, my husband took a look at the heater and I indeed had a clogged hose."
My Bissell Pro Heat 2X will not release water or
its probably a solenoid that controls the flow to the floor, take it to a bissell repair center, because its not an easy fix.
Jul 02, 2009 | Bissell 1697-7 Powersteamer Pro Deluxe...
Bissell Proheat Pro-Tech #7901 will not spray any liquid to the carpet and red cross indicator is not turning,but comes out of attactments
The 7920 is a 220 volt version of the 7901. I found a shop in New Zealand of all places that has service manuals on line. They are sort of picture books, but using them has saved me a lot of money as it makes repairing much easier. Here's the link you'll need. Good luck. If you need any more help, just add a comment to your post and it will go to my e-mail and let me know. The heads you clean are just the outlet spray heads when they get gunky.
http://newzealand.bissell.com/images/IncludeContent/Service_Center_Help/Upright_Deep_Cleaner_Repair_Guide.pdf
Looks like you already have the USELESS Bissell advice list!
Jun 03, 2009 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissell 7901 proheat service manual
I took apart the cleaner to clean the parts that were dirty and I can't seem to put the roller back in. Any suggestions
Aug 14, 2008 | Bissell 7901-1 ProHeat Scotchgard Upright...
No spray
pump part number is 2107181, the diverter valve # 2136988. You can Bissell and they can tell you who may have parts near you, or you maybe able to order thru Bissell.com. Before you took it apart, were you getting water to spray out of the hose. If you were the the heater is plugged and won't allow water to spray out the bottom.
Feb 26, 2008 | Bissell 7920 ProHeat Pro-Tech Upright...
No spray
You can to bissell.com and order them thru them, or they can tell you where the nearest place is for parts by putting in your zip code.
Feb 23, 2008 | Bissell 7901-1 ProHeat Scotchgard Upright...
How much soap and how much water do I put in the Bissell pro heat?
You are supposed to buy the Bissell soap. On the bottle depending which cleaner you need. The directions are on the bottle. Please do not use house hold cleaners because you can cause serious damage to the vacuum.
Go here, this pg. shows the 7901-1 click the user guide pdf & print the instruction if you choose:
http://www.bissell.com/Bottom_Menu/Product_Search.aspx?Criteria=7901-1+ProHeat+
Good cleaning!
Please vote..........
Jan 16, 2008 | Bissell 7901-1 ProHeat Scotchgard Upright...
How to replace pump for 7901 bissell pro heat steam cleaner
unplug unit first
take six screws out of housing.
lift of housing.
you can see pump at front of machine.
four screws hold pump in.
make sure all tubes are routed correctly.replace housing,
make sure no tubes are trapped
Jun 04, 2007 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissell 7901-1 ProHeat Scotchgard Upright Wet/Dry Vacuum Logo
301 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
