Question about Refrigerators
Fridge freezer candy mod:CBCA230 shows error code H on cooler side of display ches
  • ches66 Sep 10, 2009
    many thanks ches
  • Refrigerators Master
  • 19,396 Answers
I do not have service manual for this model , but I think the H stands for defrost Heater error.
The defrost heating system is located behind fridge firewall, it is composed by heating element , fan and defrost thermostat. The heater is tested reading Ohms at its contacts.
Try first tripping the circuit breaker for ten minutes or unplugging power cord , and see if you still get the error.
If that does not work, ring Candy at the number listed on the owners manual.
Posted on Sep 04, 2009
Frigidaire Gallery side by side error codes
SB is in "Sabbath Mode".
The Sabbath Mode is a feature that disables portions
of the refrigerator and its controls .
Sabbath Mode is turned ON and OFF by pressing
and holding both the freezer "down" and refrigerator "up"
indicators for five (5) seconds. The display shows "Sb"
while in Sabbath mode.
Jul 04, 2013 | Refrigerators
Samsung fridge freezer SR2028CVW not cooling or freezing
If you have used it since 2004, it probably is worn out.
May 02, 2017 | Samsung Refrigerators
WHAT IS THE COOLEST TEMPERATURE BETWEEN THE SETTINGS 1 TOO 7 IN MY CANDY FRIDGE?
1 is warm.2 is cooler.3 is cooler still 4 is cold etc.(use a fridge thermometer and keep the fridge at +5C,optimum temp)
Oct 14, 2010 | Candy CPCA240FFK Bottom Freezer...
Sub-Zero PRO48 fridge - Error Code 40 and EC91
Here are the most common Sub-Zero error codes:
Sub-Zero Error Code EC40: Freezer will not stop running
Sub-Zero Error Code EC50: Refrigerator runs too much
Sub-Zero Error Code EC24: Defroster is not heating enough
Sub-Zero Error Code EC 06: Evaporator thermistor reads inconsistent temperatures
Sub-Zero Error Code EC20: Defrost Bi-Metal Operation is faulty
Larry Rogers
http://sparkleappliance.com/ca/sub-zero-refrigerator-repair-los-angeles
Nov 08, 2009 | Sub-Zero PRO 48 Side by Side Refrigerator
My candy cbca230 freezer always freezes up and stops cooling the upper compartment. Fan works fine, seems that the fins all block up with ice.
same here. Seems that the heater wires heat up at top of drain tray(bottom of condensor inside at back) but dont heat up at bottom of draining tray so causing ice and not allowing water to drain out to compressor bowl. May be a design fault with the heater wires.
Sep 09, 2009 | Candy CPCA291FFK Bottom Freezer...
Fridge has become freezer and freezer become fridge
sounds like the control board i had same problem along with no light i had to have control board replaced working fine now
dmb
Jan 25, 2009 | Candy CPCA240FFK Bottom Freezer...
Candy fridge freezer
It sounds like a Freon leak. The compressor is running and it gets a little cold. THis is not something you can fix yourself. You have to have certification to buy freon and gauges and know exactly how to use them. Besides in most cases you can't find the leak and will have to keep recharging it.
Jun 28, 2008 | Freezers
Aeg fault codes
aeg santo fridge/ freezer
The fridge part of my appliance is not getting cold please help
Apr 13, 2008 | AEG 10.35 cu. ft. / 293 liter Upright...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
