Question about Sony QUALIA 004 Projector / Full High Definition SXRD home theatre projector Multimedia Projector
I have replaced the bulb and filter and followed the instructions to reset the timer,but the projector refuses to reset and switches off after 1 minute.Can anyone help....DAVID
  • 430 Answers
This is a hardware fault. The projector is thus not able to initiate reset.
Posted on Sep 04, 2009
I replaced the lamp on my sharp dt100 projector and now it will not turn on
Have reset the lamp hours after installing the new lamp? If, not the projector has treated the new lamp as old lamp & refusing to light further. So, reset the lamp hours to zero. To reset the lamp timer do as follows. Plug the power cord into the AC socket of the projector. Switch ON the power of the socket. (not projector) While pressing simultaneously MENU/HELP, ENTER & DOWN (button near MENU/HELP) on the projector, press STANDBY/ON on the projector. "LAMP 000H" is displayed, indicating that the lamp timer is reset. If this does not correct your problem then the problem lies in other area. Let me know so that further I can provide you solution. Above things are preliminary.
Aug 06, 2011 | Sharp Office Equipment & Supplies
Failure to change Filter Time
unplug projector for about an hour, and then remove bulb, and filter, inspect areas for damage, also inspect it to make sure your inserting it correctly. put filter and bulb back in, put covers back on, then plug it back in. reset the timer. if you still have problems let me know.
May 06, 2008 | Hitachi Performa CP-RS55 Multimedia...
I changed the bulb and the power lights wont come on
Certain Mitsubishi projectors have a built in bulb life timer, and are programmed to not allow a projector to power on unless the bulb is replaced and the bulb life timer is reset. Its a simple process:
1) Make sure your projector is plugged in.
2) Make sure the main power switch is on.
3) Hold the left arrow, right arrow, and power button on the control panel of the projector (not remote) for 3-5 seconds.
4) Release...
This will reset the bulb life timer to 0000 and allow for normal power up barring any other unforeseen issues.
Mar 07, 2011 | Mitsubishi HC3000U Multimedia Projector
I replaced bulb for Notevision PG-C30XU but how do i reset the lamp timer?
hi,
Do the following for reset the lamp hour
1.Plug the power cord into the AC socket of the projector.
2.While pressing down arrow, right arrow and ENTER on the projector a , then press POWER ON on the projector.
3."LAMP 0000H" is displayed, indicating that the lamp timer is reset.
ok
Feb 10, 2011 | Sharp Notevision PG-C30XU Multimedia...
I had a bulb burn replaced both bulbs worked for a couple of days but now it wont power up only lamp1 light blinking. I have tried taking bulbs out and putting them back in still nothing, also the lamp...
the lamp units should be properly aligned with the 2 very tiny switches
between them. If not lamp led will blink.
If lamp led is continuously on, lamp timer has to be reset, according instructions that come with new units.
Original lamp modules are AH-45001 and AH-45002, two different
units needen for 1 projector, reset procedure is different for each lamp !!
Dec 21, 2010 | Eiki EIP-4500 DLP Projector Multimedia...
How do i reset lamp
Power on the projector. Press the left and right arrow keys and the power key on your remote to reset the lamp timer. The three keys must be pressed simultaneously to reset the timer.
Read more: Mitsubishi SL2U Bulb Replacement Instructions ' eHow.com http://www.ehow.com/how_7313866_mitsubishi-sl2u-bulb-replacement-instructions.html#ixzz1dQh2wmwh
Dec 19, 2010 | Mitsubishi SL2U Multimedia Projector
Flashing red light on lamp and filter
OK, let me throw out some possibilities. Most projectors how a built in lamp and filter timer. This lets you know when you need to clean your filter or replace your bulb. If left unchecked some models can prevent you from using the projector til the maintenance has been resolved. Clean your filter and refer to your owner's manual for how to reset the timers. If you still get the blinking or red lights after you have reset the timers then you may have a bad bulb or the contacts in the lamp assembly are tarnished or corroded. Pull out the lamp assembly and make sure the leads to the lamp are tight now take a small knife and scratch the metal contacts that the lamp assembly uses to connect to the projector. Clean them well so they will make good contact. Reinsert the assembly, close the case, and try it out. If you do not know how to take out the lamp then refer to your manual as it will have detailed instructions. If your projector still does not work then your lamp is bad and needs to be replaced.
Jul 19, 2009 | Hitachi CP-X253 Projector
How to reset the bulb timer for TOSHIBA TLP-XD2000
The booklet that comes with a new lamp specifies the following for the TLP XD2000. While holding down
Mar 12, 2009 | Toshiba Office Equipment & Supplies
Bulb Replacement
the bulb hot indication has nothing to do with the lamp counter.u would have reset the counter as suggetsed by the manufacturer,
this problem is because of the following:
1) wrong bulb
2) cooling fans not working adequately
3) defective ballast
check the above for a solution
Jan 08, 2009 | Toshiba Replacement Projector Bulb...
Sharp projector XV Z90U
I also had this issue - followed the On, Input, Undo, Left, Enter, Right, On button sequence several times. Then I decided to push them in that sequence very quickly and it worked. The lamp LED on the front changed to green and the projector started up. So the button sequence they provide in the manual works, you just have to push them in rapid succession. Hope that helps.
Oct 31, 2007 | Sharp Projector lamp Projector Lamp
44 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
