Question about Hotpoint 23 in. BFI62 Built-in Dishwasher
Can't select program on diplomat 8520 dishwaster
The diplomat 8520 dishwaster will switch on but won't allow me to select a program. There are no lights that flash when trying to select a program. When i hold down the on button and the program button, the electricty trips out. Can you help? Is it a fuse?
5 Suggested Answers
catriver
  • 878 Answers
SOURCE: Dishwasher tripping the circuit breaker
Andy, leave the breaker off and remove the toe panel (bottom panel) from the dishwasher. Remove the cover of the junction box where the cord connection or wiring is made. Look at the wire caps and see if they are not burnt. Sometimes these connections become loose and arch, tripping the breaker. If so, cut the wires, strip a new end and reconnect. Catriver...post back.
Posted on Aug 21, 2006
SOURCE: FDW80
When the support engineer says press the 'on/off' button and 'start/reset' down together, press very hard. Press hard for 5-6 seconds and a the wording 'demo off' appears for a split second, then resets its self ready for use.
Posted on Feb 22, 2007
  • 1462 Answers
SOURCE: diplomat adp 8520 dishwasher no hot water
two things to check
check continuity thru heater
remove outer door panel and check for faults in wiring loom
get back to me is these are both ok
Posted on Nov 14, 2008
SOURCE: I have a Diplomat ADP
Why does the s button stay on for?
Posted on Jan 26, 2012
Dishwaster not working
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
REMOVE panel and check for moisture or loose joints in the connectors. If so dry using a heater. Check also the door switch. Other wise the panel is to be replaced.
Jan 17, 2013 | Washing Machines
Hey can you please unlock bb curve 8520 ...imei:357257.04.904092.1
Hi, You can get the unlock code for a Blackberry Curve 8520 from http://www.unlocking4u.com/blackberry-8520-curve/rs6wp9/ at affordable cost.
Here are the steps for unlocking a BB Curve 8520,
1 - Switch on your Blackberry 8520 Curve with any Sim card and Turn off all Wireless connections.
2 - Go to Settings.
3 - Go to Options.
4 - Select Advanced Options.
5 - Select SIM Card.
6 - Type MEPD using your Blackberry 8520 Curve keyboard (NOTE: You will not see any text appear on the screen while typing MEPD),
7 - Type MEP then hold 'ALT" key and type number 2.(NOTE: You will not see any text appear on the screen while typing MEP2),
8 - You will then be presented with a prompt "Enter Network MEP Code". Type in the Unlock Code and press in the track wheel / jog dial to confirm,
9 - Your Blackberry 8520 Curve will now be unlocked.
Sep 20, 2012 | RIM BlackBerry Curve 8520 Smartphone
Blackberry 8520 sim not allowed 3
this is normally the result of transferring phone to others, go to your settings, select security, select general, select wipe handheld, and after the phone reboots, try to insert your sim again..
Jul 08, 2012 | AT&T Blackberry Curve 8300 Smartphone
I update to the newest software for my Blackberry Curve 8520 but I can`t watch any video from the youtube web page::: why is that?
I could not either, I downloaded a free apps from MS that allowed me to do it,
In you phone's browser, type this address:
http://mobile.microsoft.com/windowsmobile/en-us/default.aspx
Select the free app for youtube and have fun
good luck and don't forget to vote!!!
Sep 28, 2010 | RIM BlackBerry Curve 8520 Smartphone
My blackberry 8520 cure app error 523...
1. Install the software Desktop Manager
2. Delete or rename the vendor.xml file, here: C:\Program Files\Common Files\Research In Motion\AppLoader
3. Open Desktop Manager
4. Connect Curve 8520
5. Doing this will force the pc to see the BlackBerry as new hardware, and thus force it to reload the Operating System
6. During the process, select YES to do a backup
7. The whole process should take about 1 hour
May 20, 2010 | RIM BlackBerry Curve 8520 Smartphone
Diplomat dishwasher bleeping showing FA
We have just experienced an FA audible error on our Diplomat ADP 8332 dishwasher...after pulling the dishwasher out and removing the low front panel we found the drip tray full of water. We tipped the dishwasher onto it's front and removed the drip tray and found a float pressure switch...it appears that once the drip tray is full the float switch activates and causes the FA fault (prevents the dishwasher from continuing) drain off your drip tray replace all covers and you should be good to go!!
Sep 16, 2009 | Dishwashers
All lights come on, program switch does not Diplomat ADP8132
If you cannot change to any program,worth checking out that the open door switch and cradle has not become dislodged etc,had same prob and fixed it,door latch out placement.
cheers
Sep 02, 2009 | Fagor 24 in. FI-48W Dishwasher
Diplomat adp 8520 dishwasher no hot water
two things to check
Nov 14, 2008 | Dishwashers
Diplomat intergrated dishwasher error code FA
FA is a problem with the tubidity sensor. By holding down the power button, it stops, but just repeats everytime you try a new wash cycle. So keep doing it and you can atleast use it. If you want to go one step further and find a permanent solution try feeling around in the sump (where the filter slots in) being careful for any broken glass. Other than that it will probably be a strip-down job to examine the internal hoses and the pump; not a DIY job to be honest.
Feb 03, 2008 | Dishwashers
Hotpoint 23 in. BFI62 Built-in Dishwasher Logo
69 people viewed this question
Top Hotpoint Dishwashers Experts
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
