Question about Refrigerators
Water collecting in bottom of ariston fridge
Water collecting in bottom of ariston fridge/freezer ,fridge compartment
  • 4,066 Answers
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Posted on Sep 04, 2009
Water collects in refrigerator which is below freezer
use air from bottom of fridge, but you will have to clear top drain eventually
May 04, 2012 | Maytag MTB2176HR Top Freezer Refrigerator
Water from defrosting leaks into the bottom of the freezer and freezes into a solid sheet of ice, which I chip out every 1 to 2 weeks. Kenmore bottom freezer refrigerator Model 795.65002400.
If water leaks inside your refrigerator
(and it WILL, at some point) you can fix
it yourself.
In the good old models, one had to defrost the
fridge every few months manually.
In the recent models, the fridge defrosts automatically,
once or twice a day, and the water is supposed to drain
down a long drain tube into a pan located at the bottom of
the fridge. This collected water in the pan evaporates
by the heat under the fridge.
Now the drain tube can get clogged, by food debris and/or
ice. Thus when the water cannot drip through the drain tube
the water drips inside the fridge.
The drain tube is located behind the fridge, which is pretty
easy to take it out and clean. However usually the clog is
not in the long tube but in the connector assembly located
in the backside of the fridge that leads to the long drain tube.
To get to the connector assemble, you need to unscrew and
take out the back panel of the freezer compartment. You would
see the evaporator coil and a tray under the coil where the water
is supposed to drip through. If you find the tray completely frozen
with ice, let it melt off. To speed up melting, you may blow
hot air via a hair dryer. Once the ice is clear, you should see
a drain hole in the middle of the tray. This could be clogged,
which needs to be unclogged.
Next unscrew and open the thermostat control assembly located
in the inside of the back of the refrigerator compartment just above
the light bulb fixture. Once you take the take the cover off (you will
also have to take the knobs out) you will see a small tray cup about
2" x 2" x 1/2" into which water from the top freezer compartment
drain hole is supposed to drain. Pull out the tray cup, and if clogged,
unclog it, clean it and put it back.
To check if the drain works ok, pour some water on the tray
under the evaporator coil (top freezer compartment) and see if it
immediately drains into the tray located at the bottom of the fridge
at the floor level. If it does, you got it; and you can assemble things
back in the reverse order you took the pieces apart.
Needless to say, use a vacuum cleaner with a long suction tube to clean
out all the collected mess under the fridge. No matter how good
your housekeeping is, the bottom of the fridge will be full of dust.
Good luck and hope this helps
Aug 01, 2010 | Kenmore 65212 Bottom Freezer Refrigerator
How to replace seal on the freezer door
  • Take food out of freezer
  • Take rack out
  • Take out any ice cube racks
  • Remove ice accumulated in the bottom of the compartment (I used a hammer)
  • Unscrew the back panel inside the freezer compartment
  • You won't be able to remove the panel right away because of the plastic duct is mated to the bottom of the freezer compartment.
  • Lift the panel up to unmate the duct and the bottom, and pull the top end of the panel toward you. Don't pull too hard because there are electrical wires attached to it.
  • Disconnect the wires and remove the panel / duct.
  • I saw an accumulation of ice and a hole.
  • Remove whatever ice you can.
  • Pour boiling water into the hole to remove ice inside the hole.
  • You'll know you've succeeded when water runs easily down the hole.
  • The water should collect underneath the fridge - there is a grille that you can remove (Just pull) and you'll see a pan where the water is collecting.
I just did this so I'm not sure if it will happen again ...
Good luck
Jul 29, 2010 | Hotpoint RFA60 Bottom Freezer Refrigerator
Water collects in bottom of freezer, then it runs out in the floor after ice has filled the bottom of the freezer. I have a frig with water and ice in the door. The ice maker is working fine, but the water...
there is a chance that the bottle that holds your water in the fridge compartment.could be broken or a line maybe disconnected this would cause water to leak in the fridge compartment.this bottle is designed to hold the water and get it cold before dispensing to your glass
Sep 16, 2009 | Refrigerators
Water collecting in bottom of fridge
you have a blocked drain there should be a small cup on the back wall top of the fridge that can be taken out and cleaned or the bottom of the freezer
Jul 06, 2009 | Refrigerators
Water under crispers in my fridge
If the freezer is on top then empty out the freezer and remove the bottom and back liner of the freezer compartment usually phillips screws. In the back you will see the freezer coils along with a defrost element. Below these two items u will see a drip tray that collects water from the coils on defrost cycle, in the center of the pan will be a drain hole that connects to a hose that leads to a pan under the refrigerator.Normally the water is collected there and evaporated. The hole in the tray in the freezer is clogged. Thaw it and clean it until you can pour water in it and it goes to the pan down below. please rate me
Jan 13, 2009 | Refrigerators
STANDING WATER ON TOP SHELF
Jan 12, 2009 | Whirlpool ET1FTKXK Top Freezer...
Water drains from freezer compartment into refridgerator
Jan 09, 2009 | Refrigerators
Ariston fridge freezer
hi smyvilla
on some fridge freezers there is a channel which is designed to take condensation from the fridge out through a small hole at the bottom of the back wall of the fridge check this hasnt got blocked or iced over, if the unit is a few years old it is possible that there has been some evaporation or leakage of the coolant mixture, that may be whats on your floor, the pump can therefore no longer pressurise the mixture sufficiently to cause it to remain cold,
Oct 25, 2008 | Refrigerators
Refrigerators Logo
360 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
