Question about Samsung PPM42S3 42 in. Plasma Television
42"lcd samsung tv,one year old has stopped working on digital and analogue but can work with a sky box or freeview box,ie it will not work on its own,thanks 42" lcd samsung wont work without a sky or freeview box plugged in
  • paddymac Sep 04, 2009
    hi there
  • Anonymous Mar 29, 2014
    Reconnecting sky box but will it work without phone cable
  • 35 Answers
Sounds like it needs a re set
you need to press the following: (do not hesitate between presses)
s/by
info
menu
mute
s/by
when the tv comes back on follow original installation set up
Posted on Sep 04, 2009
I have a panasonic viera 42 in plasma. It has a built in freeview receiver. It is in the bedroom and receives a signal through a booster from the main sky box. I can get free view channels on it but can't...
switch tv to analogue tv and auto tune on tuning menu making sure sky is on. It should find it around channel 69. If quality poor then change output frequency to a lower channel. You do this with sky menu and instruction book. Info is changing RF output in book, or google it.
Apr 30, 2014 | Panasonic PV-M1349 Combo
Can you show me how to connect up the scart and aerials up to the following so they operate correctly Samsung PS42C450 42-inch 600Hz Widescreen HD Ready Plasma TV with Freeview SAMSUNG DVD-SH893M 160GB...
hello firstly scart lead from sky box to tv1 in) this is at the top there are two AV inputs ,,,on the bottom AV slot this is where your DVD conects too).iff you are using sky you will not need aerial in back of tv as this is for analogue use such as indoor antenna or outdoor antenna or iff using horizon the scart lead will suffice for all goodluck
Mar 19, 2011 | Samsung PS42C91HDX 42 in. Plasma TV
I have a Pioneer DVR5100H which was set up to record Analogue programs - can I change the set up to accept digital programs. I have tried auto setup but it doesn't pick up any programs?
You can't record digital programmes with this recorder unless it is connected to a digital tuner, e.g. a Freeview box or Sky digibox. This recorder has a built in analogue tuner which allows it to record analogue transmissions. Recorders which can record digital transmissions have a built-in digital tuner and usually have a DVB logo (actually looks more like DV3) on the front.
If you want to record digital programmes using this recorder, you need to connect it to a Freeview or Sky digibox, preferably with a scart cable. It is not sufficient to connect it to a TV with a digital tuner or built in Freeview as the player does NOT record directly from the TV, it must be connected directly to the transmission source. A basic stand-alone digital tuner (Freeview box) can be bought for as little as £10-15.
Regards,
BElectric
Nov 18, 2010 | Pioneer DVR-5100H DVD Recorder
Cannot tune all digital cahnnels on Sharp aquos
Start by doing a factory settings/ defaults on the Sharp rather than a normal automatic retune.This should then be ok. You need to empty the existing presets first so it will find the new type of signal BBC is now using.
If still not working for BBC1 +2 then look at whether you have too much aerial signal strength. (ie a booster/splitter that you could bypass)
Nov 07, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Samsung 42'' LE40S86BD WON'T WORK ON DIGITAL OR ANALOGUE BUT WILL WORK WITH SKY OR FREEVIEW BOX,IE ,IT WILL NOT WORK ON ITS OWN.ONE YEAR OLD
Sounds like the tuner is faulty or if its a seperate module the cables might have worked themselves loose, the video/mainboard is ok as its still able to produce an image.
If your up for it whip the back off and checks the cables as there is not much inside these models and a cable could have worked itself loose.
If everything looks fine inside, reset the Plug and Play settings and if that doesn't sort it out, then I would personally not worry about it as a seperate freeview and sky box is more than work well if not better.
Thanks
Sep 05, 2009 | Televison & Video
Samsung LCD TV LE26R51BDX - No analogue TV or Freeview
Are you sure the TV has a built in tuner? Does your country have digital over air broadcasting like my country or not?
Mar 03, 2017 | Televison & Video
Lost ITV channels and C4
I think you need to get Sky because it will give you 100% coverage of all terrestrial channels. You may need to retune the television otherwise just get sky
Dec 31, 2008 | LG 32LX1D 32 in. LCD Television
I HAVE A SAMSUNG LE40R7, I CANT GET DIGITAL CHANNELS ON IT ?
I TAKE IT YOUR WATCHING YOUR SKY BOX OR CABLE ETC THOUGH THIS TV..BUT YOU CANNOT NOT GET FREEVIEW..CHECK YOUR ARIEL PLUG GOING INTO THE BACK OF THE TV, THEN TUNE THE TV IN FOR DTV. NOT CABLE OR SKY ETC THEY WILL NOT NEED TUNED IN..THE MENU FOR DTV..IF THAT DOES NOT WORK..DO ALL THE OTHER TVS WORK OFF THE SAME ARIEL ON THE ROOF TO GET FREEVIEW ???
Nov 14, 2008 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
Will this tv work without a converter box when everything goes digital?
Hi.
If your set only has Analogue tuner you will need either Sky. Virgin, Freesat, or freeview box to be able to watch TV channels.
Jun 22, 2008 | Televison & Video
Samsung PPM42S3 42 in. Plasma Television Logo
229 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
