Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
F 13 fault code
I have this fault anf this is the 2nd time in 4 yrs It got something to do with the thermostat I have british gas homecare though and an engineer comes out and fix's it, well worth the money I would recommend appliance homecare to all as its great when ur appliances fail and you dont have a big bill to pay out all at once
  • 5,081 Answers
You will be able to fix this, it will take about 2 hours.Buy two thermostats for £10 from a 'local' repair shop.These components look rather like cylindrical bits of plastic wearing tin hats but one is twice the size of the other, the larger being about 2 cm in diameter, and they DON'T look identical. The part numbers (for my WD860) are: HPT 1605 160 and HPT 1604 802.
1. You’ll need to use a combination of finesse and brut force to get the lid off of the machine. It is secured by two screws at the rear but has troublesome plastic hooks inside, half way down either side, that stop the lid from riding up at the front. The process is to remove the screws and then pull back and up to ‘unhook’ the internal brittle plastic hooks. I found this scary and difficult, cracking sounds were off putting and I did break to tips of the plastic hooks a little but they still seem to work ok. Be careful and wiggle it gently from side to side is the only advice I can offer.
2. Once inside it gets a bit easier. You should be able to see a metal snail-shaped object bolted to the top of the drum with various electrical connections – this is the dryer and within it are the two thermostats. What you’ve got to do is remove/unplug all the electrical connections from the top dryer, of course, make a diagram first as you’ll need to put them all back after. You then need to unbolt/unscrew the top half of the dryer and remove this from the machine – this is another fiddley bit and I was lucky again here to have a very small ratchet socket set which made the hard to get to bolts/screws accessible. Note: some of the screws are the Torx type (imagine a more complex Phillips’s type screw). You’ll need to have a Torx type screw driver head that’ll fit the small socket tool to undo these.
3. Once the top of the dryer unit is off, you just need to remove the thermostats – one is fixed in by screws on the outside of the dryer top and the other is fixed in by screws on the inside. Screw in the replacement thermostats, then clean off the fluff and burnt fluff from both halves of the dryer and you’re there – put the machine back together.
Posted on Sep 04, 2009
I have a WD640 which is flashing F13, i need to know the part numbers for the thermostats for this model?
Posted on Oct 27, 2009
Hi. I went to autozone and diagnosed with code p0172 on my 2005 Lexus GX470. I have vsc trac, vsc off, anti skid, and check engine light on. The lights come on for about 100 miles and goes off for same...
You own a high end luxury vehicle as do I, 2005 ES330, the dealership is the best place to get Lexus problems fixed. With my own vehicle, I had a thermostat fault code come up, and like you it would reset itself and come back. The code said it was the thermostat and I queried it with my tyre guy. He also said it is a thermostat code. I said but it isn't overheating. He told me that the computers in Lexus are so clever they are actually looking for the water to reach x degrees in x minutes. He replaced the thermostat, the fault never came back. Anyway back to your P0172 Error code.
https://www.autocodes.com/p0172_lexus.html
Possible causes
Faulty front heated oxygen sensor
Ignition misfiring
Faulty fuel injectors
Exhaust gas leaks
Incorrect fuel pressure
Faulty Mass Air Flow (MAF) sensor
The first thing I would try is that stuff that you add to your fuel to clean the injectors.
Read more: https://www.autocodes.com/p0172_lexus.html
Pull codes P0172/P0175, need help diagnoising - ClubLexus - Lexus ...
https://www.clublexus.com > ... > IS Models > IS - 2nd Gen (2006-2013)Jul 6, 2013 - IS - 2nd Gen (2006-2013) - Pull codes P0172/P0175, need help diagnoising - My check engine light, VSC, and traction light all lit up yesterday. I pulled ... Title: 2GR-FSE ENGINE CONTROL SYSTEM: SFI SYSTEM: P0171,P0172,P0174,P0175; System Too Lean (Bank 1); 2006 MY IS350 [08/2005 - ] DTC System too rich ( Bank 1 & Bank 2 )
26 Aug 2017
P0172 code to rich please help!
1 Apr 2017
Traction control = code P0172 and P175??
19 Jul 2014
Check engine light Code P0172
13 Jun 2004
More results from www.clublexus.com
Dirty Mass Air Flow Sensor P0171, P0172, P0174 Codes - YouTube
? 8:09
https://www.youtube.com/watch?v=LJSx2cDoFn4
Jun 4, 2014 - Uploaded by RomanAutomotive
A common cause for lean condition codes is simply a dirty Mass Air Flow Sensor. Since I have been testing ...
code p0172 on my 2005 Lexus GX470 Google Search
Mar 13, 2018 | Lexus Cars & Trucks
My Xenon high efficiency furnace has a red blinking led light that blinks 4 times and my furnace will not light. What could be the problem?
Gas furnace fault or error codes for common furnaces - Gray ...
www.grayfurnaceman.com/-ifc-failure-codes.html
Each color will also flash a specific number of times to signify a specific error. ... 4 redcolored flashes may be signaling that the "high-limit" switch might be open. ... 3 green colored flashes on your furnace has the same meaning as 2 green colored flashes. ....If a system problem occurs, a blinking LED shows a fault code.Missing: xenon
7 Tips and Tricks to repair your Furnace DIY - YouTube
? 13:25
https://www.youtube.com/watch?v=rAtcvPqUsBA
Dec 18, 2012 - Uploaded by JRESHOW .
Flash sequence codes 1 through 11 are as follows: LED will turn "on" ... 4 RED FLASHES: This indicates that the main limit switchhas opened ... This no-light condition occurred 3 times (2 retries) during .... My furnace trane xe80 is only flashing once my manual says something about flame being locked out ...Missing: xenon ‎efficiency
Nov 21, 2015 | Heating & Cooling
How to programme rc2 british gas thermostat
The British Gas RC2 is a re-badged Drayton Digistat and I managed to find installation and operating manuals for that at www.gasapplianceguide.co.uk
Go to the section 'Lost your instructions' and look for Drayton 2F & 3F Digistats (earlier type) for a downloadable copy of the manuals.
Following them got my RC2 up and running though it was a bit fiddly at times.
Hope this helps.
Oct 27, 2011 | Honeywell Programmable Thermostat Heater
Just bought a 93 Seville STS about a month ago, which ran great the first few weeks. But now, when i'm driving, it stalls & sputs like it's running out of gas even though the tank is full. When...
GM and Cadillacs Code 13 means Oxygen sensor circuit fault.
Its possible that your need to replace the sensor if have long time using.
Hope this helps.
Oct 12, 2011 | 1993 Cadillac Seville
Gas dryer 4 yrs young and won't heat. Drum turns.
First thing to check is the ignitor underneath the drum. (You have to open the panel to see it) It should glow shortly after the dryer starts, then the flame starts and the ignitor shuts off. If the ignitor does not glow then it or the thermostat is bad. If the ignitor is glowing but the gas does not light then the flame sensor may have to be replaced. If the gas ignites but does not stay on either the flame sensor or the coils are at fault.
See also: http://home.howstuffworks.com/how-to-repair-a-dryer.htm
Dec 04, 2009 | Televison & Video
Fidge freezer is not working properly
Get british gas homecare cover for heating and appliances, don't tell 'em the freezer isn't working, then a month later report it as a fault, they'll fix it. Unscrupulous i know but what can ya do? Otherwise get a hotpoint engineer, sign up for their maintenance plan.
Apr 04, 2009 | Hotpoint FFA70 Bottom Freezer Refrigerator
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
261 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
