Broken anteana screw post
Antenna post in back of tv broke off. Can I fix this myself or is it too technical for the home handyman to fix?
  • john2fire Dec 08, 2007
    Toshiba model #CF30D50 and is there a site to obtain info on how to remove and replace the main board?
    Novelist:
    Champion:
  • 232 Answers
John, the rf connector is not replaceable, have to replace tuner, this involves removing the main board, unsoldering old tuner and replace with new tuner and solder it in. Not rocket scientry if you have the equipment and a working knowledge of how to un-solder & re-solder in the part. You didn`t give make & model number so can`t give you price or part number, if you decide you can do this repair, send me make& model number & I`ll look up part number for you, BMW Rider
Posted on Dec 08, 2007
  • Larry Eastman
    Larry Eastman Dec 08, 2007
    John, bad news my friend, no longer available, does the set have AV input jacks on the back ? you can by-pass the tv`s tuner by using the tuner in a vcr and coming out of the vcr with 3 rca cables, do you know what I`m talking about? If not e-mail me back and I`ll explain better, remember your tv has to have video in & 2 audio in`s on the back so check that first, BMW Rider
Replace antenna
Hi John,here's a link on removing your power antenna.
Jun 06, 2013 | 2000 Nissan Pathfinder
I have a cobra 29 and noone can here me. I have an 18 inch antenna and brand new coax. The mount is on the mirror and the antenna wire goes right through the door to the radio I get rf output power fail...
throw that short antenna in the garbage you are wasting time trying to talk on it. as a rule of thumb your cb antenna should be no shorter than 36" try a longer antenna and see if that solves your problem it should
Apr 04, 2013 | Radio Communications
Hello, my 25" Magnovox (#mt2501c)
Tv fell off about 3 feets or more?Yes,turn on the tv see if u getting any power to the unit?Might have broken main PCB board too.If unit still have power,check see if tv get statics screen have colors shaded in red or mutiples colors,mean the tv CRT(tv tube) yoke is dead and damages scrambles radiation.Or the tv getting power but have high pitch sqeeling noises or rattles noises,tv have the CRT-(tv tube) is crack by the neck or broken totally.CRT have damages problems or dead tv is worthless,beacause of CRT(tv tube) is dead,not fixable even that antena connector input is replaced.
Feb 17, 2011 | Philips Magnavox MT2501C 25" TV
THE ANTENNA IN HAS BROKEN OFF I UNSCREWED THE BACK OF THE TV AND IT IS A SILVER BOX ...IS IT TO BE REPLACED OR IS THERE ANOTHER WAY TO REPAIR THE ANTENNA IN SCREW PART
The temporary fix for this issue never lasts and it will soon break again. I have seen some shops charge over 100 dollars to get the TV working again, but later the part breaks off again. The threaded part that is broke is from the tuner that is on the main board.
The only real way to fix the problem you have is to purchase a new main board.
Next time use a "slip" connecter (not a threaded one) on the back of the TV for the cable connection.
Oct 06, 2010 | Televison & Video
I have a Janome New Home machine and I was using my buttonhole lever and it seem to get stuck and now I think I pushed it too much and it is off track or I broke it. Can I fix this myself? It won't even go...
Sorry, I didn't see your second posting with the model number.
I'm not sure which screw you removed, but the buttonhole lever mechanism requires the service manual to reset the position.
Jul 19, 2009 | Sewing Machines
My antenna broke, i purchased new antenna but when I tried to install new antenna the old antenna fell inside of radiio, I took out all the screws but still cannot get radio apart
On the back panel, there is a black decal located near the center. Warm this decal with a hair dryer (warm it, don't get it hot)Slip a knife blade under the right side and lift it up. Remove the hidden screw under the decal, and the the other five and the back will come off. replace the FM antenna and you are good to go. I had the same problem. mcarmich
Jun 13, 2009 | Eton FR300 AM/FM/Weather/TV Radio
Antenna/cable socket
yes it can be repair..You would have to take it to a repair center so they can repair it for you..
Apr 24, 2009 | Panasonic PV-C2541 25 in. TV/VCR Combo
Broken Antenna Port
If you have already identified where the connection was on the board you will have to access the board to be able to solder back to the points where the old connector was. Once you have identified the two solder points (One should go to ground and the other if you can with the tv on touch it and see if a picture tries to come in or get rid of the snow). Then buy a matching transformer from radio shack or Home Depot, Lowes. Normally this would go on the outside antenna. But you want to take it and clip and strip the ends that have the forks. Solder this to the board, one to ground and the other to the point that would have been center on the old broken piece. This will have a 72 ohm or a connection that your antenna will connect to.
Jan 11, 2009 | Toshiba TP50G60 50" Rear Projection...
Antenna in broken
it can be fixed, it is called a tuner, if you can solder, you can order a new tuner from the manufacturer, and unsolder the old one , and solder on the new one
Jan 08, 2009 | Televison & Video
Televison & Video Logo
131 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
