Question about Zebra Eltron P420C Printer
I have problem in replacing my new print head to p420c
2 Suggested Answers
  • 1129 Answers
SOURCE: The Zebra P420C printer was
try going into the hardware install/removal wizard or into device manager to remove and reinstall the driver for the unit this may help.
Posted on Oct 02, 2009
Ip4850 flashes 5 times
According to the Official Canon knowledge base, it means that either print head is not installed at all, not installed correctly or the print head is defective. Install or reinstall the print head or if that doesn't help, replace the print head with a new one...
Also your print head nozzles can be clogged with dry ink, so before changing the print head with a new one, try to clean the print head with some warm water so the dry ink can come out of it... If that is of no help, as I said above - buy a new print head and install it or buy a new printer, if buying a new p. head is too expensive compared to a price of a brand new printer...
Mar 26, 2013 | Canon IP4850 Inkjet Photo Printer
False ink empty
Are you sure its exclamation mark?..
This warning message related to print head. (warn out). When you are replacing ink tube assembly use dummy print heads to do the priming (new ink tubes are empty & they have to fill with ink)..
Action: Remove all cartridges and print heads, switch on the printer follow the screen message.(Insert cartridges first next dummy print heads).once its recognizes cartridges then it switch over to print heads,insert dummy print heads. Once printer recognized the dummy print heads, printer will perform priming, during priming dummy print heads will filled with respective inks.(follow the display message)Remove dummy print heads & insert normal print heads. Wait till printer recognizes print heads, load the paper & wait till performs the calibration, once calibration is successfully done issue closed.
If calibration not successfully done, check align print out for which print head is not printed properly, replace it..
Pl ensure that minimum 50% ink levels required in cartridges before performing the priming. Best of luck..
Dec 03, 2012 | HP DesignJet 500 InkJet Printer
Printing colour is wrong, colours come out pink. Nozzle check indicates cyan colour is not printing. I have carried out cleaning, deep cleaning. I've cleaned the print head and finally just replaced the...
> replaced the print head
Did you replace the tri-colour ink-cartridge, or did you replace the print-head mechanism?
Are you sure that the CYAN part of the ink-cartridge is not empty?
Mar 09, 2011 | Canon i9900 InkJet Photo Printer
Controlador de impresora zebra modelo p420c
Saludos. Conseguiste el driver para windows 7?
Jan 07, 2011 | Zebra Eltron P420C Printer
HP Designjet 500, I have replaced the black print head twice, the first new print head would align and then fail the color calibration, the second new head aligns and pass's color calibration, but when I...
it seems there r some air in ur ink tube *** inser the priming heads & done the priming & reinstall the print heads if problem not resolved replace the carridge assembly,,,,,,,,,
Jun 03, 2010 | HP DesignJet 500ps (42 in.) InkJet Printer
Ribbon cuts or stick over Id surface when printing with Eltron
Turn the heat settings down in the driver. Clean the printer with the available cleaning card. Have the printer serviced.
Jan 21, 2010 | Zebra Eltron P420C Printer
The Zebra P420C printer was working fine then it would not print any cards. The unit was cleaned and a print head replaced the unit will still not print any solutions. SN611182 (newer style)
Oct 02, 2009 | Zebra Eltron P420C Printer
How do I reset the card-print counter on an Eltron P420C
u select the properties and search for tabs like card count,details etc and reset thecount to 0.im not sure about this answer this may work or may not be.
Aug 26, 2008 | Zebra Eltron P420C Printer
All colors not printing
hi this is nichu, you have done everything correct but the ink is low in your catridges refill it or purchase a new one.
Nov 20, 2007 | Canon MultiPASS F80 All-In-One InkJet...
Zebra Eltron P420C Printer Logo
82 people viewed this question
Top Zebra Office Equipment & Supplies Experts
pkwc
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
