Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Miele freezer too cold -35
The freezer led temp indicator is showing -35, the food is rock hard. I have changed the temperature sensor and the problem still exists.
Question is :- Could the pot for the temp dial be duff,
Could the what looks like a capacitor that is mounted at rear left botoom near pump be defective.
I've just fixed this problem with a Miele 7132S. It was a capacitor on the electronic circuit board. A very simple job to replace and cost about £2. I got the solution from another poster wonkothesane on diynot.
Note that the electronics is connected directly to the mains supply so remove the plug from the wall before you start!
The module is simple to remove: open the freezer door and under the module are three slots with catches - just push each in turn with a small screwdriver and pull the module gently forwards.
The power supply uses a 0.47uF 275V Class X2 capacitor which had gone low value so there was insufficient voltage to operate the relay. The compressor is connected to the normally closed relay contact so the freezer runs all the time.
For safety reasons it is critical that you only replace this capacitor with exactly the same specification component as you remove!
While I had the thing apart I also replaced two electrolytic capacitors in the power supply, a 100uF 50V and a 470uF 10V.
Posted on May 08, 2010
Freezer temp cycles above freezing
If you have a frost free refrigerator then temp jumps as you discribe are somewhat normal during a defrost cycle. However it sound like your defrost temp may be getting too high. There is a limit thermostat on the freezer coils that keep the defrost temp from getting too high. The part is called a (defrost termination thermostat) and is a round disk about 1 to 1.5 inch in diameter clipped to the top of the freezer coils with 2 wires coming out of it. When cold, it allows power to the defrost heaters. At around 35/40 degrees it opens and shuts off power to the heater. 35/40 degrees sounds high for a freezer temp but that is behind the wall and only for a short time. Yours may be staying on too long or out of temp calibration needing replaced.
Mar 20, 2015 | Refrigerators
The freezer is to cold
I do assume this is in Celcius.
-20C is about the right level for a three-star freezer.
From Google:
  1. Domestic freezers have a star rating indicating the temperature they are designed to operate at. On the packaging of a frozen food there is guidance stating how long the food can be stored using freezers of a given star rating. As a guide here are some suggested maximum storage times at -18°C for a variety of foods."
Feb 12, 2015 | Freezers
GE monogram refrigerator too cold
There is a balance between the freezer and fridge. Reduce the freezer temp and see what the fridge temp does. By reduce I
mean make the freezer warmer. If it is set too cold the fridge gets colder.
Nov 25, 2013 | GE Monogram ZISS480DRSS Stainless Steel
Too cold
Refrigerators and freezers have a thermostat control inside the refrigerator compartment. It is normally some type of dial with numbers and a graphic indicating warmer or colder.
Place a thermometer inside the cold box. Wait one hour and record the temperature. Adjust the thermostat one or two numbers warmer, then wait 12 hours and record the temperature.
The interior temperature for a refrigerator must be below 40F for food safety. A good range is 35-38F.
Jul 26, 2012 | KitchenAid KBFS25EVMS Stainless Steel...
Lcd not working just flashing with no temp showing food starting to defrost
Hi, You should replace you lcd soon to see the correct setting of appliance. It is hard to control your freezer with out its screen working normal. Regards,
Nov 28, 2010 | Miele Freezers
Fridge freezing up
Check the fridge sensor. On my Hoover HNMF2805AL80 f/f, first I replaced control module - still freezing.
Have just replaced cheap fridge temperature sensor. Part No. 97061619. Trouble is you have to cut into insulation at back of fridge to replace. I just plugged in sensor & placed inside fridge at back at the bottom - so far so good, only lettuce freezing now, everything else v. cold but not frozen. :)
Jun 02, 2010 | Hotpoint RLA50 Refrigerator
Temp in refridgerator is 40 degrees on bottom shelf with temp gage turned to coldest setting. Is this right?
the normal temperature for a refrigerator is 35-40 degrees F, so 40 at full cold setting is not correct.
If this is a side-by-side or top-freezer, make sure that the air vents between freezer and fridge are not blocked by food items or ice.
Make sure defroster operation is working normally as ice will block airflow.
Also, there is a circulating fan in most models that moves cold air from freezer to fridge. make sure that's working.
Oct 21, 2009 | Refrigerators
Hi, Our Frigidaire refrigerator section is freezing all the food. What should the temperature be? It just starting doing this and we didn't change the thermostat. Thanks, Robin
Fridge should be around 35 degrees F. The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Oct 03, 2009 | Refrigerators
Coils keep freezing up its 4 years old
Iced-over evaporator coils, accompanied by a non-chilled fresh food compartment, happened in my GE side-by-side (model GSS20IEMDWW). For me, the problem was caused by a faulty temp sensor in the fresh food side. That sensor never signalled the computer that the temp in the fresh food side was cool enough, so the compressor ran constantly.
Since the compressor was running constantly, the evaporator coils (back wall of the freezer compartment) eventually iced over (took about a week). Since the fan that draws air over the evaporator coils could no longer move any air (due to the icing), the temperature in the fresh food side got warmer as well.
The fresh food side is chilled through a hole with a motorized door at the top of the dividing wall between compartments which opens when the fresh food side needs cooling. If no air is moving in the freezer compartment, temps in the fresh food compartment climb.
I replaced the temp sensor in the fresh food side and solved the problem for a while.
I bough a pair of thermometers at a kitchen store and put one in the freezer compartment and one in the fresh food compartment so that I could occasionally check to see if it made sense for the compressor to be running (ie, was it really necessary to be trying to cool either compartment, or were they already cold enough).
About six months later I had the coil icing problem again. This time the fresh food side seemed cool enough (according to the thermometer as well as the fact that the flapper door would close, indicating that the computer knew to not try to additionally cool the fresh food side).
The thermometer indicated that the temp in the freezer compartment was cold enough, but the system computer continued to run the compressor. So I replaced both temp sensors in the freezer compartment - which solved the problem again. (My fridge is about seven years old.)
If you are going to replace any of the temp sensors, replace them all under the principle of "if one failed, the rest will soon fail too".
Use a website like www.partselect.com to look up a parts diagram for your fridge and see if you can order just the temp sensors. Other websites (www.repairclinic.com and www.appliancepartsworldwide.com) may also be helpful. I have no affiliation with any of the sites I just mentioned - I'm just posting them as resources.
Jul 30, 2009 | GE GSS20IEP Side by Side Refrigerator
The fridge and freezer stopped cooling. we defrosted it. There was frost in the freezer. Before that the ice on the door had stopped and now it works too.
Iced-over evaporator coils, accompanied by a non-chilled fresh food compartment, happened in my GE side-by-side (model GSS20IEMDWW). For me,the problem was caused by a faulty temp sensor in the fresh food side. That sensor never signaled the computer that the temp in the fresh food side was cool enough, so the compressor ran constantly.
Since the compressor was running constantly, the evaporator coils (back wall of the freezer compartment) eventually iced over (took about a week).Since the fan that draws air over the evaporator coils could no longer move any air (due to the icing), the temperature in the fresh food side got warmer as well.
I bought a pair of thermometers at a kitchen store and put one in the freezer compartment and one in the fresh food compartment so that I could occasionally check to see if it made sense for the compressor to be running (ie, was it really necessary to be trying to cool either compartment, or were they already cold enough).
Jul 29, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
293 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
