Question about SMC Barricade 7004 Router
SMC7004VBR PART NO. 751.0113
I tried to download firmware many times from their SMC website inputing part number and other options many times but says no firmware.
Please give me a link for latest working firmware and driver for this SMC7004VBR .Barricadeā„¢
http://www.smc.com/index.cfm?event=downloads.doSearchCriteria&localeCode=EN_USA&productCategory=1&modelNumber=924&partNumber=0&downloadType=1&knowsPartNumber=false
How do you download the usb to ethernet adapter software?
Here is the SMC driver website. You can search for the model number. Or, they also have a link to old products if yours is old enough.
SMC
Sep 02, 2014 | SMC USB to Ethernet 10/100 Mbps Network...
I don't have the installation disc for the SMC EZ Connect g SMCWUSB-G 802.11g Wireless Adapter. Is there any website that I may get it from?
Try this site to get the drivers for the SMCWUSB-G: http://www.smc.com/index.cfm?event=downloads.doSearchCriteria&localeCode=EN_USA&productCategory=5&modelNumber=1545&partNumber=0&downloadType=1&knowsPartNumber=false . You will need the part number of your adapter. Then choose your OS and click the blue button with the right arrow.
The manual and firmware are also available. See http://www.smc.com/index.cfm?event=viewProduct&cid=5&scid=31&localeCode=EN_USA&pid=1545 . The links for support and documentation are on the right hand side of the page.
I hope this helps.
Feb 22, 2013 | SMC EZ Connect g SMCWUSB-G (SMCWUSBG)...
Its not playing videos
First step --
Download a PDF copy of the Sansa View manual. Here's a link:
http://www.google.com/search?client=ubuntu&channel=fs&q=sansa+view+manual&ie=utf-8&oe=utf-8
There are two likely reasons for the video not to work;
1) The software that runs your Sansa View, known as 'firmware', is outdated;
2) Your video requires conversion before you download it.
1) Firmware update?
Download a copy of the Sansa Firmware Updater from here:
http://kb.sandisk.com/app/answers/detail/a_id/4431
Start it on your computer, and follow the directions to update your Sansa View's firmware, if needed.
2) Download and install the Sansa Media Converter (SMC) from the same link above.
--Plug in your Sansa View to the computer, and run the SMC.
--Follow the directions to select your video. SMC processes one video at a time for upload into your Sansa player.
Another possibility - Try loading video from Windows Media Player 11;
From the manual, page 17--
"Your Sansa View player supports MPEG-4 Simple Profile up to VGA, H.264 Baseline Profile up to VGA, and WMV up to QVGA video formats.
That means you can simply drag and drop these files into the Video folder if you are using Windows Media Player 11."
Hopefully, that will help you get your videos in!
Nov 03, 2011 | SanDisk Sansa View 8GB MP3 Player - Black
My ipod touch wont connect
There are firmware updates available for this router available at the SMC Support Web Site.
Follow the link to "Firmware" under "Support" on the left-hand side. Apparently there are two different part numbers associated with the SMC2804WBR model number. Check the label on the router to determine which part number is yours.
Download the firmware update and apply the update according to the user manual, which is also available at the link above.
If this does not resolve the issue, then this router may be outdated and unable to support your iPod Touch.
Dec 28, 2010 | SMC Wireless Cable Router...
The default password isnt correct, cant log in. I reseted the device many times, and unpluged for hours/days but the default password still doesnt set back...so i cant use the device because with default...
According to SMC the default password which is case sensitive is: smcadmin you enter that into the SMC web interface found by typing 192.168.2.1 into Internet Explorer's address bar.
The full manual is here,a nd their support site is here
If this helped you then please help me and vote, thank you
Oct 12, 2009 | SMC Barricade SMC7004VBR (SMC7004VBR-CA)...
Can't setup my router
You should be able to download drivers and firmware from the smc site here.
Also see the FAQ or knowledge base articles to help you with installation questions.
A great site for help with all sorts of broadband and or wireless issues is this one. It takes a little reading to find the right section, perhaps, but a wealth of reliable info there. (You'll see there's an SMC forum, but read the FAQs too.)
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Aug 29, 2009 | SMC Barricade 7004 Router
I inserted a blank disk into my mini mac. It did not come up on my desktop. I can't discharge it....How?
When you install Toast, one of the install questions is whether you want Toast to recognize blank CD's or DVD's when they are inserted. If this was set to yes, then I believe this could override the OS acknowledgement and Toast will take over.
One way to check is to open up Disk Utility (Applications > Utilities > Disk Utility) once you insert a blank disc, if you see the blank disc, try using Disk Utility to mount it, than it will should show on your desktop.
If you want the OS to mount the disc all the time, check your Toast settings.
Check both the preferences in Toast but also under System Prefs-->CDs and DVDs...there is an option there to choose what the computer should do when a blank DVD is inserted. Probably Toast set that System Pref to "Open Toast" based on your install configuration.
The Finder Pref you refer to only determines if CDs and DVDs recognized by the Finder show up on the Desktop. This is only a display preference, not really a determination of whether the Finder is the primary app that will recognize a blank disc. The CDs and DVDs panel in the System Preferences is where you need to go.
if that doesnt solve ur issue... i wud recommend u to reset ur pram and smc.....
Resetting PRAM and NVRAM
  1. Shut down the computer.
  2. Locate the following keys on the keyboard: Command, Option, P, and R. You will need to hold these keys down simultaneously in step 4.
