Try going into device manager find the device and see if you can change the COM PORT. -------------- also another option Check in the bios to see if the COM PORT is enabled.if its enabled then disable it. ------------ if nothing is working try system restore. click the start option --- then click on programs option --- then click on accessories --- then click on system tools and then click on system restore. -------- in system restore you set your pc on that nearest date on which day you were able to hotsync your handheld and desktop. it will ask you to restart and then your pc will get set on that date.and it will work as normal as it was working before. NOTE:-- system restore procedure never- ever harms the pc. --- thanks.please keep updated.please do rate the solution if helped.thank you for using fixya.
First let me knwo with which cable you use with connect palm to computer.
USB or COM port.
REinstall driver then check.
Also check that in your palm usb connectivity is enabled.
Check that cable is working fine.
Let me know if you need more assistanse.
Thanks.
Hi, it's a USB cable plugged into the back of my IBM tower.
I'm not sure how to reinstal the driver nor how check the usb is working?
Any suggestions?
Thanks very much for advice. Could you tell me if I remove the driver and proramme how do I reinstall them? I've no idea where the original installation disc is!
