Question about LG RH177 DVD Recorder/HDD Recorder
LG DVD HD RECORDER SUBTITLES come on by themselves
Have an LG hd recorder/dvd player - tell it on setup menu to turn subtitles off. records with them anyway and they often come on by self when watching telly. its actually an rh397d or rh399d - neither were on menu. VERY ANNOYING. when watching stuff u have taped u can't help but read stupid subtitles
Subtitles always on
Hi - welcome to FixYa,
There are 2 methods for changing the subtitle settings on your DVD player.
Method 1.
To turn off the subtitles on your DVD player during playback:
1. Press the "SUBTITLE" button on your remote control
The subtitle button is just below the "0" (zero) numerical key on the remote control. It is marked "SUBTITLE" above the button and the button has "ABC" written inside a white rectangle on it.
2. Use the left "<" and right ">" arrow keys to change the subtitle setting
Each time you press an arrow key the subtitle language will change and eventually the language will read "OFF". The subtitles are now switched off during playback.
Method 2.
To turn disc subtitles off from the main menu:
1. Press the "MENU/LIST" button on your remote control (directly below "STOP")
The main menu will now appear
2. Press the down arrow key on your remote once to highlight "A" in the left hand column of the main menu
3. Press the right arrow key on your remote once to move to the right-hand column of the menu
4. Press the down arrow twice to highlight "Disc Subtitle"
5. Use the left and right arrow keys to change the subtitle options until your required choice is displayed
6. Once set, press the "MENU/LIST" button again to exit the menu.
This should solve your problem, but if you need any further assistance, please post back.
Regards,
BElectric
Nov 21, 2010 | LG RH-4820 DVD Recorder
How can i remove unwanted subtitles the movie is in english and the sub titles ate very distracting
Usually, if the subtitles are from your dvd player, you can go to the main menu, select "languages" or "setup" (depending on the dvd), and find the subtitle option. You should be able to shut them off there in the menu. If the subtitles are there because of your tv, there should be a button labeled "cc" on your remote. If you press this key a few times, it should eventually read something like "cc off" on the tv screen. I hope this helps, and good luck! Sincerely, Der Strom
May 10, 2010 | LG DR-4912 DVD Recorder
Subtitles appearing on screen in recording mode on LG RHT497H
You are confusing subtitles with closed captioning (CC).
Nov 19, 2017 | LG RH177 DVD Recorder/HDD Recorder
Stop Substitles on a LG RHT497H 160G dvd recorder?
I have the LG DVD recorder DRT389H which has the same problem. You can't switch off the subtitles during timer recording from the Electronic Programme Guide. The only way I could stop this was to go to the main set-up menu then select the A icon. Select DTV Subtitle and choose a language that the TV programme isn't broadcast in. I chose Gaelic. The only disadvantage is that this stops any subtitles being recorded so you can't access them later.
Dec 26, 2009 | LG RH177 DVD Recorder/HDD Recorder
Hookup wrong? I can't get the menu to come up for the VR375
New HD tv. Have digital cable box connected to tv., cable box connected to DVD recorder, but can't get setup menu to come up on tv screen. I had a similar problem. I have a HD tv connected to a digital cable box. I hooked up the DVD recorder with the wires it came with, but it would not play or give me the menu. However it was correctly hooked up. So the next day I connected a HDMI wire from the DVD recorder to the tv and everything works now.
May 24, 2009 | Samsung DVD-VR375 DVD Recorder/VCR
I would like to be able to record TV shows WITH subtitles/closed captions. I have a Hisense HD LCD TV with built in HD tuner. I would like to be able to record onto a DVD/VCR. I'm getting conflicting...
Hey, I have a deaf brother with this issue. What I done was route the AV output of the TV to the AV input of the recorder. Set your recorders source to AV1 (or whichever you use) and set your TV to the program you want to record, also turn subtitles on. Because you wont have your TV set to the input your DVD recorder is on, you won't be able to see the DVD recorders output, but thats fine. Just press record on the unit - you have to leave the TV on the channel it's recording. Now you should be recording TV with subtitles with no problem :D
Apr 27, 2009 | Televison & Video
DVD Menu selection not available from Setup Menu
I don't have movies from premium channels, but do have cable HD channels. When I got the message re not recording in +VR, I copied from DVR to HD in PhilipsDVD-R and then dubbed to DVD.
Dec 05, 2008 | Televison & Video
We have a RH397D digital recorder. We cannot get the subtitles to stay off. Every time we change channel the subtitles come back up again. Where do we go on the menu to keep the subtitles turned off?
Easy Menu
Setup
A – DTV Closed Caption - OFF (Make sure it is turned off) I am not sure what activates this to ENGLISH but it can be switched off.
Aug 05, 2008 | Televison & Video
Finalization problem2
After transfering video from HD to DVD, before you press the "Menu" button. please make sure you you press "DVD" button on your remote to tell the machine you want the menu for "DVD" first.
It confused me at first :-)
Hope this helped
Feb 11, 2008 | LG RH266 Recorder
LG RH1999H DVD HDD Recorder
1. Turn machine on
2. Use remote to open disc tray
3. Use remote to go to setup area of menu (Home - Left) and scroll down to 'Lock' symbol
4. Press 0 seven times
Oct 29, 2007 | LG RH1999H DVD Recorder/HDD Recorder
LG RH177 DVD Recorder/HDD Recorder Logo
906 people viewed this question
