Question about Canon Color C3220 Copier - Color imageRUNNER C3220 Printer
How do I get the network IP address from the Canon C-3220 all-in-one copier
  • Anonymous Mar 29, 2014
    How do I clean the ITD sensor of my canon 3220 copier
Hi!! How can I change IP address on DCS-3220 security camera?
DCS-3220 is fixed IP security camera !!
can't change its ip !!!
Jun 14, 2011 | D-Link DCS-3220 Network Camera
How to install canon 3220 to the network for printing
Hello ,actually its a very easy way to install canon 3220 to a network just download the driver from canon official site :software.canon-Europe.com
go to printers and faxes add printer press local then next choose create port choose stranded tcp/ip write down the same ip of the copier then press next ,choose have disk and specify where the file u download it from the site and after that choose from the menu canon clc3220 c1pcl5 then press ok so now the printer driver is defined. now at the other side (photo copier ) press * system management network settings choose TCP/IP and give the machine IP turn off and the on the machine to save the changes .now the machine is connected through the network :) for more assistant t here is my email mramlawi@gmail.com regards :)
Nov 09, 2010 | Canon imageRUNNER C3220 Color Copier
How to know ip adress for Canon ir c6800
Network settings are in the additional functions> system settting > network settings. If your printing to the copier the ip address should be there in the network settings.
May 13, 2010 | Canon imageRUNNER C6800 Copier
Conect to network
you have to setup in printer menu option
network settings
-> TCP/IP settings
-> IP address
-> subnet mask
-> Gateway address
and ping the ip of pirnter form pc and install the driver .
Jan 28, 2010 | Office Equipment & Supplies
Canon imagerunner c3100n Howe do I remove
Your in the copiers IP address into your web browser and go to address book and delete address , you can also add address's here. If you do not know IP address, go to machine, touch additional functions, system settings, network settings, tcp/ip, IP and write down #.
Oct 30, 2009 | Canon imageRunner C3100 Copier
What is the default ip address of D-Link DCS-3220 ip cam ?
Hello
The D-Link DCS-3220 have DHCP, that means it gets a automatic address from your router.
IT doesent have a STATIC ip, if you not set it manually.
To configure your D-Link DCS-3220 CAM and find the IP you need to install this program.
Install Wizard You need to unpack it first.
Connect your computer and cam to same router and run the program. Then it should find your cam so you can configure it and see what ip it get your you set.
Then you can browser to the cams IP.
Here is the manual and instruktions for you CAM
Here is Quick install guide
Here is you Dlink cam site to get firmware updates and more.
Hope it works.
Jul 09, 2009 | D-Link DCS-3220 Network Camera
Network ScanGear can't discover Canon IR 3220
Had the same problem with my Canon IR2018i... After spending about all day stuffing around and ready to give up... I read in the Color Network Scangear User Manual that
"Only scanners on the same subnet (network with the same network ID) as your computer are displayed in the list"
So I went the the TCP/IP settings on my copier and changed my subnet mask from 255.255.255.0 to 255.255.255.255 and magically my scanner appeared....
Give it a go...
Jun 24, 2009 | Canon Office Equipment & Supplies
I have installed the drivers for both my canon imagerunner 3220 and my 3300 but i still cannot print to it or scan from it. I have the network cables connected... I can ping it do i have the right...
Enter the device IP into your web browser. This shoudl load its web management interface. If it does not, you have an IP connectivity issue. You must power cycle the unit after changing IP settings.
press additional functions, report settings, network, user data list, yes. Check to see if DHCP is enabled. If it is, the IP displayed in the report may not be correct. DHCP should be off in most cases. Verify IP shown here.
Double check for link lights on the network cable.
Jan 12, 2009 | Canon imageRUNNER C3220 Color Copier
Scanner installation
I WANT T INSTALL SCANNER SOFTWARE IN MY SYSTEM
Dec 09, 2008 | Canon imageRUNNER 3300 All-In-One Laser...
Unable to create an email address on a Imagerunner 3220
Hi Keeyan.
Fist you will need a send kit only supplied by your dealer.
If this funcktion is inable follow these steps.
Press the user button(it is the button with the star)
Select system settings,network settings-in network settings go down wit the arrow until you get e-mail/i-fax settings.(If it is not showing here or in tcp/ip settings the send kit might not be enabled)
In e-mail settings enter the smtp server name or ip address(you will find it on your computer in outlook under tools and acounts)
In the email you can enter a email address supplied by your network adminitrator.
If you have a DNS server insert the ip adress of the DNS in TCP/IP settings.
Make sure you IP addres is also correct.
Then you are ready to go
Nov 21, 2008 | Canon imageRUNNER C3220 Color Copier
311 people viewed this question
old marine
old marine
