TV REPAIR rca xl 100 color trac+ 26 inch, problem is ,a couple of days ago there was a glitch and the color went all dark and green and red. tried to adjust it with the on screen adjustments, no luck. the set is old(15-16years) but has always worked perfectly up to this point. can this be repaired and will this be worth doing, cost wise?
  • los santos Oct 11, 2008
    I have Direct TV coming through my APEX TV. It is a 27" color digitalo set. 5 months agao lightning struck the dish, knocking out the Direct TV box and the satellite transponders. A Direct TV tech came and replaced the dish, transponders and the box at the TV, but the TV has no sound, and the only visions are verticle moving lines of red, green, yellow and blue. I have no picture at all.
    Novelist:
    Champion:
  • 232 Answers
John, bad news, short in picture tube, not cost effective to repair, even if it was the tube is no longer available for that age set, the bright side is it doesn`t owe you anything at 15-16 years old, too bad the "new tv`s" don`t last that long, hope this answers your question, BMW Rider
Posted on Dec 08, 2007
Contrast really dark but seems to improve after the tv has been on several hours
Hi:
You may have a problem with the inverters in the unit, they are responsible for lighting up the back panel. Check or have checked the power supply voltage to the inverters, should be around 18-24 volts DC. Also leaky capacitors on the power supply will cause this issue as well as leaky or puffy capacitors on the inverter.
Sep 08, 2011 | LG 32LG30 32 in. LCD HDTV
My rca xl 100 remote will not work. I have changed the batteries multiple times. I was just wonder if i could buy a new rca remote and be able to have it work on my tv?
Yes,, you can easily purchase a new remote and have it work on that TV. In the packaging for the new remote you will find a piece of paper that contains the necessary remote codes for your TV. Follow the instructions provided with the remote and you are all set!
May 19, 2011 | RCA E13309 13-Inch Diagonal XL-100¿...
Need remote code for an RCA XL100 tv
I just programmed my RCA XL-100 today! The code is 11447
Jun 11, 2010 | RCA E13309 13-Inch Diagonal XL-100¿...
I need to find a replacement remote for this tv
http://www.rca.newremotecontrol.com/catalog_item.php?catnum=240959
There's one exactly for this TV.
Hope this helps. =)
Oct 20, 2009 | RCA E13309 13-Inch Diagonal XL-100 Color...
Convergence issue-60 inch RCA projetion TV
it is under set up options in the menu
Oct 16, 2009 | Televison & Video
TV Flashing colors
HEY WE HAVE A 72 INCH T.V AND IT KEEP POPPING UP DIFFERENT COLORS DURING T.V SHOWS WHY IS THAT WE JUST CHANGE THE LAMP IN THE T.V CAUSE IT HAD WENT OUT ON ME AND THAT WAS ABOUT 1YEAR AGO FROM MARCH13,2009 SO I WAS WOUNDING WHAT CAN WE DO OR ANYONE SAY EVEN IF IT IS THE LAMP CAUSE WE ARE STILL NOT SURE!!! THANK YOU E-MAIL ADDRESS IS bianca_guero_0909@doglover.com
Aug 01, 2009 | ViewSonic N2750w 27 in. HD-Ready LCD...
Several smokey lines cross the screen
I probably had the same problem. The cause is a bad main board ($276+-), digital board ($225+-) or analog ($102+-) board. Labor should be about $130. The actual lcd should be fine.
JVC will only issue a recall if 1500+ complaints on a model.
Mar 20, 2009 | JVC LT-26WX84 26 in. LCD HDTV
RCA P50830BL
Hi,the trouble is the power supply for the convergence,it the board that mounts above the two board that lay flat,there is a ic on that board that is heat sinked,part number is 215530,replacing this ic will return the menu and repair the set,the board is green 5 inches wide and 8 inches long.
Mar 13, 2008 | RCA P50830BL 50" Rear Projection...
Blue, green, and red colors all off
I would suggest having a repair person come out to your place to fix this problem. I believe the convergence IC are going or have gone bad. I would estimate a $300 - $400 dollar repair bill.
Sep 22, 2007 | RCA P46921 46" Rear Projection Television
Televison & Video Logo
135 people viewed this question
Top Televison & Video Experts
