Question about Dell Inspiron 6400 Notebook
CPU usage is 100% !!
Some times when I power on my Dell isnpiron 6400. I heared that the voice of CPU fan became very high and loud, and the Windows load very slowly, I can't open any program just after 5 min from i double-clicked on its icon!! the system became very slow, and cpu usage is between 99-100%.
Just shut down and power on again.. every thing back normal and the Windows become fast.
I have Antivirus software (Kaspersky 6.0) and updating it every day..I wonder if it's virus why it will be not active when I shut down and operate the laptop again??
  • 54 Answers
Re: CPU usage is 100% !!
Hey there yasser_81,
So it was just a random spike in CPU usage? Do you remmber what you were doing at the time this occured? Were you playing any PC games, or were you just simply checking email. To be honest, this doesn't too much like a typical virus. It doesn't rule out the fact that it is.
Simple check though, if you are concerned of it being one, is use a quick check with TrendMicro.
go to,
What this is, is a simple, applet based virus scanner that will check your PC of any infected files, and also attempt to remove them.
If it does in fact find some malware/greyware/worm virus, then you may safetly assume that, that's what caused the issue.
If it did not, it may otherwise have been just your computer not dealing well with opening/closing of applications so quickly.
If these steps do not help, respond back please with what you were doing at the time, and also how much memory does your laptop have.
Posted on Dec 08, 2007
0 characters
3 Points
Dell Inspiron1410 running 50% CPU usage with no other processes running in background. This after a nice repair install of Windows XP professional. High fan noise and heating up! Thanks
Hello Saman Tarik,
Task manager may say there are no other processes running but if you look in the next tab, "Services" you will find there are many things running.
The processor will run at a lower percentage when it is not busy.
As for running hot, I would suggest that the heat sink fins need cleaning out, I was surprised at how much fluff had accumulated in them, preventing a good air flow.
I have upgraded my processor from 1.5Ghz to 2.5Ghz which runs hotter so I bought a ZALMAN ZM-NC1500 USB and the hottest my CPU has reached is 41 degrees when both cores are running at 100%.
I hope the above information is of use to you.
Kind regards,
Nov 21, 2013 | Dell Inspiron 8600 Notebook
DELL INSPIRON 1410 idle process takes high processor usage and heats up my pc
If running Windows OS - there could be several background processes running causing this higher CPU usage.
Hitting 'CTRL/ALT/DEL' will bring up the task manager (Win98/WinXP) or a Menu which has task manager (WinVista/Win7/Win8), you can then see what background programs are running.
Hi i have a dell 6400 notebook when the charger conected to notebook cpu usage is 100% and do not work corectly but when disconect the charger work normal and good, (whith battry) this problem happen when...
when plug adoptor any trebal in mouse working if mouse aero do some problem buy orignal charger
becuse local charger is not work properly dell some model spaishaly 6400 ok if u have orignal charger change bettary
if fix your problem click yes for vote
Jan 06, 2011 | Dell Inspiron 6400 Notebook
I am not really sure if this caused by the fan performance, but I can confirm that my laptop dell inspiron 1420 is very hot after running about 1 hours.. and often my CPU usage reach 100% when I use Vista...
First, I appreciate the details provided in your question. Thanks!
The specification of your laptop are fine and enough to run and support Vista. It is true that greater number of processes and CPU usage causes, but normally the machine can handle it well if it gets proper ventilation.
Laptop heating issue generally occurs due to fan failure, which may damage the system, if not checked properly. Another cause of overheating is the dust present inside the laptop, which clogs the fan and heatsink. I suggest that you should get you laptop checked by a professional for servicing (if required). I believe immediate action is required to prevent any damage to your machine and data.
Hope it Helps! Let me know if i could be of any further assistance.
Nov 25, 2010 | PC Laptops
Why is my computer overheating only after 10 minutes
There are several possible causes - these are the 3 most common:
1. The fan is broken - can you hear it running?
2. You are running too much background software
Open "Task Manager" and select the "Performance" tab. If the CPU usage is constantly at a high level (80-100%) you may have too many background applications running. Next click on the "Performance" tab and look at the CPU column. See which processes are using lots of CPU power.
3. You have a virus/malware. Reboot in safe mode and run a virus scanner.
Oct 14, 2010 | Compaq Presario CQ60-220US PC Laptop
Seems my toshiba satellite lap-top is over heating, how do I get to the fan to clean it? Model number: psafgu-02k001 serial; x7253530q
If your fan is running OK, then it probably doesn't need cleaning.
I have a satellite A350 and it pumps out a LOT of heat but that doesn't mean it's overheating. It's more likely your CPU usage is very high, which makes it very hot.
Turn on the CPU Meter in the Windows sidebar and close all applications. Watch the CPU usage (the larger front meter) for about 20-30 seconds. If the AVERAGE level when running no other applications is over 40% or spiking up at 90 or 100% then you are probably running too much junk in the background, or you have a virus.
Oct 14, 2010 | Toshiba Satellite A215-S5837 Notebook
My Dell Latitude D620 runs slowly on ac power. The pc usage spikes to 100. Occassionally it will start running properly on ac power, but problem persists once unplugged or hibernates.
This sounds like a problem with your power management settings. On battery power, many of the "bells and whistles" futures such as the transparent task bar are turned off to save battery life. This greatly reduces your cpu usage, thus saving power. I would recommend changing the theme from Windows Aero to Windows Basic. This can be found by right-clicking on the desktop and selecting personalize. Good luck!
Jan 18, 2010 | Dell Latitude D620 Notebook
Dell inspiron 6400-runs slow on AC power but not on battery
uninstall any energy management software provided by dell and then check.if the issue is not resolved then the issue is with the converter board as it is heating up.
Jan 29, 2009 | Dell Inspiron 6400 Notebook
CPU saturatuon.
You'll need to look at the Processes panel in the Task Manager to see which processes are consuming your CPU cycles. If you click on the CPU column heading, the process list will re-sort based on CPU usage. If the list appears to be arranged low-to-high ('00' at the top), click on the heading again and the list will reverse so that it appears high-to-low ('00' at the bottom). Once you identify the contributing processes, you can troubleshoot them one-at-a-time.
Oct 20, 2008 | Toshiba Satellite A25-S207 Notebook
Audio works fine but voice doesn't
You need to reinstall driver of your sound and installed properly
Sep 22, 2008 | Dell Inspiron 6400 Notebook
Dell Inspiron 6400 Notebook Logo
158 people viewed this question
Top Dell PC Laptops Experts
Sudeep Chatterjee
Sudeep Chatterjee
Donna Sander
Are you a Dell PC Laptop Expert? Answer questions, earn points and help others
