Question about Philips 32PW6506 32" TV
My screen is a black and the tv is a standby
Hello.
I have a problem which philips 32pw6506/01.
When I turned on the TV button stays on standby.
Can anyone tell me which part to replace?
Thank you very much.
A greeting.
  • 35 Answers
Very comon faults on this tv is a small 12uf electrolitic capacitor but you will need an engineer
Posted on Sep 04, 2009
I have a Sony FD Trinitron Wega (KV-32HS510). When I attempt to turn the tv on by pressing the power button on the remote or on the tv, the standby light comes on and I hear two clicks but tv don't...
The primary power supply is good,maybe the horizontal output transistor is deffective thats why there is no high voltage supply in the picture tube because theflyback have no supply voltage and oscilation.So check the harizontal output transistor and replace if deffective.
Sep 12, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Unit stays on standby
The only thing I can find in the manual (link below) is to remove the power cord for a few minutes & try powering on from the "Standby ON" button, also set the "source" to anything other than TV. http://www.p4c.philips.com/files/l/lx3600d_25/lx3600d_25_dfu_eng.pdf
Jul 07, 2007 | Philips LX3600D System
Magnavox tv when the power button is pressed the green light comes on but nothing else happens; there's no picture or sound or nothing; but the green light simply stays lit (no blinking).
first, press the channel -/+ button on the TV. If that doesn't turn on the TV, then it means you have to replace the bulb of your TV. The bulb is most likely dead.
Replace the bulb and your TV should be restored.
Let me know if you need further assistance.
Regards.
Aug 12, 2011 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
I bought my son a 19" philips tv model # 19pfl340d/27.in order to turn tv on it must be unplugged for 10-15 minutes.The first one I bought did the same thing and I returned it.this one is exactly the...
The remote control will not operate the TV when the TV is in the OFF mode (No LED lit on front bezel). To change the mode from OFF to STANDBY or ON, press the POWER button on the side of the TV. Once the POWER button is pressed, the LED will change to either red to indicate STANDBY or green to indicate ON, whichever mode the TV was in prior to being turned off with the TV POWER button.
By pressing the POWER button on the side of the TV, the mode will toggle from OFF to either STANDBY or ON. If the POWER button is pressed and then the LED on the bezel is red, the TV is in STANDBY mode and will need to be turned on using the remote control. If the POWER button is pressed and then the LED on the bezel is green, the TV is ON.
Nov 11, 2009 | Philips 19PFL3403D/27 19 in. LCD TV
Dmtech TV is stuck in stanby mode
The problem IS PROBABLY BEING CAUSED BY A SHORTED POWER REGULATOR (MX084 ) OR AN OPEN FUSEABLE RESISTOR IN THE POPWER SUPPLY...
thank u rate me!!
Feb 12, 2009 | Sony KV-32S42 32" TV
Need help
turn tv on press and hold set button tell it blinks or stays lit push tv on remote push on and off tell tv shuts off press enter now you should have it
Feb 07, 2009 | Philips Universal PH301S Remote Control
Philips 50p8342 problem
I have tv proyection philips model 50p8342, it is blinking red color on the power switch botton four times and then pause then another four time continuosly.
Aug 15, 2008 | Philips 60P8341 60" Rear Projection...
Tv codes
Hello, Well I have a Phillips universal remote but but maybe they are the same. For the Orion TV try 105, 115, or 713. For The Pioneer DVD Try 042. If one or more does not work, Look for a "code Search" button. Turn on the device, then push and hold down the code search button until the red indicator stays on, then release the search button. Press and quickly release the desired mode button (TV, DVD, etc). The red indicator blinks off once. . If it is a tv or vcr use the channel up button until the channel changes. Press the power button on DVD and see if it is right Hope this helps.
Mar 16, 2008 | Philips Magnavox REM-350 Remote Control
Plasms tv
Hello
Do you have a back-UPS?
May 30, 2007 | Panasonic TH-42PA20U/P 42 in. Plasma EDTV
Philips 32PW6506 32" TV Logo
267 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
