Question about Samsung SGH-Z500 Cellular Phone
Opening the flip up screen problem
On opening the flip up screen the screen lights up as normal,but when the flip up lid has reached the end of its travel the screen goes off,on moving the lid back towards the closed position the screen lights up as normal again
How do I change the belt on carpet device
Flip it over, reach inside the front part of the opening in the middle an flip the latch open and the bottom part will hinge open. The belt will be on the end, you will need to remove the old one and then lift up that end of the roller and place the belt on the end of it then use a screwdriver to stretch it enough to slide it over the gear in the bottom of the base that is turned by the motor. replace the bottom plate.
Jan 31, 2015 | Bissell Vacuums
How to open the pfaff synchotronic 1229
Do you mean taking off the travel cover and flip open the cover? Lift the handle to get it straight up. Press the latch in the center of the top on the front of the cover and let the lid tilt forward as far as it will go. Lift off the carrying case cover (sides and back). Then press the latch again and flip the lid completely down.
The accessory box needs to be accessed by reaching under the detachable work surface and swinging to the left. Then swing the bobbin holder to the rear of the machine. Lift up the work surface and open the lid to the box.
VSM Group now owns this Pfaff line and has the manual available here: http://s2.vsmgroup.com/VSM/Pfaff/pfaffmanual.nsf/1fd5659e6f37141041256697003e64c0/1b4dc207a9ed3ce7852575fb006d2eb5?OpenDocument . The direct link to the manual is http://s2.vsmgroup.com/VSM/Pfaff/pfaffmanual.nsf/1fd5659e6f37141041256697003e64c0/1b4dc207a9ed3ce7852575fb006d2eb5/$FILE/Pfaff%201229%20Synchrotronic%20x%20.PDF . See page 1 (page 5 of the PDF) for pictures of opening the cover on the machine.
I hope this helps.
Jul 17, 2012 | Sewing Machines
How do I get my motorola gleam phone to answer by opening the flip
To Enable Answer/End Call by flipping open / close the lid you have to enable it in the phone menus. Surprisingly it's not in settings ( where it used to be on older Motorola phones).
Key presses:
  • Menu
  • Select Call center(top left)
  • Call settings (2)
  • Advanced Settings (5)
  • Answer mode (7)
  • Select Cover Answer
Done
Jun 25, 2012 | Cell Phones
How do you get the lid off to replace the lid switch.
remove the screws on each end of the control panel,some units you have to remove the end caps to get to the screws, then flip back the control panel it has plastic hinges so be careful,then you unplug the lid switch,remove the two clips with a screwdriver that hold the back on,open the lid and reach on the inside and pull the back towards you and lift off the base,replace the switch and reinstall!
Sep 02, 2010 | Kenmore 24902 Top Load Washer
How do you get the top of the cabinet off of a Sears heavy duty washer series 80, model #11092283800? It vibrates excessively w/o a load.
should be 2 screws in the control panel ,some panels you need to remove the end caps to remove them,then just flip the control panel back it has plastic hinges so be careful,then you unplug the lid switch,pop off the 2 gold clips holding the back panel to the housing.then just reach inside the lid tilt slightly towards you and lift off the frame.
Aug 01, 2010 | Kenmore 23822 Top Load Washer
How do i take the front panel off the maytag washer MAV4758Aww s/# 27991360JV
pop off the end caps on the control panel and remove the screws ,,,then pull the panel slightly forward and flip it back ih has plastic hinges on top so be careful,,,, next unplug your lid switch,,,then remove the two clips holding the back to the base with a screwdriver,,, then open the lid reach inside the inner rim and pull the back towards you at about a 45degree angle and then lift the base off the frame ,,,look inside and pay attention how the base comes off the frame and it will be easier to put back together!
Mar 09, 2010 | Maytag Ensignia MAV4758AWW Top Load Washer
Need to replace spin switch on Kenmore 110.26832690. Have switch but can't get to it.
you would need to remove the outter base,,,,first unplug machine,then remove the screws on the control panel each end,,some machines you have to remove the panel end caps to get at the screws,,,then pull the panel forward a bit and flip it back it has plastic hinges on top so be careful,,then you can unplug the lid switch,,pop off the 2 gold clips with a screwdriver that hold the base to the back panel,,,,then open the lid reach inside the rim pull the back of the base up and towards you and lift off ,,,if you look inside and pay attention to how it comes off the bottom frame it will be a whole lot easier to put back,,,once the base is off you can replace the lid switch then reinstall the base,,, don't forget to plug the switch back in!
Mar 07, 2010 | Kenmore Washing Machines
Ds lite top screen showing colours and lines but thats all can u help?
If you Feel confident enough to open up the ds check the top screen ribbon cable is as tight as possible, its at the top end of the board near the hinge.
The ribbon cable could be faulty do to rubbing on the inside of the hinge, check if the image on the screen changes when you flip the lid towards you and back, if it does chances are the screen will need to be reworked or changed. hope this helps.
Jan 18, 2010 | Nintendo DS Lite Console
Detergent does not get released
i have seen a problm perhaps similer to yours on several makes of dishwashers .. some washers have a flip up lid that normally covers the detergent cup .. if the upper basket is in the lower position (if its adjustable) then it blocks the flip up lid from opening ... this seems to be a design problem with several makes (probably all made by the same company ) .. if you put the upper tray in its up position then the door still doesnt open all the way but enough that the detergent gets washed out eventually .. that is if there is no large items just benieth that flip up lid .. if so that can block the water from getting into the detergent cup .. you end up with undesolved detergent still in the cup and in the washer at the end of the rince cycle .. very bad ... you may have a different problem .. for instance if the detergent cup door is not opening at all (bad opening mechanism) .. or if the pump screen is clogged then no water is circulated to desolve the detergent ..
Jan 02, 2010 | Dishwashers
Not spinning after wash cycle
remove the 2 console screws one on each side of front or they may be on the back of console,flip it up and you will see the lid switch jack on the washer in the middle,unplugon the washer side you want two cut the 2 outside and wire nut them together,this will by pass the lid switch,plug back in,put console back and you should be good to go-mike
Nov 02, 2008 | Kenmore 22422 Top Load Washer
Samsung SGH-Z500 Cellular Phone Logo
210 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
