Question about Gigabyte Computers & Internet
After psu burned out , can't boot computer with
After Antec 1000W PSU burned out , can't boot computer with replaced Termaltake 1200W PSU. On start up CPU fan spin for few seconds then stop. Everything seemed to run normaly (case fans,GPU,DVD). Doesn.t react on restart and power off, HDD led is on all the time.
XP-64
MOBO Gigabyte GA-X38-DQ6
Intel Core 2 Extreme QX6850
GPU Quadro FX 4600
HDD Seagate Barracuda ES.2 1TB
    Problem Solver:
  • 12 Answers
You might Have a Short on your Mobo, switch around your Jumper Config, check for any metal material touching any traces :]
hope this helped!
(try reseting stuff aswell, when things vibrate they move IE: chip creep)
Posted on Sep 04, 2009
    Sniper:
  • 70 Answers
See your cpu fan connector, weather it is connected properly. to check wether psu is working properly, short the black n green wires present in the psu's mother board connetor by using a single strand wire, and switch on. if the fan rotates there is no probs with the the psu. then u will have to replace the motherboard
Cooler Master 1000w Silent Pro M not compatible with MSI MS-7548 (Aspen) motherboard?
http://www.coolermaster-usa.com/product.php?product_id=2949
So you're using the same CPU 4+4 Pin x2 power cable on both rigs?
(One of them)
Yes, I see it's a modular cable design, and the CPU 4+4 Pin x2 power cable, can be used as a single 4-pin ATX +12 Volt power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#eps4plus4
ALL Yellow wires are 12 Volt (DC) wires.
ALL Black wires are Ground wires.
ALL 12 Volt wires go to ONE single 12 Volt power rail, in the Power Supply, BUT; there is nothing saying an individual Yellow wire may be bad.
This is why I wondered if you are using the SAME power cable CONNECTOR. Same power cable.
Yes?
Then suggest it has something to do with the Active PFC circuit.
http://www.hardwaresecrets.com/article/Anatomy-of-Switching-Power-Supplies/327/6
Not aware of any setting to change in BIOS Setup utility - Power.
BUT, I do not know everything! lol!
IMHO there is no reason it will not work, unless as said; something to do with the Active PFC circuit.
From here let's hope someone who really knows what is going on, will post.
Regards,
joecoolvette
Dec 10, 2012 | Computers & Internet
My pc is shutting down and I can't wake it up without shutting down the power from power supply. The Antec 300 tower has two blue lights- the top light starts blinking when it has shut down and I
sounds like a power supply problem
Test your PSU power supply unit or replace it if your power supply units fan is not working your PSU is faulty
http://pcsupport.about.com/od/toolsofthetrade/f/powersupplytest.htm
One bad lead can cause a computer to continue on a cycle of restarting or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive power and data cables IDE SATA
the leads from your MOTHERBOARD TO YOUR HARD DRIVE make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
hope this helps
Oct 13, 2012 | Antec Computers & Internet
LEDs on motherboard light up but computer won't start
It still may be dead. Go here and get a PSU tester:
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=-1&IsNodeId=1&Description=psu%20tester&bop=And&Order=REVIEWS&PageSize=20
Apr 24, 2012 | Antec : True430 430W P4 ATX Power Supply...
Computer will not start. No fans, hard drive or monitor motion at all. But, a green light on my motherboard blinks.
Out university has hhad a failure rate on antec 450w psu of 40-50% over 4 years (total number of pc:s with this psu was approx. 300). Check your motherboard with a known-to-be-good power supply.
Feb 17, 2011 | Antec Phantom 500 500W ATX Power Supply...
Turn on the computer nothing happen then smell burning from the power supply! turned off right away.
That power supply is probably dead. try your motherboard witha known-to-be-good power supply to determine if your system has survived. IN my experience the failrate for antec sp450 watt psu is close to 40% over 4 years (300 pc:s at university), so there is a high probability that your psu is unrecoverable.
Feb 13, 2011 | Antec SP-400 400-Watt Power Supply
5VSB IS MISSINIG FROM MOTHERBOARD CONECTOR . COMPUTER WILL NOT BOOT WHEN POWER SWITCH ON FRONT PANEL IDEPRESSED . NEED A SCHEMATIC AND COMPONENT DIAGRAM FOR THIS UNIT .
specs are here
http://www.antec.com/specs/SP500_spe.html
This includes 5VSB
There is more info here
http://www.newegg.com/Product/Product.aspx?Item=N82E16817103937
the ATX spec and 20+4 connector pinout (wich locates 5VSB got you) can be found in the Wikipedia article (section 3 in http://en.wikipedia.org/wiki/ATX#ATX_power_supply_revisions has pin out details for ATX rev 2.1).
If your psu is missing 5VSB it is defective and should be returned to manufacturer or retailer if within warranty period. See testing psu articles also.
Jan 19, 2011 | Antec SmartPower SP-500 (ASKU37152)...
Cooling fan for antec power supply pp 303xp does not come on when computer is switched on. Is this a replaceable item or do I have to buy a new power supply?
I THINK I REMEMBER reading that Antec had introduced a feature on some of their psu s where essentially the fan(s) were thermally controlled - if the psu was not working very hard it remained cool and the fan remained off but as the psu got warm with additional load it gradually increased fan speed. Perhaps this the issue you are seeing and nothing is wrong ?
PSU's are generally difficult to open and contain few accessible parts. some you can actually change the fan. I don't know about yours though.
Jan 04, 2011 | Antec PP-303XP 300WATTS ATX12V ATX POWER...
Re: PSU Antec NEO ECO 520C 520W RT This power supply was purchased through Newegg.com on 5 August 2010. It was installed into an Antec 200 Case in the same month. It has operated flawlessly until 1...
I agree with you about the power supply being faulty. Unfortunately FixYa is not affiliated with Antec nor sells or service any computer components.
You need to contact the supplier who sold you the power supply or contact Antec.
Nov 09, 2010 | Antec Computers & Internet
I replaced my power supply with a new Antec 650
Let give it a try.
Turn off your computer and unplug it from main supply. Remove the battery for cmos bios. wait half an hour. insert battery again and reset the cmos through jumpers. Plug the main supply and start your computer.
May be it can help you.
Sep 07, 2009 | Antec 650W EarthWatts ATX Power Supply 80...
Psu shut down
99% TIME IT IS A FAULTY FAN GOING OUT.
REPLACING THE FAN INSIDE THE POWER SUPPLY WILL RESOLVE THE PROBLEM.
P/S ARE CHEAP, JUST BUY A NEW ONE OOR REPLACE WITH ONE YOU HAVE ON HAND
CANDYMANGANDY
Jan 27, 2009 | Antec Solution SL400 Power Supply
Open Questions:
Computers & Internet Logo
212 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Tony
Matthew Spark
Matthew Spark
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
