Question about Frigidaire FRT17G4B Top Freezer Refrigerator
Water leaks from the freezer onto the top shelf of the refrigerator
  • 4,066 Answers
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Posted on Sep 04, 2009
Why is it leaking water onto top shelf
Most modern fridges have an automatic defrost that works by draining into a sort of funnel above the back of the top shelf.
The funnel is connected through the back of the fridge to a rubber drain tube that goes down the outside of the back to a heated evaporation tray under the fridge,
The hose and/or funnel can get clogged with disgusting yucky stuff, and the water spills over the top of the funnel onto the top shelf.
The fix is to clean all the bits. It's usually no big deal to take apart.
I have resorted to blowing through the tube from the bottom end and then cleaning up the mess, and brushing my teeth. Quite revolting but, that's the price I paid to become an expert.
Cheerfuls
Nov 20, 2015 | Refrigerators
Water leaking from freezer onto top shelf of frig. has to be wiped once a day.
You probably have a blocked or frozen drain hole in the freezer. This means that the water formed during defrost can't drain down to the evaporator tray beneath the fridge and instead goes through overflow holes into the refrigerator.
I posted about how I solved this problem in another post:
http://www.fixya.com/support/t8706684-water_leaking_inside_refrigerator
Mar 11, 2011 | Kenmore 64802 Top Freezer Refrigerator
I have a whirlpool imperial refrigerator; freezer on top; with icemaker....water is leaking from the freezer section down onto top shelf in refrigerator, near back, any help??
Hello and Welcome to FixYa!
Actually the leaking water is from the evaporator coil unit.... Under normal conditions,Self-defrost refrigerators usually dispose the water generated during the defrost cycle through a tube or channel that directs the water a pan (Known as Drip pan), commonly below the refrigerator unit....
The channel or tube is clogged and the water is leaking to the refrigerator unit, so you need to clear that contamination....Once the blockage is removed, the generated water will move through that channel/tube directly to the drip pan and there will no water on the top shelf in the refrigerator compartment. This is all you need to do....
Best of Luck,
Please do Rate the solution, if you feel that this helps you,
Concerned.
Aug 10, 2010 | Whirlpool Refrigerators
TOP FREEZER REFRIGERATOR WITHOUT ICEMAKER LEAKS ONTO TOP SHELF AND UNDER BOTTOM DRAWER
the condensate drain hose is blocked.
remove the plastic rear cover in the freezer; locate the drain opening;
it's about 1/2 inch in diameter; it drains into a pan at the bottom of the refrigerator. using a funnel and, a small pan, pour hot water through the blocked hose until water flows into the drain pan again.
remove the condensate pan pour the water out and, reinstall the pan.
Jul 02, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Water is leaking onto top shelf of fridge. It is a top freezer.
Sounds like you have a frozen drain in the freezer. You can remove the back panel of the freezer and take a turkey baster and run hot water down the drain line to clear it. Once its cleared you will want to dump an additional cup of water down to make sure that its clear. This will stop the defrost tray from overflowing when the unit goes into defrost. This is where the water is coming from.
Hope this helps _MJ_
Feb 16, 2010 | KitchenAid KSRA25ILSS Side by Side...
Water is leaking into top shelf of Refrigerator - Whirlpool Gold
the drain in the freezer is clog make sure the drain from the freezer is clean all the way to the pan next to the compressor . you need to open the back wall of your freezer for that ( the inside wall) clean with buster (water pump)the drain is in the bottom middle of the freeze.
Sep 10, 2009 | Whirlpool ET1FTKXK Top Freezer...
Kenmore elite - Water dripping from freezer to refrigerator
Your refrigerator has a defrost drain blockage behind the evaporator in your your freezer compartment. Some models like yours have leak in the turns as the water leaves the freezer. I recommend that you unplug and remove the cover to the evaporator and check the defrost condensate tray below the evaporator. A wet vacuum cleaner and poring a solution with clorox in the drain will help you clean locate the leak and where the blockage may be downline.. I do have the manual on yours and can help you solve this. Some times this is a factory defect and I can help you solve the freezing drain problem. Let me know, Sea Breeze
http://fixitnow.com/wp/2009/05/26/the-permanent-cure-for-repeatedly-freezing-condensate-drains-in-whirlpool-roper-kitchenaid-top-mount-refrigerators/
http://servicepartstec.blogspot.com/
Jul 01, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Water dripping from freezer onto top shelf of fridge with ice buildup back of freezer
the defroster isn't close enough to the drain to be effective. remove the back wall of the inside of the freezer, remove the excess ice. clear out the ice from the drain using hot water and a turkey baster. there is a kit from whirlpool that uses a piece of metal and a screw around the defrost rod, but I found out that a piece of 14 gauge solid core wire with the insulation stripped off works great too. stick the stripped wire into the drain, 2 to 3 inches, and wrap the rest around the defrost rod.
Jun 02, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Hi, I can help you. The drain is plugged in the freezer section. Could I get the model #?
Some models need an after market drain heat strip added.
Please let me know and I can get you through tis.
Thanks
Vic
May 30, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Frigidaire FRT17G4B Top Freezer Refrigerator Logo
204 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