  3. Turn on the computer.
  4. Press and hold the Command-Option-P-R keys. You must press this key combination before the gray screen appears.
  5. Hold the keys down until the computer restarts and you hear the startup sound for the second time.
  6. Release the keys.
Your computer's PRAM and the NVRAM are reset to the default values. The clock settings may be reset to a default date on some models.
Resetting PMU on PowerBook or iBook computers In some troubleshooting situations, if resetting PRAM does not resolve an issue, resetting the PMU may be the next appropriate step. For information on when this is appropriate and for instructions on how to reset the PMU in your PowerBook computer, see Resetting PowerBook and iBook Power Management Unit (PMU).
Additional Information Resetting NVRAM in Open Firmware If your computer is Open Firmware-based (Power PC) and you are unable to reset NVRAM as described above, you may alternatively reset the NVRAM and Open Firmware settings using the steps in the Solution section of Message “To continue booting, type 'mac-boot' and press return”.
In some cases, an Open Firmware-based computer may not respond to the keyboard commands noted above, and may not allow starting up into Open Firmware by pressing and holding the Command, Option, O, and F keys during startup. If you are unable to get to an Open Firmware prompt (and your computer supports doing so), try powering on the computer with the power button held down continuously—as if you were doing a firmware update. This should force the computer into Open Firmware, allowing the steps in the article noted above to be used.
Contents of PRAM Some Macintosh computers may not have all the settings described below. For Mac OS X information, refer to Mac OS X: What's Stored in PRAM?
  • Status of AppleTalk
  • Serial Port Configuration and Port definition
  • Alarm clock setting
  • Application font
  • Serial printer location
  • Autokey rate
  • Autokey delay
  • Speaker volume
  • Attention (beep) sound
  • Double-click time
  • Caret blink time (insertion point rate)
  • Mouse scaling (mouse speed)
  • Startup disk
  • Menu blink count
  • Monitor depth
  • 32-bit addressing
  • Virtual memory
  • RAM disk
  • Disk cache
with respect to ur SMC...
The System Management Controller is an integrated circuit (computer chip) that is on the logic board of the computer. As the name implies, it is responsible for power management of the computer. It controls backlighting, hard disk spin down, sleep and wake, some charging aspects, trackpad control, and some input/output as it relates to the computer sleeping.
Over time, the settings in the System Management Controller may become unusable, which can result in operational anomalies with the computer. Examples include not turning on, not waking from sleep, not charging the battery, or not recognizing the AC Adapter, among others.
Resetting the SMC is not intended for resolution of a stall or situation in which the computer is unresponsive. An SMC reset should not be necessary except as a last resort in cases where a hardware issue with the power management system is suspected. Performing an SMC reset resets the hardware power management functions.
For most situations, a restart is sufficient. If the computer has stopped responding, try each one of these steps, one by one. Test between each step to see if it has worked. If one step works, don't worry about the next one. You should only reset the SMC if you've tried all of the steps listed here and the computer still isn't working.
  1. Force Quit (Option-Command-Escape)
  2. Restart (Control-Command-Power)
  3. Force Shut Down (press the power button for 10 seconds)
Only perform an SMC reset on the computer if none of the above steps resolved the situation. If this is the case, see below for instructions on locating the reset button or key combination for your model of computer. If your computer is earlier than the models listed here, see "Resetting PowerBook and iBook Power Management Unit (PMU)" or "PowerBook: Resetting Power Management Unit (PMU)".
MacBook (13 inch, Late 2008), MacBook Pro (15-inch, Early 2008), and MacBook Pro (17-inch, Early 2008)
  1. If the computer is on, turn it off.
  2. Disconnect the AC adapter and remove the computer's battery.
  3. Press and hold the power button for 5 seconds and then release the button.
  4. Reconnect the battery and AC Adapter.
  5. Press the power button to restart the computer
Note: Starting with MacBook Pro (Late 2008) and MacBook (Late 2008) models, you may instead use the reset method for MacBook Air (below) to reset the SMC. All earlier models of MacBook and MacBook Pro must use the method described above, which involves removing the battery.
MacBook Air and MacBook Pro (Late 2008 and later)
  1. If the computer is on, turn it off by choosing Shutdown from the Apple () menu.
  2. Connect the power adapter to a working power source.
  3. On the built-in keyboard, press (left) Shift-Control-Option along with the power button once.
  4. Wait 5 seconds and press the power button to start the computer.
Note: You must use the keys on the left side of the built-in keyboard.
You should only perform an SMC reset when the MacBook Air or MacBook Pro (17-inch, Early 2009) has been properly shutdown. This prevents issues from occurring to the file system.
While the power adapter does not need to be connected to reset the SMC, it may be necessary in situations where the battery needs charging or if the computer has been without power for an extended period of time. You can also visually check the SMC reset by observing the LED on the adapter. It will momentarily turn off as the SMC resets.
Jul 16, 2009 | Computers & Internet
Can I use SMCWBR14-G2 firmware to update my SMCWBR14-G's firmware
SMCWBR14-G Firmware V1.00.28
http://www.smc.com/index.cfm?event=downloads.doSearchCriteria&localeCode=EN_HUN&productCategory=1&modelNumber=1386&partNumber=3083&downloadType=2&knowsPartNumber=false
Jan 02, 2009 | SMC Barricade g SMCWBR14-G (662698582192)...
SMC Barricade 7004 Router Logo
223 people viewed this question
Top SMC Computers & Internet Experts
Prashant M
Prashant M
J John
Are you a SMC Computer and Internet Expert? Answer questions, earn points and help others
