Question about Sony Playstation 3 (PS3) Console
No video/audio output
When i turn my tv onto the AV setting it comes up with a blank blue screen. no picture or audio. i have tried two other tv's and a new cable. I have tried holding in the power button till it resets but this didnt work either.
  • Sony Master
  • 2,404 Answers
Problem with the main board then. You tried different cables, reset the ps3 and also tried different tv's to be sure it wasn't a TV issue.
You did everything I would have done. Call sony if you decide to get it repaired by them. I think they charge $150 from the last time I checked.
Posted on Sep 04, 2009
My kids PS3 comes on and then when you push play the light turns green and you hear it start up for a couple of seconds and then it goes off.
R - Restore: Restore default settings E - Environment: Change your environment, remove from media cabinet, try different media, try different equipment (TV, router, hotspot, etc.). P - Power Cycle: Power cycle by unplugging your networking equipment from wall for 2 minutes to reset. A - Access this Knowledge Center for useful articles to resolve issues. I - Install the latest System Software Update. R - Resolved: In most cases these steps can resolve your issue.
Adjust the video input on the TV to match the input connector that is being used to connect to the PS3™ system. Check that the cable is securely inserted. Try disconnecting the cable from the PS3™ system or TV and then reconnecting it. There may be a problem with the AV cable in use. Try using another cable that is compatible with the PS3™ system. If the video output settings on the system do not match those of the cable or TV in use, there may be no picture. If the screen goes blank, turn off the system. Then, with only the system and the TV connected, touch the system’s power button for more than 5 seconds to turn the system back on. The video output settings will automatically be reset to the standard resolution. If the resolution of the video content is not supported by the TV in use, when the video is played the screen may go blank. If this happens, go to the screen for selecting the resolution in the system’s video output settings, and then select all the resolutions that are supported by the TV.
Mar 23, 2010 | Sony Playstation 3 (PS3) Console
Can you put a phillips dvdr610 onto a television with built in freeview and then record from it. If so how?
If your TV has an OUTPUT MONITOR Output Jacks, Yellow, (Video) Red (Audio) & White (Audio) FEMALE RCA Jacks.Then these will output WHATEVER is showing on the TV screen. And can be used as an Output for any Recording Viewing device. There will be other, FEMALE RCA Jacks,AV, Yellow, (Video) Red (Audio) & White (Audio) and possibly also The Composite Video, Red, Green, Blue, all Video, These are INPUTS, they will be there also. Make sure.
Feb 16, 2010 | Philips DVDR610 DVD Recorder
Have a toshiba tp 61H95 proj TV- want to connect panasonic dvd recorder and toshiba vhs recorder so I can copy family videos to dvd- can't get hook ups set up for both to work.
Select AV-1 or some thing in TV and plug DVD recorder Video-Audio output in AV-1 input of TV, playback any DVD and confirm its picture and sound in TV. Press Stop button of DVD recorder to stop playback.
Now plug Video-Audio output of VCR in DVD recorder input and select AV Input in DVD recorder, insert VHS tape in VCR and playback it and confirm you get VHS picture and sound in TV via DVD recorder.
Hookup between TV, DVD recorder and VCR is completed.
Playback VHS tape in VCR, Insert blank DVD disc in DVD recorder and press Record while you see VHS tape picture in TV.
Hope this info will help you.
Feb 03, 2010 | Toshiba TP61H95 61" Rear Projection...
Ps3 as no video or sound i bought 3 wires for the tv and no color or soud sows we even used a ps2 cable
Excerpt from the PlayStation 3 Manual:
There is no picture on the TV screen.
*Check that the input mode of the TV is appropriate for the connector in use on the system.
*There may be a problem with the AV cable in use. Try using another cable that is compatible with the PS3 system.
*If the video output settings on the system do not match those of the cable or TV in use, there may be no picture. If the screen goes blank, turn off the system. Then, with only the system and the TV connected, touch the system's power button for more than 5 seconds to turn the system back on. The video output settings will automatically be reset to the standard resolution.
