Question about Dell 810 All-In-One InkJet Printer
We turn on the printer, and it does nothing, if we need to photocopy something the paper is getting stuck, weve taken it apart to see if there is anything stuck in but found nothing. it pulls to the left side, but paper just stays in original tray, and will not go through the machine at all, any advice please
  • 40 Answers
There Rubber roller in the machine. They need to be cleaned-up, check where the paper goes in the printer and clean the rubber roller with alcool so that the printer can take the paper instead of spinning on.
Posted on Sep 04, 2009
There is Dark spots on paper when a photocopy is done
Most likely there is something on the glass or something ie: dust underneath the glass that gets in the way of the scanner and the paper(dots) or on the scanner itself(streak). I have heard many times that photocopy machines in cvs/wall greens, any kind of commercial copy places and even libraries deliberately mark on the glass with permanent marker to prevent any kind of copy fraud. You can clean the glass with rubbing alcohol or goof off to remove any stubborn ink on the glass and then use some Windex or something, but if its underneath the glass or on the scanner bar you will need to take some stuff apart clean it and place it back. IF you do that make sure its SUPER clean and you dont leave any finger prints on it
Feb 04, 2014 | Sharp AR-M207 All-In-One Laser Printer
Hp laserjet 4345 mfp cannot photocopy anything because the startup button has a red light
Hi Bridgette.
The red light on the startup-button indicates that the machine is not ready for a photocopy. Usally there is something stuck in automated document feeder (ADF). Take a close look and see if can see something in the paperpath. If no luck, try pushing a A4 sheet manually through the ADF and see if something comes out with the sheet. Usally there is a small piece of paper, a paper clip or a staple stuck in the ADF. If nothing found in the ADF, the Scanner Controller Board is probably broke, and needs to be replaced. Good luck.
Dec 31, 2013 | HP LaserJet 4730mfp All-In-One Printer
There is a paper clip stuck somewhere in our Kyocert Mita 3830. When copies are made the imprint of the paper clip is on the page.
Since it is a printer and not a photocopier, I don't think you would get imprints of a paperclip even if there were one stuck in it. Somebody might be playing the prank in this video: on you where one takes photocopies of a paperclip and then leaves the output papers in the blank paper tray.
Sep 06, 2011 | Office Equipment & Supplies
My printer folds up the paper like an accordian. What can I do to repair this?
That usually means there's something stuck inside the rollers of the printer. The only way to fix this, is to open the printer cover and remove the rollers to clear the object (it's usually a little piece of paper or something). If that doesn't work, then the rollers need to be completely taken apart and should be done by a professional or someone that knows what they're doing.
Jul 11, 2010 | Konica Minolta magicolor 2300DL Laser...
Printer jammed. I cleared the jam but it
You most likely have a tiny piece of paper stuck in the paper path that cannot be seen unless taken apart. Depending on the type of printer... remove the paper tray and the back cover and look for any small shred of paper. If you still see nothing, a local repair shop would be your best option.
Jan 02, 2010 | Office Equipment & Supplies
How to solve a paper jam on dell 924 printer
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Nov 26, 2009 | Dell 924 All-in-One InkJet Printer
The printer says I have a paper jam. There's none,but it won't wo
One of the paper sensors is probably stuck. Some disassembly may be required to get to them. They are normally small plastic rockers that will let a small IR device either allow a beam of infrared light to pass or block it. On this printer, I would guess that there are 2 of them. One located at the paper feed so it knows if there is something in the tray or not and the other is probably located at the back where the paper curls back around to pass beneath the print area. There could also be a thrid at the output tray, but with this particular model, I kind of doubt they put one there.
Apr 14, 2009 | HP PSC 1215 All-In-One InkJet Printer
Won't print - says 'paper jam 2' but no paper is stuck in machine
Paper jam 2 error code is saying the jam is in the fuser area of the machine.
You need to remove the toner cartridge, and since you said you've taken the whole thing apart, maybe try a flashlight and look for a LITTLE piece of paper that may have torn off that remains stuck around that fuser area (the fuser is the thing behind the toner that gets hot-- so be careful -- but look in the corners and anywhere a small piece of paper could have torn and got stuck.
If you're absolutely sure that there is nothing stuck, I'd try to do a hard-reset: Turn off the machine, unplug the power cord and the cable that goes to your computer (if it's hooked up to one. And if it is hooked up to a computer, power down the computer as well.) Wait a minute or two, plug the computer back in, plug the power cord and cable from the printer back in, then turn on the printer and the computer and let them both go through their various start-ups.
If none of that works, let us know.. but from what I know and the docs I have access to, it should work... (fingers crossed!)
Good Luck!
Maggie B
Feb 22, 2008 | Samsung SCX-4216F All-In-One Laser Printer
Paper Feed
Try turning the printer upside down and shaking it. Sometimes something small like a paper clip or Lego brick gets down inside and will prevent the paper from feeding.
Apr 04, 2007 | Lexmark X75 All-In-One InkJet Printer
Dell 810 All-In-One InkJet Printer Logo
93 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
