Question about Garden
Finding parts for a stihl fs66 weed eater
I need to find a new or used (preferably used) cylinder head and piston for my stihl fs66 weedeater and also i need to know if those same parts off a larger model would just bolt right on for a little more power output
  • 143 Answers
I dont think it would be wise to fit used parts to a
twostroke engine and parts of a bigger model
wouldnt fit.
Posted on Sep 05, 2009
Weedeater troubleshooting
bad extension cord ???
Aug 28, 2014 | Stihl Garden
How to line the feed on Stihl FR 106 Weed Eater Max 420 head
could you add a picture of the particular head you're using.
Aug 22, 2014 | Stihl FS 85 Weed Eater
Does 4123-400-1300 and 0000-400-1300 the same
0000-400-1300 is for chainsaws and large brush cutters. The 4123-400-1300 does not appear to be a good part number. The correct number is 4123-400-1301 and it is no longer available from the factory meaning you need to find a good used one, find a dealer with new old stock or buy a new trimmer
Jun 26, 2014 | Stihl Trimmer Ignition Coil Ign Module 48...
LOW COMPRESSION ON A WEED EATER; WON'T START
If it's a 2 cycle. Check that your piston and cylinder are not scored. Do this by removing the muffler and look into the cylinder as you slowly pull the cord. If you see score marks you may be able to find a new cylinder/ piston depending on brand and rebuild.
If it's a 4 cycle ohv(stihl) is could be the valves needing adjustment.
Sep 18, 2013 | Garden
Weedeater head spins off the weedeater body
Jacque It's possible that you are not tightening the head on properly or the nut has completely sheared. If you can get some two part resin glue i would suggest that you try and stick it back with this. I used it on a Mculloch and it lasted years. Make sure to give it 24 hours to set and that everything is clean.
Sep 03, 2013 | Stihl FS 85 Weed Eater
Weed eater head spins on its own, no power.
check the compression on your weedeater low compression will cause this
Jun 26, 2013 | Poulan Genuine Weedeater Part # 36006-128
No power fs66 stihl weedeater
Hi When you cleaned the muffler out did you also clean the carbon out of the port on the cylinder as this can be blocked as well. Also you will have to retune the carby, There should be 2 screws 1 for low speed marked l on the carby body and 1 marked h for high speed to start with they should be set at 1 & 1/2 turns out from closed the low speed you set at an idle and the high speed you set at full throttle. Hope this helps.
Aug 03, 2009 | Garden
My weed eater will not ignite the gas
pull the muffle off and look inside the cylinder,if you see score marks it means that you need to replace the piston and cylinder,usually they are not worth rebuilding,you are looking at $125.00 to $175.00 to replace these parts.that price does not enclude any labor cost.hope this helped,let me know.......................
Jun 26, 2009 | Garden
Stihl weed eater runs 2min. then stop
Stihl weedeater was running and stopped suddenly. Put in a new fuel filter and cleaner air filter with soap and water. Checked spark plug and it appeared fine. Started the weedeater, ran for a second or so and stopped. Spark plug wasn't gas fouled. Could it be the carburetor needing new diaphram gasket and spring.
Apr 23, 2009 | Ryobi Garden
Gap setting poulan wildthing blower
buy an echo or a stihl... poulan rates this motor for 40 hours of use and then it is done.
head bolts came loose on mine piston slap wore out jug ring and piston. don't want to spend 40d on parts to repair a 100d unit
Dec 06, 2008 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Garden Logo
1,302 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
