Question about Toshiba 52HM95 52" HDTV Projection Television
Toshiba model 62HM95 DLP. There is a fan noise clearly audible even when 12 feet away while tv is off. Are there any solutions? Can I order a fan and replace it, is it a sensor that is bad, poor design by toshiba get used to it??
  • 35 Answers
It is just a noisy fan.
yes you can order from tosh and if you are able it is an easy fit. Just make sure you unplug the tv from the mains
Posted on Sep 04, 2009
Testimonial: "thank you. I at least know i can replace the fan. I didnt get an answer as to why the tv needs a fan when its off. but, thanks for the answer anyway"
Replace fan, http://www.cwc-group.com/afb1212lr00.html
Posted on Dec 22, 2011
Where are toshiba dlp 62hm95 fuses
I looked at the power board online and I do not see any glass fuses.
I only saw the pico fuses which you unsolder and resolder.
Here's an image of the power board: http://tvpartsandmore.com/wp-content/uploads/imported/46HM95-TOSHIBA-23764257-POWER-SUPPLY-UNIT-46HM95-52HM95-62HM15A-62HM95-62HMX95-191208846050.jpg
What is the problem with this TV?
www.aaatvservice.com
Aug 15, 2014 | Toshiba 62HM95 62" DLP HDTV
My Toshiba 62HM95 62 in. HDTV DLP TV won't turn on...the green and red lights under the power button remain on and the red light flashes. How do I fix this?
Most likely, you need to replace your DLP bulb. The one that comes with your TV will last a few years max. The replacements seem to only last about a year. D:
Dec 08, 2010 | Toshiba 62HM95 62" DLP HDTV
Toshiba model number 62HM95 62' makes grinding noise
SORRY, This is from the authorized Toshiba parts center:
"The color wheel, lamp fan, lamp fan holder are parts of the LIGHT ENGINE only." It means the wheel is not sold separately and there is not even listed in the breakdown for the set a part number.
A replacement light engine (optical light engine) retails for 456.00 list and is sold on an exchange basis only.
SD TECH
May 13, 2010 | Toshiba 62HM95 62" HDTV
No picture, siren type noise as restarting
My Toshiba dlp 62hm116 was used for 3 months then stored for 2 years, I turned it on yesterday and it makes a loud grinding noise which I think is probably from the exhaust fan area and the picture is black except white at both vertical sides. It worked fine the last time I used it 2 years ago. Any ideas?
Jan 13, 2010 | Toshiba 62HM95 62" DLP HDTV
Humming noise
The light enigine shouldn't be that difficult to replace if you have a decent amount of time and are moderately mechanically inclined. You can order the original Toshiba replacement light engine for this model (62HM95) from a major Toshiba parts distributor at the link below:
Toshiba 62HM95 Replacement Part Light Engine / Optical Block
Apr 01, 2009 | Toshiba 62HM95 62" HDTV
No solution found on your site. My 62" Toshiba DLP makes an extremely loud chopping noise when on HD channels using a satelite service. (Happened on Dish and Suddenlink) No sound except for the chopping....
Have you contacted your satelite provider? Have you any other HD sources to try, A Playstation 3, a blue-ray disc player or even using the TV's terrestrial HD tuning system can tell you if its the TV or the Satelite.
michtech
Feb 18, 2009 | Toshiba 62HM95 62" HDTV
Light Engine for Toshiba 62HM95
Hello thuertam,
I would first suggest that you spend $19.00 for the schematic and service manual for this device. In the service manual you will see the factory approved instructions on how to remove the light engine. This is the best course of action, because even though some here can give you excellent instructions, the warranty on the parts might be voided if you install incorrectly. In addition if you have the service manual it can guide you through steps that might be left out with secondhand guidance.
A good sight to get schematics frrom is http://www.servicemanuals.net and http://www.manualsparadise.com
I hope this helps
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Feb 12, 2009 | Toshiba 62HM95 62" DLP HDTV
Toshiba DLP fan noise (52hmx95)
i constantly hear complaints about fan noise in dlptvs if you sit in front of your computer you will hear the same noise even in the next room there is no solution to the fan noise problem this product has a huge cage fan and a second and third three inch fans in it.... more than the samsung product it can be noticeable if the tv is on hard surfaces ie wood floors ,inthe corner, glass top etc the vents on the back of the tv allow for proper cooling of the lamp at shutoff so it doesnt shatter the tube its kinda like annealing glass its designed to extend the life of the lamp .... which im sure youve priced call toshiba and tell them your lamp is bad right now and get a new one for an emergency ( warranty if you can do it ) they are also improved this product is known to have short bulb life sometimes the zinging noise you hear is indicative of a bad color wheel in the light engine which would require replacement ( not cheap) toshiba will not piece out the color wheel assembly individually
Nov 30, 2006 | Toshiba 62HM95 62" HDTV
Toshiba 52HM95 52" HDTV Projection Television Logo
474 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
