Question about Garden
Husky ride on mower will not start.
Symptoms are no start--battery is OK but there are no lights and the starter will not turn from key. It will turn if jumped to the battery but the engine will not start, 20 HP Kohler on a 42 inch ride on mower by Husqvarna.
Is there a main fuse which might have blown?
    Champion:
  • 239 Answers
Sounds more like a safety switch problem, first verify the seat switch then the mower switcher and make sure it's not in reverse.
Posted on Sep 04, 2009
  • niyajerm Mar 29, 2011
    i have same problem. seat switch is ok. it is in neutral. but it still not start. could it be the switch itself. cause the battery is ok. it starts when i jump start it.but the electreial switch will not turn it on its like nothing is happing.what do you think?
When I try to start my 60" Ariens rider all I get is a loud clattering sound. I just replaced the battery 2 months ago. What's wrong with my mower?
Joel, Recheck battery to make sure it has good charge >12 v and all battery and starter wiring,plugs,connections are clean,tight and undamaged. If you remove spark plug and engine spins freely from the key, the engine compression release or valve clearance needs adjusted. It is probable the solenoid or starter is faulty, the starter Bendix/drive may be sticking. If you can, give the starter a couple sharp raps with a hammer or bar and then try to start.
Check the attached links,instruction and guides to help diagnose starting issue. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://troybilt.custhelp.com/app/answers/detail/a_id/86/~/clicking-sound-while-attempting-to-key-start---riding-mower
What Are the Symptoms of Bad Starter Motor on Riding Mower Engine
My Bolens lawn tractor won start It just clicks when turn the key even...
Craftsman riding mower won start Just clicks the starter motor
Aug 27, 2016 | Ariens MaxZoom60 60" 25HP Kohler Zero Turn...
John Deere Z225 trouble starting - turning the key to start, you hear the starter engage. The engine trys to turn over but struggles. Sounds like the battery is low. Bought a new battery, charged it...
The symptoms described may indicate a bad starter. First check all connections from the battery to ground and from the battery to starter You may want to have the starter tested at Advance Auto or Auto Zone. It will need to be removed from the mower, and I am not sure if Auto Zone, Advance Auto can test small mower starters. They test the starter under load, so if you remove the starter and hook it up to a battery, it will run probably, but it will not indicate whether the starter is good or bad. It needs to be tested under load. Good luck.....
Mar 18, 2014 | John Deere EZtrak Z225 Zero-Turn Riding...
Cub cadet model 1520 won't start.
Sounds to me like you might be having a problem with either your key switch, or more likely your starter. Although I have never had a starter go out on any riding mower Ive ever had, thats really what is sounds like. On the other hand, I have had many a key switch go bad and they act alot like your symptoms. So I would start at the simplest and work backwards.
Also, make sure blades are disengaged and also they are not bound up on the underside of the mower deck. also check the belt and its not in a bind. These thing could be dragging down your motor keeping it from starting. Let me know if I can help further. Have a Great Day! Good Luck!
Jun 09, 2012 | Cub Cadet Garden
Will not start fuse ok battery ok they said try new starter, its ok turn key on hear click Sound sounds llik up at carberator, AMP gauge gos negetive and starter will not ingage, belt for mower is...
I would try to jump the starter. Pos cable on the starter then ground out the neg, it the starter turns over that isnt it. then check the smaller wire going to your soleniod, when you turn your key to the start position it should have power. then check to see if there is power from the battery to your soleniod then with the key turned power from the soleniod to the starter.
Aug 20, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Mtd riding mower won't start clicking noise
Take some sort of 12V tester and measure voltage on the small terminal on the starter to ground. You should get close to 12 V with key turned. If you see the 12 V, test the incoming large battery terminal. It should also be close to 12V. IF that's ok, check the large terminal on the starter. If you have 12V here, then check for bad ground connection. If any of these are not 12V remove cable and clean connection. How are you sure the battery is ok?
Jul 23, 2010 | Mtd FASTATTACH MANUAL SLEEVE HITCH
Turn key wont starts
yes there should be,its ether near starter solinoid or near battery
Jul 17, 2010 | Husqvarna 24HP VTwin Hydrostatic 54" Cut...
I have a husky 14.5 B&S riding mower i am having problems with the motor turning over it drags i have replaced the battery and solenoid if i jump it off it will start .
check your ground and they are good check you starter motor it may be draging which would cause it to not want to start. From the sounds of what you are saying i would start there.
Good luck
Mark
C.C Motorsports
Feb 11, 2010 | 2001 Sym Husky 125
Starter motor won't activate
Had the mower blades engaged and there must have been a safety switch engaged.
Apr 18, 2009 | Garden
Garden Logo
295 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
