Question about Cell Phones
My sony g 700 ...the touch screen not working but keypad is fine so i can operate the phn...but on off button is not working...as solution i ws asked to take off the battery for 15min n restart the cell... but since the on/off button nt workin is it fine to jus remove the battery without turning the cell off??
Sharp fx plus screen unresponsive
Sounds like the touch screen is dead, the crack most likely broke the touch screen sensor
Jan 20, 2014 | Sharp FX Plus
Touch screen is not working
Problem is not screen joanne. its your keypad. you have to replace the keypad and your touch will work again. buy original keypad only. tested by me.
Aug 15, 2009 | Sony Ericsson K850i Mobile Phone
I need to retrive the key operator code for a Aficio 1060/1075. How do I do this?
You cannot restore the key operator code for the Aficio 1060/1075. You can delete the code and then write new one .
Follow the instructions and will be easy.
1. enter the service mode.
2. To enter the service mode press one after other the follow keys on the control panel of the copier.
press the yellow key [ Cancel Modes] than press the number one after other [1]-[0]-[7] on the number keypad of the copier and than press and hold the red key [ Clear \ Stop] until on the touch screen do not appear the service menu after the service menu will appear press on the touch screen [Copy Sp] up in the right corner has a touch key [sp direct] press that key and press the follow numbers on the number keypad which are 7810 and then press "#' on the number keypad.
on the screen will appear "execute" press the touch button and than by pressing
"exit" several times you will exit from the service mode.
NOTE: "PLEASE DO NOT TOUCH NOTHING ELSE IN THIS MODE IF YOU ARE NOT A SERVICE TECHNICIAN BECAUSE BY PRESSING SOMETHING YOU MAKE SOME ERROR OR OTHER PROBLEM"
After clearing the key operator code you may enter new one.
If you need something else please ask
PLEASE RATE ME
Jul 15, 2009 | Office Equipment & Supplies
Three numbers on my phone keypad not working.
You need to remove the external casing and replace the keypad inside.
The operation can be done while you are waiting at any Phone shop with parts and repair facility.
Apr 08, 2009 | Sony Ericsson K550i Cellular Phone
Keep searching the satellite for connection
hold the power button the plus or minus button and the repeat button on top while powering on
Dec 13, 2007 | Magellan RoadMate 700 GPS Receiver
I don't have any voice and the touch screen is slow
kaelor, Yes, that would be my first instinct.. that is if I was in a shop with spare parts lying around.. but I'm guessing your not so... 1st off we are only talking about the touch screen's respones time right? You said the enter button is slow to react as well.. so that makes me think keypad too. If both are reacting well, then try resetting the user data. yes, all of your POI's would be erased if you did this.. so if you can't afford that to happen , then don't do this. 1. At user menu (upon initial boot) 2. press + key and repeat (on top) button 3. select reset user data, then select the verify yes button. 4. unit will reset, post back on here and let me know if this worked.
Apr 14, 2007 | Magellan RoadMate 700 GPS Receiver
Magellan Roadmate 700 GPS
If everything else is working fine, specifically the touch screen, then it's probably your speaker. open unit and check your speaker for anything stuck to the back of the magnet (on the speaker). make sure the cable going from your speaker to the keypad PCB (board) is pushed in all the way. you may want to even pull it out and re-connect it. make sure the unit is off while you do this and try to ground yourself with something. good luck and let me know how it turns out.
Mar 04, 2007 | Magellan RoadMate 700 GPS Receiver
Sony w550i
Its software problum(100%) Make it full flash. will be ok.
Feb 01, 2007 | Sony Ericsson Mobile Bluetooth Car Kit...
Frozen screen when turned on
Kevin, Hmm... it worked fine the first two times you ran it, then all of a sudden it freezes at the user screen?? I'm not sure if your able to do this, but at the user menu, try pressing the (-)zoom out key and the repeat button a the same time. -If it does bring up the "secret" menu, try clearing user data. -If you have a program that allows you to update the software, version 4.32 I'm guessing (or 5.14) then at that "secret" menu select NAND Flash Format and re-load the software. If you can't access the "secret" menu and it locks up hard at the user menu w/out any responsiveness, I would suspect the hard drive is either bad or has corrupt data. I'm not sure if you can order just the hard drive from magellan/thales/tomtom/shaw but if you can then just replace the hard drive, nand flash format (above) and re-install your software via usb. Additionally, not that it helps your problem, but atleast you would know the pwr and keypad work if this works, press Enter, Cancel and power button at the same time, as this SHOULD power off your unit. Let me know if any new symptoms/problems come up or if you need further instructions. -Daniel
Aug 31, 2006 | Magellan RoadMate 700 GPS Receiver
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
