Question about Sony Playstation 3 (PS3) Console
PS3 setup/withHDMITV I have a PS3, a Sony HDTV, DIRECT TV, an HDMI switchbox,three cables, and a Psyclone cable for PS3. How do I set-up?
1 cable from the PS3 goes to input 1 on switchbox 1 cable from directtv goes to input 2 on switchbox 1cable from output of swichbox to your tv.
Posted on Dec 24, 2007
Ps3 is in hdmi1 and direct tv and wii has to share the video input because my tv doesn't have enough outlets so I have to switch cables every time . How can I get the wii to work ?
What you could do is setup the PS3 to HDMI-1, DirectTV to HDMI-2(or whatever compatable) and setup the Wii to either a component cable(RGBWR) or a Composite cable (YWR).
I'm not sure you can support all 3 systems through 1 HDMI cable, Not unless there is a tree cable that you have to all three. And even then only one could be on at a time.
Nov 27, 2012 | Video Game Consoles & Games
Hdmi Port wont work on PS3
you need to go into your console video settings and setup for hdtv to use hdmi.
May 21, 2010 | Sony Playstation 3 (PS3) Console
Have had psp3 hooked up for 2 years, set up on video 2, with direct tv it has now started flashing no signal.
PS3?????PSP????????PSP3000???????I assume its a ps3, probably(if you use an HDTV) you have 1-3 HDMI,,or component,or composite(standard) (I have 2 of each) In which your direct TV might be taking it...... OR if you have an animal or infestation check your cables to see if something on the tips is bent or the cable chewed up.......this is all i could think of...
Jun 16, 2009 | Sony Playstation 3 (PS3) Console
42" Sanyo HDTV with 3 HDMI Inputs
Everybody is having problems with sony products and HDMI cables. It's on a lot of forums. So, your not alone.
Most of the solutions are:
1. Unplug your TV for 30 mins.
2. Plug TV back in and put it on HDMI for PS3.
3. Hold down the power button for 10secs on the PS3
That should solve the problem.
Feb 17, 2009 | Sanyo DP42746 42 in. Plasma Television
No surround sound from my PS3 through the Onkyo 5100. Video OK
Unfortunately only the higher end Onkyo Reciever pass audio over HDMI for sound. 605,705,805,905 exc. Your reciever will carry Video over HDMI but you will need a digital optical cable for sound.
thanks.
Jan 24, 2009 | Onkyo Audio Players & Recorders
Ps3 won't display on hdtv via dvi
Re-Set the PS-3, by pressing and holding down the power button (front panel) this hard re-sets the unit and yo can then reconfigure via the composite video cable it came with, back to HDMI / DVI
Dec 17, 2008 | Sony Playstation 3 (PS3) Console
Toshiba HDTV + SONY PLAYSTATION 3 + SONY Home Theatre DAVHDX265
I have looked up the infomation on your TV I noticed that your TV has two HDMI input plugs. Since your SONY BRAVIA is hooked up to one port, you need to buy another HDMI cable for your PS3. On your tv remote you should have an option to switch from video 1 to video 2 so then you can switch from the SONY BRAVIA to the PS3 the problem is you will only hear your PS3 Sound from you TV. If you want to hear your PS3 sound from your SONY BRAVIA you need to buy an optical cable (also called TOSLINK) to connect from your PS3 to the SONY BRAVIA.
Hope that helps!
May 01, 2008 | Televison & Video
Playstation 3 audio connection into Yamaha HTR-6040 AV Receiver
Is Yamaha HTR-640 a receiver? Try HDMI from PS3 to receiver or Sony HDTV. If HDMI from PS3 to receiver the you need and HDMI from receiver to out Sony HDTV. You could connect everything to receiver and HDMI out to HDTV. You can not have an HDMI cable AND an optical cable coming out of the PS3, only one or the other.
Dec 30, 2007 | Yamaha HTR-6130 Receiver
No sound from HDMI to PS3
go under system setting-->select sound settings-->select audio output settings -->hit x on hdmi-->hit x on automatic-->hit x to enter. This solved the issue for us :)
Dec 04, 2007 | Sony Playstation 3 (PS3) Console
PS3 hdmi cable
Hold the power button for 5 seconds or more, that will reset to regular viewing ratio. From there you can adjust to whatever you are using. I had the same problem.
Aug 25, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
77 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
