Question about Garden
My briggs and stratton engine keeps cutting out ,i have keep prining the the little button after every couple of minutes,thanks
  • 143 Answers
I dont know what type of carb. you have but it needs cleaning and if it has diaphrams renew them. A repair shop will have these. Stephen
Posted on Sep 05, 2009
Briggs & Stratton 19hp opposed twin platinum engine keeps surging with the choke off. But with the choke about 3/4 closed runs great. Cleaned carburetor and adjusted it and governor a little. Same way
when this is running at it's best, look closely at the Levers as you move them slowly and see all that's affected by this movement look for bent Levers and if you can adjust-adjust. careful you don't break anything as you might try to bend back the Lever.., Don't adjust anything yet!, Pay close attention to adjustable ways that can be made on the Levers. And adjust accordingly. Make very small positions/turns and let engine settle into its new revolutions (Running) might take a few minutes.
Thanks, hope it helps.
LJ
Jul 10, 2015 | Briggs & Stratton Measuring Tools &...
Briggs and stratton 875 series
Engine hunting is fuel starvation, dirty fuel, partly blocked main jet.
Jun 02, 2012 | Swisher T14560 T - 60" Trailmower with 14...
I have a 3.5 horsepower B&S push lawn mower. It is easy enough to start, but once started it fluctuates. Runs high and then low almost as if it will cut off and then it runs high again. What can I...
I have a Briggs & Stratton 3.5HP Model 91212 type 1319E1 engine that I'm having trouble keeping running. Once it starts it will run about ten minutes, then die, and then is impossible to get re-started. Is this a carburetor problem, or possibly a coil?
Kent
Aug 31, 2011 | Briggs Stratton IC Horizontal OHV Engine ...
148cc Briggs and Stratton engine starting but after the primer fuel is gone the engine cuts off, it will start but won't remain started.... Thanks
remove main jet from fuel bowl and clean it out. the little hole should be at the top of the threads or up the center of the bowls bolt.
Aug 08, 2010 | Briggs Stratton 10,000- to 12,000-Watt...
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical engine 24hp,48in riding lawn mower,keeps smoking.
these are common for doing this ,if you dont want to pull it down and hone the cyl. then i would use a heavier oil say 20w/50and that will probabley solve your problem
Oct 21, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Have to hold chocke out to keep it running
sounds like the needle and seat is dirty within the carb
Aug 11, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Having problem starting and keeping engine running. Spray engine starter fluid and runs for couple of minutes then dies. Acts as if its not getting fuel. It is a 13.5 briggs and stratton engine. Could it...
some have fuel filter some do not , but it sounds like you have contaminated fuel and is is clogging up fuel line or carburetor,look into gas tank with a flash light and see if there are specs floating at bottom of the tank, if there are drain tank of all gas and remove tank and flush it out with brake cleaner, then disconnect both ends of fuel line and spray through tube into white paper towel until u see no dirt/debris. then remove air filter clean foam( soapy water, dry re-oil 10w30 is ok). remove carb from engine spray through main port with carb cleaner not brake cleaner, and use tube and spray through inlet tube while holding throttle wide open reassemble and it should run fine, if not u may need to disassemble carb if not comfortable with this then order new one usually under $100
Jul 09, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Garden Logo
406 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
