GE GSS20IEM Side by Side Refrigerator
Problem for GE GSS20IEM Side by Side Refrigerator
Variance in freezer compartment temperature
By madado on Sep 04, 2009
i have a 3 year old ge (gss201eta) refrigerator whose freezer temperature varies from 15 degrees F to -9 degrees F. is this typical of this model? several websites specify maintaining a freezer temperature of 5 degrees or less. i have the freezer temp control set at 6. i have recently replaced the defroster heater to the newer 2 wire design, without positive results. one repair person hinted at the possibility of a bad computer board.
any thoughts would be appreciated.
Best Solution
posted on Sep 04, 2009
Very Helpful)
woodchuck789
Rank: Guru  GE Refrigerators  Expert
Rating: 91%, 639 votes
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost heater, defrost thermostat. If the heater and thermostat are ok it’ll be the control board.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for GE GSS20IEM Side by Side
Questions and Unsolved Problems for GE GSS20IEM Side by Side
Do you recommend GE GSS20IEM Side by Side Refrigerator?
Answer
Answer
the freezer stopped freezing food everything defrosted. it won't make ice.
Answer
The freezer keeps icing up. Seems to have a lot of moisture aroungice maker. Drain was frozen but I... (More)
Answer
After about an hour the freezer is 26 and the fridge is 64. The Evap Fan isn't running. I cliped the... (More)
Answer
evap. fan runs but no power to compressor freezer up to over 50'  look at thermostat turned on... (More)
Describe your Refrigerators problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Refrigerator Experts
Top Refrigerator Repairmen
in Sedona, AZ
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(619) 564-4488
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