*If the resolution of the video content is not supported by the TV in use, when the video is played the screen may go blank. If this happens, go to the screen for selecting the resolution in the system's video output settings, select "Custom" and then select all the resolutions that are supported by the TV.
Jul 29, 2009 | Sony Playstation 3 (PS3) Console
Can not see the Video when I input it, see only a blue screen.
ok hook up the audio video in the OUTPUT on vcr and INPUT on the tv then make sure tv is changed to the right input channel now go to vcr and change that channel to AV,.if AV isnt there you may have to go into menu of vcr and do a channel search,but when you change it to AV on vcr you should see the picture
May 27, 2009 | Televison & Video
Sound but no picture
Your player has several outputs and you might want to start with the basic Video Audo Left Right output first.
Set your with your plazma to see if you can change the input types to accept the video and audio input which will probably be labeled AV 1, AV 2 and so on.
My guess is that you have it set for Component Red Blue Green which his a high def (just before HTMI) and requires a separate audio cable. Your player, depending on the age of the unit, probably will not have Red Blue Green picture output.
Next if you have an HTMI output from your player hook that to your Plazma in the HDMI 1 position and select it on the TV's setting. Audio and Video are both carried in the HDMI cable.
Good luck, my name is Eric Kirkhuff
Feb 23, 2009 | Toshiba D-VR4 DVD Recorder/VCR
My ps3 has no picture or sound...
if there's absolutely nothing on the TV screen, then most probably the video output is different then the cables you are using (eg: video output HD and you are using AV cables). Are you sure your TV is set correctly? like using HD cable you have to choose HDMI or AV cable choose AV. Anyway, When the PS3 is on, turn it off by pressing and holding the power button on the front (so the light turns red) you will hear beep sound ( I can't remember how many but not once). This should reset the Video output to AV. Swithch to AV cables (if you're using HD). Usually if the system is set to AV output and you switch to HDMI cables, the system recognizes that and swithches to HD output. But if it's set to HD output and you are using AV cables, it doesn't switch back; that is what my system does.
Jan 22, 2009 | Sony Playstation 3 (PS3) Console
Unplugged insignia box replugged cannot access menu unit comes on
Plug the Insignia output to TV video 1. Turn on TV, set to video 1 source. Turn on Insigna. You should now have picture and be able to go through the set up again.
Dec 31, 2008 | Insignia Digital-to-Analog Converter for...
Ps3 hdmi-av
i currently have the exact same problem...i always play HDMI but i went home from college for thanksgiving and wanted to play on a regular AV jack TV, hooked up, and have no picture whatsoever...and i think it's because of the settings on the PS3 since it's set to send out an HD signal...Well i found this straight from Playstation3.com, on the support/troubleshooting section
  • If the video output settings on the PLAYSTATION®3 do not match those of the cable or TV in use, there may be no picture. If the screen goes blank, turn off the system.
  • Then, with only the PLAYSTATION®3 and the TV connected, touch the system's power button for more than 5 seconds to turn the system back on. The video output settings will automatically be reset to the standard resolution."
Hope it helps =)
Nov 17, 2007 | Sony Playstation 3 (PS3) Console
Ps3 wont show up on tv
Hey i just posted i have the same problem as you do but then I checked the SONY PS3 website and it solved my problem. Try resetting your video output. I'll paste what it says on the PS3 website but if that doesn't solve your problem go to the website. They have a bunch of troubleshooting solutions for this problem...
If while manually changing the Video Output Settings, the screen remains blank for more than 30 seconds, you may need to perform the following steps to reset the Video Output Settings.
  1. Make sure the Component AV Cable is connected to the [AV MULTI-OUT] port on the back of the PLAYSTATION 3 system.
  2. Connect the other end of the Component AV Cable into the video and audio RCA jacks of the TV or display monitor.
  3. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings.
  4. Turn ON the PLAYSTATION 3 and once the system finishes powering up, the Video Output Settings will automatically be reset to the standard resolution (or detect the current display output settings of your TV/monitor).
Nov 03, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
35 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
