Question about Kenmore Elite Oasis 27052 Top Load Washer
Kenmore washer elite top load makes nosise when spining.
If it sounds like gravel rattling around during the spin cycle while the machine is draining this is caused by small articles caught on the influent side of the drain pump. You can remove the hose from the side of the pump and clean pump. If left the articles can damage pump and housing.
Kenmore needs to install an easily accesible line screen to elleviate the problem like on some other HE designed machines. It could then be cleaned easily once a month and save the pump.
Posted on Sep 15, 2009
    Problem Solver:
  • 18 Answers
If it also tends to walk around, there are pads under tub supports that tend to wear out in this model. They are easily replaced.
Posted on Sep 06, 2009
  • aldensteve Sep 06, 2009
Washer will not drain. I can hear the motor or pump spining.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Aug 22, 2010 | Kenmore Elite 45986 Front Load Washer
When spining the washer makes a grinding sound
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
Apr 24, 2010 | Kenmore Elite 45986 Front Load Washer
Our washers keep flashing LF after the wash cyle and stops workin, not spining very fast either.
Hello there :
the Dreaded LF code means
LF Long fill If the water fill time exceeds ten minutes, the water valves are turned off and "LF" is flashed.
Press STOP/CANCEL to clear the display.
check the water controle inlet valves that are attached to the machine for proper operation and replace if found bad
Jan 07, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
I have a kenmore elite washing machine. it is not spining the clothes all the way. it is leaving the clothes soaking wet.what should i look at
Take the agitator apart by pulling off the softener cup and taking out the bolt, probably broken plastic DOGS. Ask your appliance parts guy for them.
Nov 11, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Not spinning
motor you hear is probably pump motor ..remove bottom cover remove acess port on pump and clean
Nov 16, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore elite top load ms9711174
THE KENMORE TOP LOAD WASHER HAS A CLUTCH AND DRIVE COUPLING THAT IS PART OF THE SPIN CYCLE.
THE DRIVE COUPLING ATTACHES THE MOTOR TO THE TRANSMISSION AND IS MADE OF PLASTIC AND RUBBER.
IT COULD BE GETTING HOT AND TORN. THE OTHER POSSIBILITY IS THE CLUTCH MAY BE SLIPPING. THERE COULD BE OIL THAT HAS GOTTEN INTO THE CLUTCH AND SO THE CLUTCH WON'T GRIP. PULL THE CABINET OFF OF THE WASHER OR TIP IT BACK AND CHECK THE FLOOR FOR BLACK OR WHITE SHAVINGS OR OIL. THE SHAVINGS WOULD BE FROM THE DRIVE COUPLING AND THE OIL COULD BE FROM THE TRANSMISSION OR THE SPIN TUBE.
Apr 01, 2008 | Kenmore 22422 Top Load Washer
Series 70 kenmore elite washing machine
If it goes through the complete cycle o.k. except for the slow spin then the motor itself needs to be checked.
Mar 20, 2008 | Kenmore 24622 Top Load Washer
Possible your belt is loose; you have to unscrew the back after disconnecting electrical connection from wall socket. If the belt "gives" more than half an inch, you have to loosen the motor bolts and push motor upwards, then tighten the bolts very well. Try spin only to check, before closing the behind. It shd spin very fast.
Let me know if it worked..
Oct 17, 2007 | Kenmore 22422 Top Load Washer
Kenmore Elite Oasis 27052 Top Load Washer Logo
294 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
