I have a fuji xerox document centre 186 copier with Cover A error message giving continous bips, i checked the cover its tightly closed but continues giving the same error.
  • 19,396 Answers
There is not much you can do, apart ensuring that the problem is not just temporary, and that cover is well closed, and eventually calling Xerox in case the error does not clear.
First unplug the copier power cord.
While copier is off try opening a closing the cover, eventually blow the cover with air and ensure there is no fragment of paper or foreign object in there.
If the problem is still there on startup, then cover sensor or wiring may be faulty. In that case ring Xerox using the number listed on copier codumentation.
Posted on Sep 04, 2009
Fuji xerox document centre 350 manual to download?
The User's Guide for the Document Centre 350 is available from the product support page. There are two files (one for the scanner and one for the printer). See http://onlinesupport.fujixerox.com/processDriverForm.do?ctry_code=TW&lang_code=en&d_lang=en&corp_pid=DC350&rts=null&model=Document+Centre+350&type_id=5&oslist=Windows+95&lang_list=en and the Documentation tab. The drivers are available for supported OS versions on the Drivers tab.
I hope this helps.
Jun 27, 2013 | Office Equipment & Supplies
I have a Fuji Xerox 525a colour laser printer which is giving a phantom paper jam message (error message indicates paper jam in cover E, but it is clear) What can I do to clear this message as it...
I beleive there are only two paper sensors for that machine.
1- in the tray there is a paper empty sensor which hangs down,
make sure you take out the tray and look for any pieces of paper stuck.
2- open right door and look as if your looking inside to where the paper is supposed to end up. The sensor is in that black unit, is there any paper there, can you see a black lever, if you pull on it gently and let go does it snap back in place?
Jun 21, 2008 | Fuji Office Equipment & Supplies
Unable to close Cover E of Fuji Xerox c525a
For anyone smashing their head against the wall about this problem I finally found out what the issue is in regards to the C525A Cover E not closing.
If you run into this issue you need to look inside the printer where Cover E is, at the very bottom of this is a piece which looks like the rest of the printer but actually freely moves up and down on a swivel. Put it in the up position and as you go to close it it'll fall down again but this time Cover E will close. Not banging it shut or punching it, it all clicks back into place nicely.
Nov 19, 2011 | Xerox DocuPrint C525A Laser Printer
Wat is an LSU error on a phaser 3200 MFP
Change the toner cartridge , i have many units phaser3200 and this is one of the problem , but only if the toner cartridge is very old and many time refilled , if not , change the Laser unit .
  1. Remove a misfed document if the copier displays a message reading "Document Jam." Lift up the document feeder cover and turn the roller to remove an Exit Misfed document. Lower the document feeder back into place and feed the document through again. If the document is jammed on the Input side, open the cover and gently pull the misfed document to the right and out of the feeder.
  2. Pull out the paper tray and lift the tray to release it from the copier if the copier displays a message reading "Paper Jam O." Remove the jammed document, and open and close the side panel of the copier to clear the error message.
  3. Unplug the power cord and plug it back in again if the copier displays a message reading "Fuser Error, Open Heat Error, Heating Error and Overheat." If the problem persists, call for a service.
  4. Remove the toner cartridge and shake it from side to side if the copier displays a message reading "No Developer Cartridge." If this does not do the trick, you may need to replace the cartridge. Pull the release latch to open the side cover, and open the front cover. Twist the cartridge locking-lever upwards and remove the toner cartridge. Insert the new cartridge and lock the lever into place. Shut the front cover and the side cover.
  5. Power off the unit and power it on again if the copier displays a message reading "LSU Error." A problem has occurred with the Laser Scanning Unit. If the problem persists, call for a service.
Jan 04, 2011 | Xerox Phaser 3200MFP/N Laser Printer
For document centre c250 fuji xerox: error code 062-380 or error code 062-386
Defective IIt/IPS board. Is very expensive. Call you local Xerox service number and ask them for part number 160K99811 and how much it would cost to get it fixed.
Aug 04, 2010 | Xerox CopyCentre C128 Black and White...
My Xerox Document Centre 265ST just stopped working and a message: Copier is not available Printer Fault please call for assistance I cannot access tools or anything else.
turn it off completely unplug it. open up all doors and trays....turn it on with everything open if you still get the error you are going to have to call in a tech if it starts up . start closing things till you get to when that errror comes up then repost and ill look up an answer for you. i work for xerox
Dec 14, 2009 | Xerox Document Centre 265ST Printer
Document feeder jam
if you open the cover where you feed in the documents to be copied, look on the back side of that cover and you should see a little black plastic piece that dangles from the cover. Make sure first of all that is is there, and it moves freely. This makes contact with a sensor when the cover is closed. And of course make sure the cover is closed tightly. Let me know if I can be of any further help.
John
Nov 23, 2007 | Office Equipment & Supplies
Document Cover Open
I had the same problem with mine. Lift the top scanner, and check the hinges on the left. That error message means that the little black sensor on the left next to the hinges is not meeting flat with the unit when closed. Hold the sensor in for a few seconds, and your printer will start working properly.
Oct 11, 2007 | Brother MFC-8840D All-In-One Laser Printer
k24674
jasbo
jasbo
